Question about Electrical Supplies
Honda es3500 generator carb linkage diagram
5 Suggested Answers
  • 1388 Answers
SOURCE: I need a carb for
Good place for honda parts is http://www.jackssmallengines.com/index.html. I would try to repair the carb first using a kit containing gaskets and needle. enjoy
Posted on Nov 30, 2008
SOURCE: Ihave a honda ganerater MODEL#ES3500 and dont know were the battery goes.
The battery '+' attaches directly to the starter and the '-' cable is grounded to the frame/block.
Posted on Dec 11, 2008
darjr
  • 378 Answers
SOURCE: 220 volt outlet
you can find it in electrical store.
Posted on Jul 05, 2009
  • 37 Answers
SOURCE: CONTACT BREAKER GAP FOR HONDA ES3500 GENERATOR
Recommended spark plug is BPR5ES (NGK) W16EPR-U(Denso)
Spark plug gap is 0.7-0.8mm (.028-.031in.)
Air Gap for your ignition coil is .4+-,02 mm(0.016+-0.008in.)
Posted on Nov 22, 2009
What does the carb spring and linkage look like on a honda lawnmore motorhrr2i6sda look like
Go to Harbor Freight, look at the connections on the same Prededator motor, same as the Honda. Google the model number parts. Diagram will indicated spring placement.
Sep 11, 2014 | Honda Garden
Our Honda EB 3500 generator was serviced a month ago and now that we need it it won't work. The generator will start however it won't take a load. Do you have any recommendations or suggestions?...
It's either not getting enough fuel, or the govenor is not working. When the engine is running, watch the throttle linkage between the carburetor and engine, looks like a bent wire. When you throw a load on it, it should move to give the engine more power, if it dont, try moving it by hand.
If that appears to be working ok, check the fuel line from the tank to the carb for good gas flow.
You can also remove the float bowl on the bottom of the carb, it's a round bowl on the bottom of the carb with a bolt in the middle of it...clean it out and check the float. The float looks like a little catamaran, make sure it is moving freely up and down. That is about all you can do without removing and cleaning the jets in the carb.
Good luck, & i hope this helps.
Aug 27, 2011 | Honda Electrical Supplies
CONTACT BREAKER GAP FOR HONDA ES3500 GENERATOR SPARK PLUG GAP.
Nov 16, 2009 | Electrical Supplies
Briggs & stratton Modal No 490179 carburettor linkage
it sounds like the governer needs to be set and the carb needs to be cleaned out> I would get a carb rebuild kit and go to briggs online and look up how to set the gov dont run it till you do or you may blow the motor
Aug 31, 2009 | Briggs & Stratton Power Products 5,550...
220 volt outlet
Jul 05, 2009 | Electrical Supplies
1000 watt Yamaha generator surges when on low setting
YOU PROBABLY HAVE LINKAGE PROBLEMS ON THE CARB IS IT AUTO THROTTLE IF SO YOU MAY ONLY NEED TO ADJUST THE SETTING SCREWS GIVE ME SOME DETAILS LIKE BRAND HORSE POWER CARB BRAND AND MODEL AND I MAY HAVE THE EXACT ANSWER FOR YOU I HAVE ALOT OF SMALL ENGINE RESOURCES FOR SPECS AND DIAGRAMS
Jun 23, 2009 | RTO New Yamaha Inverter Ef2400is / Yamaha...
I need a carb for a es3500 honda
Nov 27, 2008 | Electrical Supplies
Nov 03, 2008 | Honda Electrical Supplies
Electrical Supplies Logo
80 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
