Question about Honeywell Programmable Thermostat Heater
How do i set the thermostat on my model rth2300b1012 Honeywell
Honeywell thermostat
Honeywell has made a huge number of thermostats over the years. Directions for each are specific to each model. Your model number will begin with the letters, T, TH, RTH, C, or CT and is on the back of the thermostat.
Once you have the model number, you can obtain the owner & programming information by supplying it on the Honeywell webpage, here.
If you are having trouble, either contact Honeywell directly - or repost here.
May 16, 2013 | Heating & Cooling
How to set the heat on the thermostat of my honeywell r h t 2300 d 1012
There is a Honeywell model RTH2300B1012, which is what I think you're talking about.
The Honeywell website has the owners manual for that model available online at:http://customer.honeywell.com/Honeywell/getliterature.axd?LiteratureID=69-2448ES.pdf
Feb 14, 2012 | Honeywell Heating & Cooling
Can you please explain how to set my thermostat
Go to myhome.honeywell.com and search for a manual for your model number thermostat on the right hand side of the page.
Oct 08, 2009 | Honeywell Programmable Thermostat Heater
Honeywell thermostat won't regulate temp properly
check to differential setting in the thermostat and are you saying the temp in the room and the set temp is being read from the thermostat or is there another thermometer in the room your looking at
Jun 25, 2009 | Honeywell Electronic Programmable...
Program manual for honeywell thermostat model T8700C1005(1)
go here: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/
Nov 13, 2008 | Honeywell Programmable Thermostat Heater
Problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
Go to www.honeywell.com and search their data base for your model of thermostat. You wil need all the numbers of your thermostat to be able to search. Once you find it, download the installation manual.
Good Luck.
Dec 03, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
941 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
