Question about Carrier IBM UNIT 2380 79F4796 Drive Case
Carrier RADCO unit FA4ANF030
Is it ok to clean the lower part of th A.C. unit where the air first passes through with a toothbrush to get it all cleand out?
The best thing to use is any alkaline base with water
Posted on Aug 27, 2007
What's your question?my Noah sr50 engine doesn't run smoothly on start up when accelerating and also jerks whilst in motion
Hi if it was running ok untill now,check air filter is clean,check sparkplug ok,also sometimes the exurst gets bunged up and needs the inside cleand.
all the best.
Apr 18, 2015 | Cars & Trucks
Samsung factory reset
inspect the data socket for liquid damage seen as green mold, white calcium residue. If present, clean using toothbrush or q tip moistened in tap water, dry afterwards with compressed air or a hair dryer.
Dec 22, 2013 | Cell Phones
Dripping water from portable aie condtioner
Remove the rear cover and clean the unit throroughly. Use a can of air duster with the little hose to carefully clean the drain holes in the drip tray under the evaporator (upper radiator) let the unit fully defrost, drain the unit from the bottom plug. Clean the fins wth a toothbrush and windex if needed. Reassemble and run the unit in fan mode for an hour to let it dry out.
Jul 08, 2012 | Windchaser PAC9 Air Conditioner
Unit is leaking water from somewhere
Upper drip pan drains clogged, water overflowing onto the floor.
Remove the rear cover of the unit and clean it thoroughly wit a vacuum. Let the unit fully defrost. Use a can of Air duster (for pc's) with the little hose on to clear the drain holes in the upper drip tray. Clean dirty evaporator fins with windex and toothbrush, flush with water. Excess condensate should now drain into the bottom tank instead of overflowing ontot he ground. Be sure to drain the bottom tank thoroughly. With the unit cleaned it should now vent condensate out the warm air duct rather than letting it build up in the unit.
Jul 06, 2012 | Windchaser PAC9 Air Conditioner
What is the recommended way to clean your plasma screen?
Use a lint free cloth, there are cleaning kits available specifically for this. Phillips is one brand, Monster is another. Solution and cloth typically in the same package.
Aug 21, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
UNIT WILL NOT COOL. FAN AND HUMIDIFIER WORK. THIS IS ONLY THE SECOND SEASON USED AND THE UNIT HAS NEVER BEEN SITTING UP AND NEVER LAID DOWN OR TURNED UP SIDE DOWN. WHAT IS THE PROBLEM?
A portable air conditioner may not cool for several reasons. Check the filter by removing the unit's grill and clean the filter.
Also check for clogs in the evaporator or condenser coils by light vacuuming. Make sure the evaporator isn't frosted over, but if it is, allow it to defrost and normal operation should resume.
Lastly, ensure the ambient temperature is lower than your AC's set temperature, as this can prevent cooling. However, if all of these steps fail to resolve your problem, the compressor may be malfunctioning, and in this case, the compressor needs to be replaced or repaired.
In summary, if the air won't cool, remove the grill and clean the filter. Clean out any clogs in the evaporator or condenser coils by vacuuming them and scrubbing them lightly with an old toothbrush. And since fan is working, you compressor might be defective.
I hope the above information is clear.
Regards.
Jun 24, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
My cs510 18 inch bar echo chainsaw wont work its got compression and ignition but no gas already checked the filter and cleand out the gas tank...stuck
Does the primer bulb fill with fuel when pumped several times? If not check the primer bulb for cracks or holes and the fuel lines (including the one in the tank) for any decay or other damage. If all looks ok, remove the carburetor and do a thorough cleaning inside and out. Inspect the the lower chamber diaphragm for hardness, or cracking. Also inspect the small needle valve that the diaphragm controls for a damaged tip or gunk accumulation. There is also a small screen which may be plugged that passes fuel from the upper chamber down to the lower chamber through the needle valve. Finally, inspect the impulse passage that runs from the cylinder, up to the rear of the carburetor through gaskets, and a heat isolator block. Go to: www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting, which applies in general to other brands as well. Hope this helps!
Oct 23, 2010 | Echo Garden
My wall unit cozy heater goes on when I turn on the thermostalt but it goes out one minute later. What is the cause?
by pass the wall stat, pull the 2 wires off stat and twist together and if unit runs ok it is the stat if it does the same thing by pass the stat wire by disconnecting the stat wires from the valve a put a jumper wire between the (th) terminals.
Oct 10, 2010 | Cozy (W352E) Heater
Wont print black ink all outher colors ok cleand
If you did put in a new printhead, it means you need a new purge, or cleaning assembly. If it doesn't clean and prime the printhead properly, it won't print.
Dec 04, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Computers & Internet Logo
874 people viewed this question
Top Carrier Computers & Internet Experts
Martin Murray
Paul Carew
Are you a Carrier Computer and Internet Expert? Answer questions, earn points and help others
