Question about Lakewood Heating & Cooling
Wiring diagram lakewood 792/jr heater - Lakewood Heating & Cooling
4 Suggested Answers
SOURCE: Lakewood 792/JR heater running w/o heat
Hi Spybotics. I have the same problem and I traced mine down to a burned out over-heat fuse link. Check out my recent post. My guess is that you are having the same problem as me. It's not hard to tell - just take off the rear panel and test the link (looks like a small resistor in line with the element) with an ohm meter. Open circuit means burned out fuse link. DO NOT bypass the link, as an extreme fire hazard will exist without it.
Posted on Apr 22, 2007
SOURCE: lakewood heater 792 will not work
The bottom switch is bad. Unplug bottom wires and touch them together, if heat and fan comes on your switch is bad.
Posted on Oct 01, 2010
SOURCE: Where can I get a replacement thermostat for a
I found one at this place, but is half or more price than the whole heater with shipping.
http://www.allpartsinc.com/productdesc.aspx?code=104458-01
part #
104458-01 - THERMOSTAT, BI-METAL 2 WIRE
Posted on Oct 25, 2011
The switch 750/1500 watt doesn't work
Replace it with any rated double throw double pole switch. Continuity check the switch first, to be sure it's the switch that's the problem.
Dec 11, 2013 | Lakewood 792/JR Utility Heater
Lakewood Model 792/A My heater has stopped working. The light indicates that it is receiving power. I checked the tip switch to see if stuck open. OK Next step please? Jeff
Separate the case and trace out the wiring you are looking for an over heat limit switch. These are usually at the top of the case. You should also go over the element with a volt ohm meter make sure it is good, once you locate the thermal overload check it with the volt ohm meter it should read closed or dead short. If it reads open here is your culprit. It has been my observation that replacement parts can generally cost as much as replacing the entire heater. These I can pick up all day long for $19.00 at Home Depot the call them milk house heaters. Good luck with the repair.
Dec 28, 2010 | Lakewood 792/JR Utility Heater
Where can I get a replacement thermostat for a Lakewood 792/JR space heater?
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Nov 06, 2010 | Lakewood 792/JR Utility Heater
Unit stays running can not turn down themostat
You will need to contact the dealer for that. Of course, if you still have the reciept, then i recommend taking it back to the store.
What to do if my lakewood 729 jr utility heater wont come on it on ly glows
sounds like your fan is not turning you may need to unplug and try to move the fan motor by hand this may take a few tools to open the unit and see if its stuck if it is try sprayin the motor shaft with wd if ti turns by hand
Apr 09, 2010 | Lakewood 792/JR Utility Heater
Lakewood heater 792 will not work
Feb 11, 2010 | Lakewood 792/JR Utility Heater
Lakewood heater 792/AA Fan works and pushes warm air, but element/coils never heat up where heater actually gets hot.
sounds like a broken element or wire. with unit unplugged, using an ohm meter check all connections and check elements for resistance.
Jan 13, 2010 | Lakewood 792/c Utility Heater
LAKEWOOD HEATER DOESENT HEAT UP
take it apart they should be aglass fuse inside
Dec 24, 2009 | Lakewood 792/JR Utility Heater
Apr 14, 2007 | Lakewood 792/JR Utility Heater
Heating & Cooling Logo
65 people viewed this question
Top Lakewood Heating & Cooling Experts
Mack Baxter
paulcarew
jdthefixer
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
