Question about Fuji FinePix S5000 Digital Camera
Camera will not power up
Batteries ok but camera will just not power up when switched on
  • bakobratt Apr 06, 2008
    i have one of these turned on a pop then a smell could it be that capacitor going short and the smell was that track is that a common problem.
    i will look and see this week and i will let you all know.
    jeff
  • gprcmedia Apr 07, 2008
    We have 8 of these cameras and 2 of them now have the same problem. We get power to turn on in playback mode, but no reaction when camera is turn to camera mode. Camera worked fine for 2 years.
Hi, I had the same problem. One fine day I tried to switch ON the camera but it will never turn ON. Batteries OK and condition of switch OK too. Being a technical person, with the help of some colleagues, I decided to open the camera, assuming that sending it for repair would cost too much. We found a blown smd capacitor marked 4710d. We replaced it with a 47uF capacitor and also a blown link just adjacent to the capacitor. The link resoldered and the camera is working fine now. I must say that even though very complicated, the way this camera is assembled makes it easier to handle.
Posted on May 22, 2007
  • 188 Answers
May be due to broken power on switch, a common problem with fuji s 7000
Posted on Aug 19, 2006
SOURCE:
Camera will not power on
Assuming that the battery is OK, there are two switches that if not operating the camera will not power on - one for the SD card door and one for the battery door. Both must be closed for the camera to power on. Also, the main switch is a micro switch. You can see the battery door switch with the door open. Carefully check to make sure the little arm is closing. Sometimes if the battery door is worn it will it not close enough to close the switch - try pushing up the battery door all the way and see if it then turns on. You would have to remove the back cover to check the on/off switch, and to replace it you have to replace the entire back cover assembly. The other common cause is one of the bottom board screws coming loose and shorting the board. Most of these problem require professional repair, but if it is the battery door you can usually find them on eBay.
Jul 07, 2014 | Canon EOS 60D Digital Camera
ok you have to check the bettery terminal and the power switch, maybe you have lost contact in your unit.
Oct 08, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
My sony handycam DCR-TRV340E is not charging at all, dont know if its to do with the battery or the AC power adaptor
First, check that the camera switch is in the off (charging) position.
If this is OK, Check the battery output connections for voltage: use a multimeter.
To check the charger, put a load resistor across the output terminals (about 1000 ti 2000 ohms) and again, using a multimeter, check there is a charging voltage. Alternatively, if the camera operates OK with the charger attached and switched on the charger is OK, AND, the problem is then in the charging circuit from camera to battery. If the battery checks OK as in the beginning, then you will need a Sony repair man who needs to know all the results from your testing above.
May 27, 2014 | Sony Handycam DCR-TRV340E Digital...
Not power off
I guess you can't switch the camera off when you are using it. But when you don't switch it off, the battery runs out.
After you charged the battery, what happened. Or next time, when it won't switch off, remove the battery, Then watch what happens after you reinstall the battery and try to switch it on.
If you can switch on the camera the switch is ok. If the camera starts immediately, after you inserted the battery, the switch is blocked. (makes full contact without you touching it). This is a real problem, and I think only can be repaired in the service centre. Please ask before what it will cost, because sometimes it is cheaper to buy a new camera.
Oct 31, 2013 | Samsung ST30 Digital Camera Pink
Fuji av 100 wont power up
Reset the camera by removing the battery for 15 mins, replace the battery. Switch on the camera and go into the camera's menu to set the Date & Time.
Mar 22, 2013 | Fuji Photography
Power switch not working
hello sir .. does your batteries are charged already??
if your batteries are fully charged and your camera didn`t turn on,
there`s a possibility that your camera has a problem. You can visit the store where you bought your camera and you can ask questions there why does your camera didn`t turn on whenever your batteries are ok .. :)
Feb 23, 2013 | Kodak EasyShare C142 Digital Camera
The camera will not turn on even though batteries are new.
Hi Kris - If the camera worked before changing the batteries, but now it doesn't; check the batteries for proper insertion. If just one battery was installed incorrectly, the camera will not power up. Also, check the charge of the batteries. If even a single dead battery was included in the mix of new batteries, the camera will not power up either.
If all these conditions check out ok, the problem may be related to defective hardware (power switch, lens, etc.). When the camera is powered on, it goes through a quick self test. If any of these self tests fail, the camera shuts off immediately. This will often require that the camera be evaluated professionally. Hopefully, you'll find the problem is battery related.
Nov 21, 2011 | Canon PowerShot S51S Digital Camera
Why won't camera switch on and red light flashing all the time i have bought a new battery but still won;t switch on and light still flashing many thanks
hi, what type of batterys have you brought as most normal batterys you buy wont even switch the camera on you need hi power batterys such as lithium or even better go into a camera shop and they will have special high power bats, normal bats wont even switch mine on so give different batts a try
let me know how you get on or if you need fyrther assistance ok
Nov 10, 2009 | Kodak EasyShare Z730 Digital Camera
Camera works but no LED display and power switch not working. battery has been tested and is ok.
First you, should give the model of the camera, which will help for better understanding the problem.
Aug 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
System error
ok try this pls take out the mem stick b4 going fwd
factory reset the camera
Home Screen>Settings>Main Settings1>Initialize press OK on Control Button and then OK select Initialize All Settings press OK
then pls turn off the camera and take out the battery then move power switch of camera to ON position for 1 minute
after 1 minute move power switch to OFF position and then put the battery back and see everrything is OK
pls let me know with the results
Rate me FIXYA if i fixed ur problem
Feb 06, 2009 | Sony Cybershot DSC-H3 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
111 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
