Question about Honeywell Programmable Thermostat Heater
What is the em. heat setting - Honeywell Programmable Thermostat Heater
    Sergeant:
  • 359 Answers
Emg heat refers to the back up heat of the heat pump could be electric , gas . oil , should only be used if the heat pump malfunctions or might come on to support the hp in it is unable to reach temp on its on in the heating cycle.
Posted on Oct 26, 2008
When em heat is on my outside unit runs but when not on em heat it doesn't. Which setting is best to use?
Has this always been this way? When the emergency heat is on the outside unit shouldn't run. When in normal heat, no emergency heat, the outside unit should be running unless the temperature is below the balance point ( usually around 35 degrees). If this has always been this way and the outside temperature is above 40 degrees you might have your 1st stage and 2nd stage wires switched.
Nov 27, 2016 | Heating & Cooling
Honeywell troubleshooting
Emergency heat is the setting that shows that your heat strips are activated. Sometimes people do not wire up the heat strips at all as the use a great deal more power than the normal heat pump uses. The problem is that a heat pump comes to a point where it is not efficient at about 28 degrees and this is where you need the heat strips or if you want to heat the house quickly which a heat pump will not do. Heat strips are located in the ductwork and act like a space heater. A H/A tech is probably needed to check this stuff out for you.
Nov 15, 2013 | Cars & Trucks
When should em. heat be used on a thermmostat setting?
anytime your below the workable temp of your heat pump, so say your heat pump is putting out 70 degree air at the vent its time to switch. no sence in over working your heat pump
Jan 04, 2011 | Honeywell Programmable Thermostat Heater
How to preheat my new microwave model EM-C5796V of sanyo
you really don't pre-heat a microwave. set it for the time you want to cook and it reaches the temperature for cooking almost instantly
Sep 27, 2010 | Sanyo EM-Z2100GS Microwave Oven
Heat pump runs in em heat when outside temperature is low
Yes, you may turn to em heat only. May this confirmation help you.
Jan 06, 2010 | Heating & Cooling
The transformer on my central AC/heater (luxaire model # A236A344T LH) keeps going out. There are 4 settings on the wall. Cool, off, heat and EM. Heat. The setting switches to EM. Heat each time the...
You might have some thermostat wires that are touching meaning the insulation has been broke off and getting a direct short. Check the wiring going to the outside unit and replace any wire that is in bad shape. let me know okay. Ken
Dec 11, 2009 | Honeywell Programmable Thermostat Heater
What proplem may Iface in the desert?
I am assuming both are air cooled. On that note over heating could be an issue, just b sure to have a shaddy spot to set them when not in use, and the next BIGGY is clogging your air filters. If your out tooling arround without one on em, get em and if you got em buy spares
Dec 07, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Having trouble removing u- joints from drive shaft there are no snap rings it appears to have set pins or some thing holding them in is there a special trick to removing them ?
There glued in you need to heat em up to remove em, or stick em in a vise and beat the h*** out of em. Its easier to heat em up but don't get crazy it don't take much
Nov 08, 2009 | 1997 Chevrolet S-10 Pickup
Abbreviation definitions.
Economy Mode = EM
Auxelary Mode = AUX
in em mode heat pump does most of the work in aux either an electric heating element is used or gas depending on if it is gas or all electric
Oct 16, 2009 | Ruud Central System Air Conditioner
Heating & Cooling Logo
3,787 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
