Question about Maxtor OneTouch A01B080 80 GB Hard Drive
Maxtor 80GB external drive
Tried to use this device this morning--and the blue light on the end of the unit blinks--and does not go on solid--as normal. I can't hear the drive spinning--does it have a power supply in it that can be repaired. I have lots of data on it that I don't want to lose---my laptop doesn't recognize it when plugged in and in Windows Explorer???
Mark
ImWireless
  • 113 Answers
SOURCE: maxtor external hard drive is not accessable
- Do you hear any beep sound when you plug in the USB drive into the laptop? - You can also try a different USB cable - Try connecting the hard drive to a different computer and see if it works All those steps will help you determine where the issue is. Please revert back with any other observations. Good Luck
Posted on Mar 30, 2007
Paul319581
  • 101 Answers
SOURCE: Maxtor External HD - The device cannot start. (Code 10)
ok do 1 think plug it on another 1 pc or lap to make sure that its workin...
if the same msg comes then ur HDD is gone ull have to replace it...with new...(if it dont have warrenty)
Posted on Mar 09, 2008
worldvet
  • 859 Answers
SOURCE: Computer does not recognize Maxtor OneTouch
Sounds like you need to remove the cable, uninstall the software, Restart, and then shut down. Now, from a cold power off power on. I know this seems tedious, but it has to do with the Last Known Good Recovery File and what is in Device Manger.
Now reinstall the software and if the software should call for you to "now" connect the USB cable, do so only when prompted or when the installer is done. Re: the latter, attach the cable. Windows ill say it discovered new hardware, point windows to your CD drive where the installer disk is located and allow Windows to locate the software.
Shut down and restart and your drive should be recognized now when you have a desktop. If not, post this back using the comment box below.
When replying to mine or anyone else's reply please address us in your reply, such as Worldvet: that doesn't make sense, please explain. And so on and so forth. This allow US to track what you've tried and from whom you were provided the solution.
Thank you for you indulgence on this. And, please be aware that, we all here want to see you fixed up and on your way. We all have a pretty good track record. However, there are times when a repair from a warranty service center is the only solution. However, I'm certain we all can get you taken care of and thanks for using Fix Ya.
Regards,
Worldvet
Posted on Aug 06, 2008
  • 300 Answers
SOURCE: Maxtor 80GB External HD
1. I need to know the brand name , model number , or motherboard you have
2. I need to know what operating system you are using
and when you say open , in what manor do you mean open , in what way are you attempting to open the drive and with what program , so far it looks like you may need to reinstall the computers operating system from scratch , because something is dead wrong , and it looks like a file system error , as if your computer operating system is no longer able to access files properly.
I consider your situation unresolved at this time untill you can give me more information.
I'm trying to reach guru status here in order to help people like you in a far more proper manor.
together we can solve it.
shalom
Posted on Sep 11, 2008
Benimur
  • 6966 Answers
SOURCE: Light turns on but My Computer does not recognize the drive
Hi and welcome to FixYa,
Offhand, your described concern unfortunately is a hardware failure. To be more specific, the hard disk (HD) inside the Maxtor OneTouch Mini III.
The Maxtor OneTouch Mini III is basically an enclosure to house the HD and the electronics interface. As you have tried, the interface is recognized but the HD is not and therefore files could not be transferred to or from it either from any PC or the Hitch.
Considering your location, limitations and requirements of transferring files (as well as keeping in mind possibility of recovering the contents of the HD), suggested course of action :
  • open the Maxtor OneTouch Mini III (but warranty would be void);
  • extract the faulty HD and note down the specs;
  • purchase locally a laptop HD that would fit and match (capacity could be bigger);
  • physically install the new HD inside the Maxtor OneTouch Mini III;
  • keep the old HD in a safe place;
  • verify that it works. In some instances, it may be necessary to format the new HD.
or
purchase locally a no name enclosure/interface and appropriate HD and make your own.
or
purchase locally some other form of external/USB storage media such as a large capacity flashdrive, additional memory cards for the camera.
or
every so often, upload your files, pictures to an online temporary storage such as RapidShare.
Good luck and thank you for using FixYa.
Posted on Apr 11, 2009
Hi, I have a WD external HD (my book essential) that doesnt seems to be read by any of the pcs I've tried to plug it on. It doesnt make a sound or even blinks that blues light. I tried to change...
This unit requires separate AC power. If the blue light is not on to begin with - indicating power, no PC will be able to read the USB. There is a hard disc in the unit that needs to spin...it is not solid state like a thumb drive.
Jun 13, 2011 | Western Digital My Book Essential...
For no reason whatsoever, my Maxtor external drive stopped appearing in My Computer. I've tried on three different computers, but each one only gets me the following message: "Error 10, The device...
yep --the disc is spinning , the lights are on BUT the pickup arm that reads the disc is not working
Time to consider a new unit preferably a solid state unit that has no moving parts to wear out
Jul 21, 2017 | Maxtor Personal Storage 3200 (U01E200) 200...
My Maxtor one touch has stopped being picked up by my computer when plugged in. When power source is plugged in led light (white) just blinks and never turns solid
You said it has stopped being picked up when plugged in so I hope this is note is relevantbut I don't think it is abnormal for it just to blink.
If the OneTouch does not appear in My Computer or cannot befound by Maxtor Manager, right click on My Computer icon and select Properties,Device Manager, Disc drives, and expand Disc Drives.
There may be ayellow overlay over Maxtor drive, to show it has a problem, so right click onit and select 'Choose drivers for this device' to reinstall them.
Without goingonline they seem to be found and reinstalled from somewhere locally on the PC and I hope this willdo the trick.
Also in case this helps, I don't find the OneTouch (Maxtor Manager) software appears when the driveis plugged in, so I think this is normal too.
You should look for an icon (a capital M within a blue disc) for Maxtor Managerin the taskbar, at the bottom right of the PC's screen.
Right clicking on this icon, (capital M), should bring up awindow with Maxtor Manager at the top.
Then click on the text 'Maxtor Manager' to open the program's window.
Hope this is what you wanted.
Dec 28, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Orange light
What is your operating system? Have you tried to force install this hardware? I need to know this before I can begin to troubleshoot.
Ryan Frame
Creative Energy Associates Technical Center
Aug 23, 2009 | Maxtor Personal Storage 3100 (M01E100) 100...
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor one Touch 300GB no steady green light
The USB Isn,t supplying/providing enough Power to the device.
Search e-bay or similar for a 2 into 1 USB Cable.
Then power the unit with 2 USB Ports on the Computer.
2 x USB Into 2 x Sockets On P.C. 1 x Into Device Drive.
This will be enough power to operate the Device Correctly.
I,ve done this on several external Drives, never failed for Me.
Mike @ compurepair.
Mar 16, 2008 | Maxtor OneTouch II external hard drive...
Maxtor OneTouch III 500gb
One hard drive failure mode is a power circuit short. Contact MAXTOR support on their web site for a possible warranty replacement. BTW, SEAGATE owns MAXTOR now.
Feb 24, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor OneTouch A01B080 80 GB Hard Drive Logo
121 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
