Need program codes for vizio vz043 remote - Televison & Video
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
Posted on Feb 19, 2008
VOTIT
  • 2071 Answers
SOURCE: VIZIO REMOTE CODES
JUST TRY THIS PROCEDURE;
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 02, 2008
SOURCE: I need the code for vizio L32 to program One For All remote
I used the LG code 0178, to program my universal remote, it was not a One For All remote but the code worked.
I can't remember where I found the code, but give it a try!
Posted on Nov 27, 2008
  • 4 Answers
SOURCE: code for Vizio tv
Unfortunately, those remotes only take a 3 digit code. I bought 2 new remotes, which do take 4 digit codes, but the code(s) for the Vizio do not work (or partially). I found that the 4 digit codes for the Goldstar and LG work better than those provided for the Vizio, but still not as good as the original Vizio remote.
Posted on Apr 01, 2009
SOURCE: Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
Posted on Aug 28, 2009
Where can I get a vizio vz043 manual
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 11, 2014 | Vizio Televison & Video
I need codes for vizio vz043 for tvs mine is a mitsubishi
049,041,044. Try these codes. For more information check this link. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 07, 2013 | Televison & Video
I need a code for a vizio universal remote control vz043 to program a dynex tv
0382,-927,0917,0988,0936 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Check this site too.
Apr 21, 2013 | Universal Remote Control Televison & Video
Very old tv don't know name need code for vizio vz043 DC20110304
Check these Vizio codes. 0034,0019,0082,0091,0000. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 15, 2013 | Televison & Video
I have a sanyo tv with a vizio vz043 remote with no code book
0049 0097 0110 0004 0268 0012 0108 0180
Try these codes.
Apr 06, 2012 | Sanyo Televison & Video
Need the Vizio universal remote code for Sharp TV Model #VZ043
With the manual for the remote try the codes listed and some units have a way to try all codes one at a time.
GOOGLE the model number of the remote if you need it with "manual" listed after the remote model number.
Mar 24, 2012 | Televison & Video
What is the vizio code for remote vz043
Dear Sir:
Please go to the next web:
www. fitness.manualsonline. com give your model, etc and download for free. sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 20, 2012 | Televison & Video
Televison & Video Logo
758 people viewed this question
Top Televison & Video Experts
Electro Med Services...
