Question about Sansui 32" TV
My Sansui 32 Inch LCD screen shuts off, after a minute. The power remains on - the screen just switches off.
I have switched the main power off and back on - the screen still remains off. After about half an hour I switch the TV back on it works for a minute and then the screen switches back off.
This may not work but i had a similar problem. My 32inch sansui LCD TV would switch off after about 10-20 minutes. I had to unplug it to get it going again. So i decided to open it as the warranty was long gone anyway. Very easy to open the back. I checked to see if anything was "swollen" as some sights suggested, but found nothing burnt , blown or swollen. Then i thought about heat? So i left in on without putting the metal backing plate back. It worked! when i put the plate back.....20 minutes and it shut down. So i just left the metal backing plate off! And no its not dangerous as the sansui has a protective plastic backing, that covers the metal one, that is better ventilated and protects the bits and pieces. Its been a week now and its fine.
Posted on Mar 06, 2012
2 Suggested Answers
gopakumarg43
  • 74136 Answers
SOURCE: the color on my 32
Hello
Either your Sansui TVs screen voltage has gone very low, or its brightness control section inside its chroma IC has damaged. To make sure which is faulty, you have to open your tv. There is an LOT [Line Output Transformer], which can be locted on the main board of your TV, from which three wires will go to the picture tube, out of which one will be connected directly to the picture tubes upper side, look like as it is sucked by a rubber ******. Usually this component is balck in colour and will have two adjustment controls integrated with it, marked as "screen and focus". After switch on your TV, just adjust the "Screen" control preset a little clockwise to see whether there is any advance in the bright ness of the picture. If the focus voltage is less or its wire connection to the picture tube base socket gets corroid; this type of fault may occur also. Check that also. If these does not help you, the chroma IC has damaged, and should be replaced with same type and number. OK.
Posted on Feb 24, 2011
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Hi, I have a Sansui SV-4210 LCD HDMI TV . It does not switch on with the remote and only works once I unplugged the power cable and plug it back again. Lately it occurs every time and I have to do th
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 20, 2014 | Sansui Televison & Video
My Sansui 32 inch LCD TV is not working
The main digital board stopped working. No SCL, SDA. Contact any service technician.
Jul 01, 2013 | Sansui HDLCD3250 32 in. LCD TV
I dont want to look at the No HDMI Cable Message after the computer shuts down. Is there a way to make the screen go blank more quickly. Or do I have to watch the message scroll across the screen for 10...
A couple of options. First and cheapest, you could turn off the monitor. Second, for about thirty to fifty dollars, you can pick up an energy saving surge protector. With this, it has a main plug, and switched plugs. The switched plugs cut power when the main item is turned off. I.E. PC turned off, monitor, speakers, printer all turn off a moment later.
Dec 11, 2011 | Dell ST2420L 24 inch LCD Monitor
The color on my 32 inch sansui flat screen is xray like dark.
Hello
Feb 24, 2011 | Sansui 32" TV
ComI have connected my laptop to Sansui 32 inch LCD through VGA cable but the i am not getting the notebook screen displayed on tv continuously. the screen gets displayed for a second and goes off, it is...
You may need to enable the notebook VGA output. They can switch between notebook only, notebook + VGA or VGA only. You usually press the "fn" key and one of the Function keys at the same time. On my laptop, I press "Fn" and "F5". Please note that it can take some seconds for the switching to be completed so press them together once and then wait 10 seconds to see if it does what you want. (remember it may be something other than F5, look for a picture of a monitor or a square symbol).
Feb 06, 2011 | Sansui HDLCD3210 32 in. LCD TV
Sansui LCT37SD switches off by itself
To anybody that has not been able to solve problems with the sansui lcd tv ,lines ,dots on screen etc after warming up ,pls contact me for the solution to the problem. i have succesfully repaired my lct 37st for next to nothing. garth@cybersmart.co.za
Apr 13, 2009 | Sansui HDLCD3210 32 in. LCD TV
Canon imageRUNNER C2058 color network printer board-B1 only. Upon power up the display screen indicates "Wait...".
The printer Board B1: you must shut it down by hitting the Options button and then selecting Function >Shut down > Shut down sytem>OK. Then power the machine off with the main switch. If the Customer has not been shutting off the machine properly and you get the please wait message you might try reloading system software first before replacing the hard drive.
Or = remove and reseat the printer board, if that doesn't work then you'll have to reformat the HDD unit and reload system software from a laptop. If the problem remains, the printer board may need to be replaced.
The Color Network Printer Board -B1 has a shut down function. It is for preventing corruption of the HDD. Be sure to turn off the main power switch after performing shutdown.
To properly shut down the Color Network Printer Board -B1:
1. Press the Option key on the control panel if the copier is in copier mode.
2. Make sure that the LCD reads Idle.
3. Select Functions on the LCD.
4. Select Shut Down from the Functions screen.
5. Select Shut Down System from the Shut Down screen.
6. The message 'It is now safe to power off the system' appears on the screen.
7. Power off the main power switch located on the lower right side of the copier.
* Note- After powering off the copier, wait at least five seconds before powering the copier back on.
Jan 25, 2009 | Canon imageRUNNER C2058 Led Printer
Westinghouse 32 inch screen goes blank
Westinghouse LTV-32w1
replace capacitor c162 on power supply
power supply was a delta electric dps210ep-2c rev01
reheat any solder joints that don't look 100% as well .
such as c310 .
this is a known working fix . try before you buy a supply .
Dec 25, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Sansui LCDTV 40 inch goes Off automatically
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 10, 2017 | Sansui HDLCD-3700 37 in. LCD Television
Sansui 32" TV Logo
97 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
