My dad has a hp pavilion that worked fine this morning, but now when he turns it on, the monitor says "no vga input" and turns itself off. we have tried another monitor and the same thing happens.
  • lewisthebear Oct 25, 2008
    power supply is fine, as it lasts long enough to display the message, then puts the monitors into sleepmode. He left the pc running whilst he was out this morning, came back and this problem had occurred.
  • 141 Answers
Try another power supply.
Posted on Oct 25, 2008
  • Theresa  Smith
    Theresa Smith Oct 27, 2008
    If it is set to hibernate/standby I think you'll have to see if you can get into the bios. Usually "Delete"/"Del"/F10 etc. holding down key until you see the bios screen. Then look for "Load Default Settings" to see if it will skip over your current settings.
    But "no vga" should not show up for this reason. This means there is a problem with your video. Changing the monitor was 1 thing now look at your pc hardware; Video Card. You can get one almost anywhere that sells computers/parts. You open your case watching to see where your video cable connects to the back of you pc - then inside your case. That will be your video card. If you don't see anything like this it's ok, then you have only "onboard" video from the motherboard which does go bad! So you would seat your video card into the proper slot, pci etc. If your an average computer user, a 64 bit pci card will be fine. There about $20.00 compared to the next price up of around $60-$80.00. It's very easy to change out. I think this will be more helpful in solving your problem.
HP pavilion a6700y there is no VGA no input signal
Make sure that the connections are tight. and plugged into wall.
If this wont turn it on monitor may be bad. try different cable and/or monitor.
Jun 07, 2014 | HP Pavilion a450n PC Desktop
No vga input on working monitor
Turned on computer (Pavilion a1657c), HD light operates, Monitor has little window saying:
HDMI Input: No Input Signal
VGA Input: No Input Signal
Recommended Settings: 1920x1080 - 60hz
Changed from the monitor that came with it (HP f2105 digital ouyput) to my Samsung analog and same message comes on dark screen.
Hope It's resolve all Your Computer Problem,
Still having Problem Then follow Us For Computer Support
Mar 21, 2014 | HP Media Center m7657c home PC - RC640AAR...
I have a HP LP20265 monitor, and it seems have problem, with signal detection.
wow ,, why not test the monitor on any other PC or laptop.
see if its good or bad.?
this is the only way to find this, unless guessing works.
i got lost in your post.
try 2 machines
the post photos of what screen does bad, words never work for telling graphics./
Mar 08, 2017 | HP LP2065 Monitor
My hp pavilion slimline s3020n pc is on but cannot view on the screen it says on the monitor VGA: no input signal
Check the video cable connectors, remove the video connectors and reconnect them again.
Check the monitor input settings make sure the input is set to VGA and not to DVI.
Try a different monitor.
May 20, 2012 | HP Pavilion Slimline S3020N PC Desktop
I have a Samsung SensR470 laptop and i have linked up the VGA, audio, and power cables but the monitor is not showing anything. when i turn it on, it just goes into sleep mode or otherwise shows the...
its because you failed to read the Samsung manual on your PC
go there and read, it has HOT key , all laptops have a hot key
Fn key that turns on the external display VGA jack.
on rear of this SAMSUNG.
It means the PC, VGA jack is turned off.
bad cable
bad monitor.
The PC can also be bad VGA chips, or worse,.
your first failing here is not saying why you are using VGA jack
is the Laptop screen dead too> (my other shoe falls off)
dang that be nice to know , no?
or like we do run that VGA to a projector? for say doing power point presentations, (done many before retired)
RTM, the manual is free to read any time of day, 24/7
each PC maker uses there own rules here, its there call
there design and their rules.
my HP its, Fn+F4, (toggle:, internal, external ,both or auto)
but yours is Samsung, ask them. or learn to use google?
Jun 10, 2017 | HP w1907 LCD Monitor
Using a HP L1506 Monitor on a HP Pavilions a 867c computer and has worked, but now receiving "VGA input: no input signal" with window on monitor, followed by "Monitor going to Sleep" and it does. Worked...
First of all, boot your system without the monitor connected to it and when you feel that it's booted upto logon screen (or if you haven't assign password it'll directly logon to the desktop, power on the speaker to make sure you can know it's done) connect the monitor. If this isn't successful, please turn off the system and remove the cmos battery, leave it outside for few minutes and again reinstall it. Boot again normally. Still having the same problem? then let's try another method. Did you see the bios loading (black screen with white text during startup) when you power on the system? If so, press F8 several times while it is booting and select "Safe Mode" and restore your system to previous state. Do let me know if this isn't possible. Good luck Thanks for using FixYa.
Jun 10, 2010 | HP Pavilion F1703 17" LCD Monitor
Cpu says no input vga signal, then goes to sleep
The no input VGA signal just means that the monitor is not receiving anything from the graphic card on the tower. Is the card a digital (DVI) output card? You'll know by the connector, it's white and slightly wider than a standard VGA connector. If so, perhaps the monitor is set to the wrong input?
If that isn't the case, and the computer is using an on-board or built-in graphics controller, you could try resetting the system's CMOS settings by setting the clear-settings jumper on the system board, or simply remove the plug and CMOS battery for a few minutes. Check the computer's documentation on the exact steps to do this.
Hope this helps!
May 19, 2009 | HP GX613AA Pavilion A6300F Desktop PC
Monitor in sleep mode
This problem could be caused by windows or the monitor .You need to hook up your monitor to another computer and see if you get the same response. If you do check and see in the owners manual if there is a control for power management.Find the control and try to adjust it, or turn it off. If all this does not work than you need to take the monitor in for servicing. If the monitor works,you may have a problem with the computer bios or windows itself. Check all power management controls in the bios and window settings and see if you can find the problem.Check the Microsoft website for this problem with your operating system and a solution. Hope this helps.
Apr 08, 2009 | HP w1907 LCD Monitor
HP F1903 turns itself off when connecting DVI
Sounds like your problem is hardware and lies with the port on your PC, this may be due to a bad driver, or bad port! Sounds like you have tried everything else!
Oct 03, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
