Question about Emerson EWC19T3 19 in. TV/VCR/DVD Combo
No picture The first problem that I had was that my DVD tray in my combo TV would not eject. I could tell that it was just a small mechanical problem (the motor had broken a gear off; a little glue fixed it, no problem) so I opened the TV up and fixed the DVD tray, no problem. To do so I had to take off a wire (red, 2-prong, going from the circuit board near the power cord up along the picture tube). When I plugged this wire back in and closed the TV up, I got power to the DVD/VCR (which work perfectly, as well as I can tell), but no picture. There isn't even the sound of the tube charging up or the typical noise you hear when you turn a TV on, and, obviously there's no picture. Is there something I could have touched or moved to screw up my TV? I was careful to stay away from the picture tube and other circuits I didn't need to mess with, but I don't understand why it wouldn't be working if there isn't something that is pretty sensitive that I might have accidentally hit or displaced when opening the case. Any ideas would be very helpful, thanks.
    President:
  • 3,130 Answers
You disconnected something else or it got pulled on by accident..
Posted on Aug 16, 2006
SOURCE:
Dvd stuck in dvd tv combo-RCA32LA30RQD tv
If you wish to get some details; visit the site linked here. Pull up older posts.
Sep 30, 2017 | Televison & Video
Will not eject a DVD. How can I get the DVD out?
All dvd units have a small hole in front panel that you can access. Straighten out a paper clip and stick in the small hole and push straight in - the tray will open and, voila, there is your disk!!!!!!!
Feb 15, 2016 | Sharp "LC-26DV27UT DVD LCD TV Combo"
Dvd is stuck in tv/dvd combo
here you can mess the unit up completely if your not carefull,,some of the many different types of system unit have a small hole on the door itself,carefully power on then push a straightened paperclip into this hole,,if you can find one that is,,your only other options would be to use a very flat knife and try to time pressure on the door in conjunction with the power on button the door itself is ,or can be operated by internal cog mechanisms which can break easily--good luck--Davey
Jun 18, 2012 | Haier HLC19R 19 in. LCD TV/DVD Combo
RCA L32WD26D TV/DVD/HD Combo - dvd wont eject
Hello
Check the loading motor and loading belt. If loading motor has damaged, or loding belt has broken or loose. the in-out tray mechanism won't work well.
Mar 03, 2012 | RCA L32WD26D HDTV/DVD Combo
Dvd player door is locked and we cannot eject the dvd?
Get a small paper clip.
There should be a little hole on the DVD tray bezel or possibly around the edge. If you put the paper clip into the hole and poke around, it will partially release the tray and you should be able to gently pull the tray open.
Oct 15, 2009 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
There is a DVD stuck in our TV combo that will not eject. Is there a way to force open the dvd without harming it?
If you can find a very small hole in the face of the DVD tray, then you may straighten out a paper clip or something similar that will fit in the hole and gently press it in to activate the manual eject for the tray.
Jul 15, 2009 | RCA Televison & Video
Failure opening the tray
do 1 thing,take a pin and insert it in the small hole below the tray
and then press the eject button
Jun 04, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Panasonic PV-D4743S combo DVD/VCR player won't eject DVD
This unit has seperate power supplies for the DVD and VCR side and the DVD side supply seems prone to failure. I have not isolated the cause, but can tell you this will require a component level repair. Unless you are a tech you may as well buy a new unit.
Sep 22, 2007 | Panasonic PV-DM2794 27 in. TV/VCR/DVD...
DVD tray will not eject
go to the any depanator and help to zero(.)settyng your dvd
Nov 28, 2006 | Emerson SB350 13 in. TV/DVD Combo
Emerson EWC19T3 19 in. TV/VCR/DVD Combo Logo
144 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
