Question about Kenmore HE2 Plus Front Load Washer
How do i remove lower front panel on Kenmore HE2 washer?
SOURCE: Removal of front cabinet panel of washer section
Should be two screws on each side of the bottom of the front panel. Takes those out and push the panel up and out. (There are two "tabs?" in the middle of the front panel that lock into the side panels, so you have to push up and then pull out.)
Posted on Jan 15, 2009
SOURCE: I need the repair manual for the Kenmore HE2 Plus washer
The model number for the Kenmore HE2t front load washing machine is 11047571600. If you go to the Sears site for manuals and enter than number you can get the manual on line.
Hope that helps.
Posted on Jul 04, 2009
  • 5 Answers
SOURCE: Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
Posted on Oct 10, 2009
  • 5 Answers
manual for the HE2 and Duet Sport here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
(give it time to download, big file)
Posted on Nov 06, 2009
  • 6 Answers
SOURCE: My Kenmore HE2 Plus Front Load Washer won't drain?
remove front panel at bottom, get a bucket & clean pump out
Posted on Nov 10, 2009
I have a 5d fault code on my HE 2plus kenmore washer.
  1. Remove the lower front panel and remove the cover for the drainage filter. Slide this tray out and clean it.
  2. Unplug the washer for at least 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit.
  3. If the above procedures do not correct the problem, it is recommended to replace the drain pump.
Feb 27, 2011 | Kenmore HE2 Plus Front Load Washer
How do i remove the he2 plus lower panel to clean the filter
Their are three small screws at the bottom of the panel (FLOOR LEVEL) once these are removed you can pull out on the bottom of the panel to remove..Then you can place a shallow pan under the drain pump then remove the cap and strainer to clean......
Nov 16, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore fHE 2 plus front load washer does not drain and does not complete the spin and drain cycle. Error code f-21.
Means the drain is too long. Under the front lower panel is a sump filter. Remove the filter by turning ccw and clean.
Nov 04, 2010 | Kenmore HE2 Plus Front Load Washer
Where is the pump/filter located on my Kenmore Front Loader Washe
It is just behind the lower panel. Remove the 3 screws from the lower panel (the panel just below the door), the screws are on the lip on the bottom of the panel facing the front of the machine. Pull down and toward you to get the panel off. The filter and clean out are in the center. Unscrew the cap to remove and clean out, but have lots of towels ready, there will be water coming out.
Apr 20, 2010 | Kenmore HE2 Plus Front Load Washer
Where do i find the filters on a front load kenmore he2 i believe the filter is clogged with dog hair but i do not know where to find them and i cant find my manual the washer will wash but not drain all...
Front lower panel should have three bolts near the floor. Remove those and panel should slide down. There you will find a plug. once you unscrew it water will pour out, be ready.
Feb 11, 2010 | Kenmore HE2 Plus Front Load Washer
Something loose between the drums
how did the underwire get there, you may want to remove lower panel please unplug washer before removing panel use a flash light there is a area were coins and other objects fall in to also have a bucket there well be water in the lower unit use something to fish it out lucky it did not get caught in pump
Nov 25, 2009 | Kenmore HE2 Plus Front Load Washer
HE2 Plus blinks F-11
Look for the technical brochure. Mine was on the lower kick panel taped inside. I would not take off the back panel first. Maybe the top or the lower front if it is a front loader. It tells you how to do diagnostics and what the codes mean.
Jul 22, 2009 | Kenmore HE2 Plus Front Load Washer
How do I remove the cabinet from mt Kenmore front load washer. It is leaking during the wash cycle.
Screws along the bottom of the front lower panel. This will get access to find the leak. If it is up high the top comes off with 3 screws at the back top edge and slide forward.
Eric
Jun 26, 2009 | Kenmore HE2 Plus Front Load Washer
Lint trap
First you need to remove three screws on the front lower panel. This will expose a round "plug" to your right. This is the lint/drain trap. Place a bucket under the plug. Slowly unscrew this plug and aloow the water to drop into the bucket. Make sure your plug is clean and reset it.
Jun 10, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
115 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
