Question about Emerson Televison & Video
Emerson lc320em2/ 2 thin vertical lines in center of screen
circuitcity
  • 137 Answers
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Posted on Dec 06, 2007
SOURCE: green vertical line on the right side of screen
I bumped my screen by accident recently and now have a similar problem (multiple vertical and horizontal thin lines). I was told that the screen is now bad and probably cannot be repaired. The cost of replacement is more than the cost of a new set. Sorry, but that may not be the answer that you are looking for.
Posted on Dec 10, 2007
  • 50 Answers
SOURCE: thin red vertical line on sanyo lcd-37xr1
Sounds like your display panel is going out. Has the tv been droped, or hit by anything? You should call your customer service number to confirm.
Posted on Feb 27, 2008
  • 31 Answers
SOURCE: 50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Posted on Mar 10, 2008
  • 586 Answers
SOURCE: Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Posted on Jun 27, 2009
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Brand new 55" led Emerson tv has s thin red blue green line(one line)verticle on right side of screen? What to do?
If it does not disappear in a little while, just ask the shop repair or bring a new screen. Must be a guaranty case.
After installing my computer screen, I had vertical lines in the middle, but after some time (In my memory about a few hours) they all disappeared and never came back.
Jan 06, 2015 | Televison & Video
Thin black verticle lines on screen some disappear when warm toshiba wide screen tv
The post is a bit confusing. However, I have a Toshiba 42rv530u model where vertical lines appeared. Tech came out and ordered a new panel. It sounds like the same situation with you.
Nov 09, 2009 | Emerson Televison & Video
Black screen with a line of the picture running
The vertical sweep generator is dead. The circuit that controls the lines being drawn from top to bottom has malfunctioned or died. This not something you can fix, you will need a professional.
Apr 02, 2009 | Emerson EWF2703 27" TV
Lighted line in center of tv
the trouble of your tv is not a picture tube.it's in vertical section,so check the supply of vertical IC if its ok ,re solder the ic.
Sep 30, 2008 | Emerson EWF2004 20" TV
LCD TV - RED LINE
I have a thin red vertical line on the left side of my Philips LCD TV
Feb 25, 2008 | Televison & Video
10 yr old emerson tv
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace. You'll need to take your set to service center to have it serviced.
Good Luck!
- Jim
Feb 08, 2008 | Televison & Video
No picture
a bright thin line in centre is called horizontal line. first of all do not keep tv on unless it is rectified. BUT If you want to put on tv keep brightness minimum to protect your screen for any demage. now solution your problem is in vertical section. 1 check vertical supply. 2 check parts in vertical section or loose contact. 3 yoke connrctor loose 4 ic defective It is not serious problem can be rectified easily
Sep 19, 2007 | Toshiba 32DF46 32" TV
Televison & Video Logo
126 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
