Question about Canon imageRUNNER C5800 Copier
Canon iR C3170 Error Code E000004-0001
Pls provide solution ASAP
spinal
  • 287 Answers
SOURCE: canon ir 5570 - error E000100-0001
Hello prntrfxr,
E000100-0001 is a secondary code to the initial problem. It means verbatum " The power has been turned off and back on again without resetting the error ". So, there was a previous error code that instructed the customer to turn off the main power and turn it back on in an effort to reset the code. Unfortunately this must have been an error code regarding the fusing system. Canon designed the copier to prompt the customer to power the copier off and back on for all error codes, and more often than not the copier can recover to some degree or another. Fuser codes on the other hand WILL NOT reset even though the display says to power off/on . You will need to go into service mode to reset the error. Press "additional functions"......then the numbers 2 and 8 at the same time and then additional functions again. If you have followed these steps properly you will now be in service mode and a different screen. Just follow these instructions. Press copier. Press functions.Press clear.Press err.Press ok. Power off and on . This WILL clear the code. However, if the problem still exists the code will return of course. THAT code is the one we need to troubleshoot! :-)
Posted on Apr 20, 2008
hquiteculo
  • 19 Answers
SOURCE: Error code E000025-00001
there is a toner feed motor over currente detection error, there is a toner botle motor connection detection error.
1- check the connector for any fault in connection.
2- replace the motor
Posted on Apr 09, 2009
  • 66 Answers
SOURCE: looking for a copy of a service manual for canon
You would be better off spending the money on a different machine than buying a manual. canon did not produce those machines for very long. they are horrible. we have 2 left in the field and i will be glad when those 2 are gone.
Posted on Apr 23, 2009
  • 82 Answers
SOURCE: my iR 5000 had an error code E000004-0000. solve
Contact a Canon Dealer/Authorized Service. It's either an error that needs to be reset or you have a hardware issue... with some errors, once you get it, it will never go away until you get a technician to clear it out.
Posted on Nov 29, 2009
  • 149 Answers
SOURCE: how to remove this error e000840-0001 in ir 6570
to be honest the fixing assembly needs to be rebuilt. the sutter inside the fixing assemble has becomes warped or has locked up and the gears on it could be worn or broken.. unfortunatly that is the only solution for the problem
Posted on Jun 09, 2010
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
My copier CANON-c3170 is not working due to Error- E000070-0001
Not a good code to have. Its a problem with the transfer belt home position sensor or maybe a broken tension arm. The disassembly involved to remove that belt assembly is brutal and the belt assembly is expensive also. Love the canon copiers but the c3100 and c3170 units are terrible machines. I would think twice about investing the money it will take to repair it.
Jul 23, 2012 | Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
I have Canon iR 2016 it show E808 code error
i have canon Ir2016 it give 808 error code can u help me please
May 29, 2010 | Canon iR 2016i Black and White Copier
Error code E000020 - 0081 in ir C3170 PCL5c
Apr 28, 2010 | Office Equipment & Supplies
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
E070-003
when i open the printer the unit will int.rot. and then the error will appear. tnx...From Canon Support Product : imageRUNNER C3100 / C3170 Title : E00351-0000 Problem
May 05, 2009 | Canon iRC3100 Printer
Canon imageRUNNER C5800 Copier Logo
261 people viewed this question
old marine
old marine
