Question about HP LaserJet Office Equipment & Supplies
Download rfu file for hp 4650 printer
How to send through parallel port
5 Suggested Answers
SOURCE: Printer Froze and Have Download Message
Download file now RFU Load Error Resend RFU Over Parallel Port
Posted on Aug 16, 2008
SOURCE: Download file now RFU LOAD ERROR
Upgrading Printer Firmware
WILL SOLVE YOUR ISSUE
HP Jetdirect firmware images have an extension of *.dld while the printer
firmware images have an .rfu extension.Once imported into the repository, the files physically exist under the following location on the HP Web Jetadmin server:
C:\Documents and Settings\NetworkService\Local Settings\ApplicationData\Hewlett-Packard\HP Web Jetadmin\WjaService\config\FirmwareUpgrade
check the document from the hp
Posted on Jan 05, 2010
  • 48 Answers
SOURCE: Printer problem HP Color Laserjet 5550dn(download
This error is related to the firmware for the printer. You can get the firmware update utility from the hp website. The following is the site for XP. http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=406808&prodTypeId=18972&prodSeriesId=409994&swLang=8&taskId=135&swEnvOID=228
Posted on Sep 02, 2010
BaronVonNuke
  • 1915 Answers
SOURCE: I HAVE UPDATED FIRMWARE HP
See this tip
I wrote this tip for another model but the application is identical for this model.
Posted on May 17, 2011
HP laserjet p3005d frozen on "download file now send rfu upgrade"
Need further information as there are several ways this can go, some of which are fairly complicated. Does the screen state Download firmware over USB? or Resend over parallel port?
Post the exact message and I will see if I can find you the tech document that shows the steps needed, depending on what the screen says.
Jul 01, 2014 | HP LaserJet P3005n Printer
Rfu file download
You need to resend the firmware. If you have a parallel port on your printer you can do it from there, just follow the instructions that come with the RFU download.
If you only have network and USB then you will need to follow the instructions that I wrote for solving this problem on another model of HP.
You can find that tip here
Jul 21, 2011 | HP LaserJet 4650dn Printer
Downld file now SEND RFU UPGRADE ON USB DEV PORT
install printer Driver
change print port to "Virtual printer port for usb"
use usb line
down load the right firmware .rfu file
in CMD mode,type:
copy /b firmwarefilename.rfu \\pc name\printer name
waitting
it will be down
good luck!
Nov 26, 2010 | HP LaserJet 4345mfp Printer
Jan 05, 2010 | HP Office Equipment & Supplies
RFU load error
I have a printer HP Color Laser Jet 5550' i cont print when i on the perinter ther 59 er--co is come on printer screen and the printer can not work .waht sould i do it cont rest too plase
Feb 27, 2009 | HP LaserJet 5550 Printer
Need help installing the firmware for an HP LJ p3005n. I have the download, and the printer is locally connected *USB*
David,
As per the instructions from HP for windows systems:
If the device is shared on the network, then the following command can be issued from a command prompt: copy /b FILENAME \\SHARENAME\PRINTERNAME
where FILENAME is the name of the .RFU file,SHARENAME is the name of the machine, from which the printer is being shared, and PRINTERNAME is the printer's share name.
If the device is attached locally, then the .RFU file can be sent directly to the printer with a COPY command from a command prompt or DOS window:
copy /b FILENAME PORTNAME
where FILENAME is the name of the .RFU file and PORTNAME is the name of the appropriate device port (such as LPT1).
The following can be set on the computer to help address a timeout message that may occur during an update:
From a command prompt or DOS window type the following command and press the enter key:
Mode lpt1:,,p
If the device is attached to a parallel port other than LPT1, then substitute the proper LPT port number in the MODE command. Once this command has been set the file can then be copied to the printer with the above mentioned COPY command.
NOTE: When the upgrade process has completed the LaserJet will reboot. Once the printer is back online, print a Configuration Page and verify that the new firmware has been installed.
Chris
Alkaline Water
Dec 05, 2008 | HP LaserJet P3005n Printer
Downld File Now
RFU LOAD ERROR
RESEND RFU OVER
PARALLEL PORT
Aug 13, 2008 | HP LaserJet 5550 Printer
HP LaserJet 4250 Jet Direct Error
have you updated the firmware to the latest version?
Jun 04, 2008 | Computers & Internet
350 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
