Question about EliteGroup P4S5A/DX (ECSP4S5A) Motherboard
USB I need the manual to setup the front USB
  • tzatsisgre Oct 27, 2008
    i have the manual but i need more information
  • 21 Answers
Http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=1&DetailID=38&DetailName=Feature&MenuID=1&LanID=9
then click on manual under downloads.
Posted on Oct 25, 2008
How to conect front panel
For this you need the motherboard manual.
If you do nor have it, download it.
The setup procedure will be at the beginning, after the specifications. The two cables from the front panel that are important are the (power on , LED reset) cable, and the USB cable.
Both these cables are built to the Intel developed, case standard, on most PCs.
The problems start when you are building a PC with an old case. The wires from the front panel will be all separate.
The motherboard manual will have the location of the pins, and the "pin out" for the motherboard.
The color lead is positive, and the white is negative.
The speaker wires are red and black, and the polarity does not matter.
Do them one at a time. Start with power on, when you have found the proper pins and hooked up the leads, then reset, then power LED, then HDD LED, and last the speaker.
Then find the USB pins and connect the USB cable to the motherboard.
The PC should boot, assuming the other components are installed.
Sep 02, 2015 | Computers & Internet
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
I have an Intel D845GVSR motherboard. The 4 back USB ports are enabled but the two front ports aren't. I also have a Creative Combo NS DVD ROM with card readers in it. My Computer guy enabled the card...
This is probably set in the BIOS. You need to reboot the computer and enter the Setup/BIOS to enable the ports. Otherwise they're physically disconnected in the case and you will need and expert to reconnect.
Mar 07, 2011 | Intel D845GVSR Motherboard
I have a logitech webcam. On MSN, others see me; but I don't see myself
Open your messenger, then go to tools, then click on audio / video setup, then click on next and go through the setup process.
Also ensure you plug your cam in the main usb port at the back o your computer, try to avoid using the front usb ports or added usb hubs as there needs to be a direct conection.
Feb 12, 2010 | Intel Easy PC Camera Webcam
I'm tryin to install the sierra wireless card 598 on win 98 manually. Does anyone know how to do
Hello sir, hi, installing a USB device on windows 98 is kinda hard but possible. here are some things that you should do:
  1. you may need the sierra CD device driver that comes with your wireless card.
  2. next is that your PC should support USB 1.1 or 2.0. If you are using windows 98, make sure that your USB port is working fine, you can insert a flash drive to confirm if your usb port is working.
  3. depending on the setup files they may need you to plug in the device as the setup file loads the driver or later.
  4. run the sierra CD setup file to install your wireless card. (hope win 98 supports this device)
  5. after the setup, plug in your wireless USB device, windows 98 should detect it.
If things didnt work out as listed above, do it setup several times, ............ still no progress call your dealer for proper installation on your PC.
Nov 09, 2009 | Sierra Wireless 598U USB Modem
How to setup 750 gb drive usb. two disks which one is first. no manual came with it
your question is bit confusing.. but if you have Winx Xp you need not setup anything. just plug in the USB cable & you will have the Drive showing in mycomputer
Jul 29, 2009 | Kanguru 3.5 QS2 SATA Ext HD 750GB 750 GB...
Reconnect front usb
Visit the manufecturer's website and find the users manual. Usually such informations are given in the users manuals. (ehteshamhusain@gmail.com)
Apr 27, 2009 | Computers & Internet
Usb not working
Check that all the USB ports are turned on in the BIOS setup.
Apr 02, 2009 | PC Chips (M925G) Motherboard
EliteGroup P4S5A/DX (ECSP4S5A) Motherboard Logo
119 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
