How to connect a turntable to htr-5540 yamaha
There is no input on the yamaha htr5540.Where sould i connect it to work
cancerags
  • 36 Answers
SOURCE: Connecting a Yamaha VX7 Subwoofer on my Yamaha HTR 5730 AV Receiver
Hello srqwrk,
You can connect the VX7 to the 5730 using an RCA Y cable like the one shown in the picture below. You get your one connection for the receiver and 2 for the VX7. These are available at any electronics store. Remember that the cable should be long enough to go from the receiver to where subwoofer will be placed.
Hope this helps. Let me know.
cancerags
Posted on Jan 01, 2008
HDTV GURU
  • 261 Answers
SOURCE: Yamaha - 5650/HTR-5640
Did you try going thru the setup portion of the owners manual? IF you need the manual you can get it online free. I realize sometimes people read the manuals and don't understand the technical jargon. Let me know if you need further assistance thur chat session and i can possibly step you thru it better in real time. Good luck Guru Jay
Posted on Feb 02, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
mrwtech
  • 59 Answers
SOURCE: Hooking up Turntable to Yahama HTR-5660
If Yamaha says that you need a phono pre-amp, you need it. it does not have to be a Yamaha pre-amp. just a generic pre-amp will fill the bill. Radio Shack or many places online have very reasonable(costwise) preamps.
Posted on Nov 29, 2008
  • 121 Answers
SOURCE: Yamaha HTR 5760 Video Problem with Wii
You need to connect a composite cable from the receiver. The receiver does not carry a composite signal over component cables.
Posted on Feb 27, 2009
How to connect a turntable connected to a yamaha a450 stereo amplifier...can I attache the a450 to the htr-6130 ?
If the turntable is newer kind you can connect it in any Stereo input like CD, VCR , etc.
If the turntable is older model you can only connect it to PHONO input (if amp has one) and make sure earthing cable is connected on Amp
Remember input is only stereo (unless your model has digital input) and select sound effect eg Pro Logic for enhanced sound,
Aug 26, 2014 | Yamaha HTR-6130 Receiver
How do I connect a usb turntable to a Yamaha HTR 6230? Sony turntable PS-LX300USB preamp switch set to 'line'
hi,
Select the switch to line. Then connect the red and white RCA pins to the corresponding red and white sockets of MD/CD-R play input of Yamaha. Select the MD/CD-R by pressing the button on the remote. Then play the turntable.
OK
Oct 15, 2011 | Sony PS-LX300USB Turntable
How do I connect a Akai AP207 turntable to my Yamaha HTR 5630 receiver???
If you want to connect the turntable all you do is get an audio cable white and red on the end. Then hook one end to the back of the reciever and the other end to the same connectors on the turntable. Make sure its output on the turntable and input on the reciever. Good luck...
Mar 29, 2011 | Yamaha HTR-5630 Receiver
When using tuner both speakers work but when using turntable one speaker is very low?
ONLY one channel low with a turntable?
Are you using a self-preamlified TT or an outboard phono preamp, because the HTR has no facility for direct attachment of an old-school TT.
It could be a turntable problem if you have phono preamplification most likely. Swap the two channels to prove it or not.
Try another input.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Mar 11, 2011 | Yamaha HTR-5730 Receiver
Can I connect my ipod to my yamaha htr 5540 via some kind of cable?
Yes - just go to electronics store and buy a 3.5 to 2 RCA lead and plug the 3.5 plug into your IPOD and the RCA plugs into the Aux sockets on your Yamaha. Job done
Mar 19, 2010 | Yamaha HTR-5540 Receiver
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Yamaha htr5540--can I hook up a turntable to this unit. No phono outlet
as long as you have an aux in labeld you can hook up whatever you want to it. should just be red and white rca cabels good luck.
Feb 25, 2010 | Yamaha HTR-5840 Receiver
Factory settings
I only found this on the manual
if the power is cut for more
than one week, the parameter value you edited will
return to the factory setting."
May 13, 2009 | Yamaha HTR-5540 Receiver
Turntable
turntables require a special input... I'd check crutchfield to see if there is something they might have to make it work better...
Jan 23, 2009 | Yamaha HTR-5860 Receiver
 Grubhead
Grubhead
