Panasonic split inverter cs-e12ckp condensor, error code f90!
  • 306 Answers
SOURCE: Have a near new panasonic
Sounds like some how the fan wiring got on the line side of the magnetic contactor. Unless the contactor is still engaged in that case the compressor would be on also. When I say line side I am talking about where the power comes into the unit from the house and connects to the contactor. If it is within a year old maybe two the installer should stand behind the installation of unit. Contact them and explain the problem. Let me know how it turned out. Ken
Posted on Nov 30, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: How do I change the battery in the remote control
slide the cover of the remote up higher. It is hiding the batteries.
Posted on Nov 26, 2009
hvac1960
  • 2133 Answers
SOURCE: panasonic inverter model no CS-E21HKR
In remote/thermostat there is option " FAN " press for low/med/high. Plz refer if any fault code is there.
Posted on Dec 10, 2010
SOURCE: Panasonic Inverter CS-E12EKU timer indicator blink.
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Posted on Dec 11, 2010
hvac1960
  • 2133 Answers
SOURCE: WHAT IS ERROR CODE F96 ON A PANASONIC INVERTER AIR
F-96. Over heating protection. to solve it-------Check for • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor)
Posted on Jan 03, 2011
Panasonic mini split air conditioner css9nkua error code h99 what does it mean
12.11 Freeze Prevention Control 2
• Control start conditions
o During Cooling operation and soft dry operation ? During thermo OFF condition, indoor intake temperature is less than 50°F or ? Compressor stops for freeze prevention control
o Either one of the conditions above occurs 5 times in 60 minutes. • Control contents
o Operation stops
o Timer LED blinks and "H99" indicated
You may need the assistance of a technician. Service manual located here:
http://www.mcaair.com/docs/panasonicac/CS9NKUA%20CS12NKUA%20Service%20Manual.pdf
Apr 29, 2015 | Panasonic CS-S9NKUA Ductless Mini Split...
Timer blinking.outdoor unit does not functioning. what was the error?
Looks like you said it, the outdoor unit is not working. Check for power to the outdoor unit or try cutting power to it, then after a minute restore power in attempt to reset it.
Apr 28, 2015 | Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall...
E4 error on screen
Check out door unit. May be weak in Running capacitor/Fan motor capacitor/Condensor coil dust blocked. First clean and run, if still problem check speed of fan motor, if less replace fan-capacitor.
May 07, 2014 | Midea 24,000 Btu 17 SEER Inverter Mini...
Panasonic a/c
F90 = PFC control
Abnormality judgement: 4 times occurrence within 10 minutes
Location to verify: Voltage at PFC
Jan 26, 2014 | Heating & Cooling
Error message F90 on Panasonic Air Conditioner R401A
F90 - various defects of the compressor windings, defect in the inverter board Panasonic
Nov 09, 2013 | Heating & Cooling
Panasonic ac unit keeps coming up with a fault.... the error code is F90 air con is 5kw
dont no the code but if you call pana and tell them the code they should no what it is. not always usefull as they can give a general response but worth a try. then post the answer.
Jan 20, 2013 | Panasonic Heating & Cooling
Panasonic heat pump timer light flashes
check if it is poor contact .or current is too small.
wall light
May 20, 2012 | Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall...
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
Split system not starting up for about 10 mins after turning on
Hi Wendy,
The manual for the unit is at this link. This should answer all your questions. http://panasonic.com.au/products/details.cfm?objectID=4601 then go to the bottom of the page and click on CS/CU-E18_21_24_28HKR Operation Manual
I take the time to answer you questions so please rate me
Thankyou
Mat
Jun 10, 2009 | Panasonic MCM INVERTER
I've got a pana inverter CS-E24FKR, and the timer icon is blinking. I have not set a timer and i can not get the unit to respond. I tried holding the "check" button down for 5 seconds, then...
I had the same problem with a Panasonic Inverter mini split model cs-e12eku and i had to turn it off using the main power breaker switch. ( I could never get the darn error code.) I left it off for a couple of minutes and it seems to reset. My uncle is in the ac business and he has heard from other ac techs that the Panasonic ac's are problematic, sounds like it might be true...I suspect that the time, my unit worked perfectly for from 11/06 to June 08 and living in the tropics I used it every day I havent called Panasonic but it sounds like a faulty circuit board.
Jun 03, 2008 | Heating & Cooling
Heating & Cooling Logo
560 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
