Question about Ubi Soft Entertainment Imagine: Babyz for DS
Cannot cut lawn
After receiving 3rd child parents do not pick up the child and you can't cut the grass to go outside
Go to the attic. Find the lawnmower and tap the button on the lawnmower with your stylus and slide it right to pull the starter. It takes practice.
Posted on Feb 08, 2009
My mower cuts the grass fine but does not collect the grass cuttings which are left all over the lawn.
check and clean under deck --wet grass -to slow a speed - grass to thick/to high improper hook up of bag
Sep 15, 2016 | Garden
I just got a honda lawn mower and i can't tell when i want to cut grass taller if i take the lever for the wheels up to cut longer of down to cut grass shorter
When the wheels go up, the body goes lower, so the grass is cut shorter. Take notice of the body of the mower rather than the wheels because that is where the blade is.
May 20, 2016 | Honda Garden
Why won't my toro model 71225 15 horse hXL m554201196. Will not pick leaves
I do not pick up leaves. I just keep mowing over them until they are very small pieces. Over the winter they decompose and fertilize the lawn.
Nov 06, 2015 | Toro Garden
Why do the clippings remain on lawn and don't enter bag?
Blades cut the grass and blow air like a fan. The clippings should flow along with the air out into the yard or into the bag. That only works if the bag acts like a filter and catches the clippings but lets the air out to be replaced by more air and more clippings until the bag is full of clippings.
The most likely problem is that your bag does not let the air out. Cutting wet grass will coat the inside like green paint. When dry, it's like the underside of your mower.
Check the inside. You might need to scrape and/or flush from the outside in. Can yours be turned inside out"? That would be the best case.
When clean and dry, it should work.
Didn't mention the easiest fix: to take out the hand-ful of clipping blocking the path to the bad: since you already checked that.
Aug 31, 2014 | Garden
Not picking up grass
maybe discharge shoot clogged or mower not running fast enough
Aug 16, 2014 | NA Black & Decker SPCM1936 19-Inch 36-Volt...
Lawnmower problems
if you let grass grow to long will be to heavy to be picked up and go into bag
Aug 13, 2014 | Garden
How to fix Honda HR215 mower from skipping grass
check the belt tension on the deck
Apr 22, 2012 | Garden
The riding mower doesn't cut evenly...one side cuts higher than the other...
The following steps will make any riding mower cut evenly.
1. The rear tires must be the same diameter i.e. same tread type and the same tire pressure (check it before each mowing).
2. Level the deck following the instructions in the manual and recheck it occasionally
3. Make sure the blade(s) are not damaged and kept sharp, rounded blades tear instead of cut.
4. Make sure the deck and its attachment points are not bent or damaged.
5. Drive at a slow walking speed with the engine at cutting speed.
6. Over lap rows in amounts sufficient to lift and cut the tire tracks from the previous pass.
7. Cut the grass at intervals that ensures you never have cut more than 1/3rd the total length of the grass.
8. Make sure the underside of the deck is clean.
9. Use a blade style that matches the type of grass you most often mow.
Jun 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
WHY IS CUT UN EVEN? MOWER LEAVES LINES IN LAWN
My 10 steps to ensure even cutting for any riding mower.
1. The rear tires must be the same diameter i.e. same tread type and the same amount of pressure
3. Make sure the blades are not damaged or bent.
4. Make sure the deck nor its attachments are bent
5. keep the blades sharp and don't drive too fast when mowing.
6. Over lap rows about 20%
7. Cut the grass at intervals that ensures you never cut more than 1/3rd the total length of the grass.
9. Make sure the underside of the deck is free from chunks of clippings.
10. Use a blade with higher lift, yes you have to match the blades to the type of grass you cut most often, (commercial mowers use a universal blade and high speed decks).
Jun 18, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Ubi Soft Entertainment Imagine: Babyz for DS Logo
47 people viewed this question
Top Ubi Soft Entertainment Video Game Consoles & Games Experts
Colin Stickland
Colin Stickland
akigawa
Level 1 Expert
Adam Jasar
Level 1 Expert
Are you an Ubi Soft Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
