Question about Star 50cc MOTOR SCOOTER
Changing headlight bulb on 2009 jmstar
Bright light works,dim light blown
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 48,573 Answers
Hi Anonymous, I am sorry you can't find the first and best tool you ever bought for your Bajaj but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Manual Kawasaki Bajaj Wind 125 Documents
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Posted on Nov 04, 2015
2 Suggested Answers
  • 4088 Answers
SOURCE: headlight on my jmstar scooter will not come on
Operate the dimmer switch--does one beam come on? Check inside the headlight shell and examine the wiring from the lamp socket into the handlebar and main harness wiring. If individual connectors, check that the colors match at each connector. If you can't find any problem, then the wiring is mis-connected. Make sure the lamp socket is connected to ground.
Posted on Sep 08, 2009
2009 Keeway Superlight 125 lights are not working
Hi, Neil if your headlight is not working, intermittent, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chafed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/low beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lighting coil
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Newbie on Keeway Superlight problem after problem
Ignition turned on but no power at all Bike just stop working
Keeway superlight 125 service manual
Keewayparts com Genuine Keeway Parts Shipped Worldwide KEEWAY Speed 125 User Manual
Feb 17, 2018 | 2009 Keeway Superlight 125
Driver side headlight goes dim on high beam while passenger side is bright
bad connection or bad earth check all connection or bulb
Jan 24, 2016 | Cars & Trucks
2005 Honda Activa headlight dim
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
5. Faulty hi/lo beam switch.
http://www.instructables.com/id/Make-your-Scooter-Motorcycle-Headlight-Brighter-by
one headlight EXTREMELY dim Honda Civic Forum
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda activa 2009 Owner Manual
Jan 22, 2014 | 2005 Honda Activa
2009 Kawasaki Z1000 high beam not working
Hi, Anonymous if your headlight is not working, intermittent, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your headlight bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
High beam not working Kawasaki Forum KawasakiWorld com
Head light flasher not working Kawasaki Z1000 Forum Kawasaki Z1000...
Kawasaki Z1000 Service Manual
OEM Parts for Kawasaki
2007 Kawasaki Z1000 Owner Manual
Jan 08, 2014 | 2009 kawasaki Z1000
Headlights dont work
if the bulbs are blown the voltage regulator is the problem
Dec 19, 2013 | Arctic Cat 2006 F6 Firecat EFI Sno Pro
2007 Hyosung Avitar GV 650 the headlight keeps getting bright then it dims
Hi, Oliver if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
3. Worn, chaffed, or broken wires in the light circuit.
10. Weak charging alternator/generator/lightling coil.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Why does my headlight go dim get bright
Headlights bright then dim ELD or
HYOSUNG Aquil GV650 Service Manual
HYOSUNG AQUILA GV650 PARTS CATALOGUE Manuals
HYOSUNG GV 650 EFI Owner Manual
Jun 13, 2017 | 2007 Hyosung Avitar GV650
1998 Honda CBR 1100 XX Super blackbird headlights not working
Headlights are out need part of relay
Headlights not working CBR Forum Enthusiast forums for Honda CBR Owners
1997 1998 Honda CBR1100XX Service Repair Workshop Manual Download Download... $15
Honda 1998 CBR1100XX Owner Manual
Oct 22, 2017 | 1998 Honda CBR 1100 XX Super blackbird
1990 Honda VT 1100 C Shadow headlight stopped working
Hi, Mattbutler75 if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
10. Weak charging alternator/generator/lighting coil.
Headlight problem
http://www.fireblades.org/forums/honda-cruisers/96259-honda-shadow-1100-headlight-not-working.html
Honda shadow vt1100 Owners Workshop Manual
Honda VT1100C2 Owner Manual Page 3
Jul 07, 2012 | 1990 Honda VT 1100 C Shadow
Both headlights stopped working in the dim position, but they work in the
both headlights might have dim blown out buy a new bulb and see
May 05, 2012 | 1991 Ford Ranger Supercab
Honda Activa no high beam
Hi, Joan_simon if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
Motorbike experts why are my main lights not working Singletrack Forum
Honda Ruckus high beam issue
Apr 23, 2011 | Honda Activa Motorcycles
Star 50cc MOTOR SCOOTER Logo
74 people viewed this question
Top Star Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Star Kitchen Range Expert? Answer questions, earn points and help others
