Question about Baby Lock Esante
Touch screen works sometime
Tried directins, still some of buttons-stwitches w/not work? but now the ajustment w/not come back on get a blocks w/1-30? My husband is an electrician but not a sewing mach repair person. Does it need new screen acts like a short. TKS sewdarnit@yahoo.com
  • Baby Lock Master
  • 7,365 Answers
Sounds like a computer part is going out, could be the motherboard
it needs to be serviced
Posted on Mar 14, 2012
Can the LCD screen be replaced and also the start button on the brother pacesetter 2003D Some of the LCD touch screen won't work sometimes it does. Same with the start push button
Sorry, I just got on to this website. Sounds like your mother board has gone a wall. I has to buy one on line . It was priceyll perhaps time to invest in a new machine.
Jun 15, 2017 | Brother Sewing Machines
My touch screen isn't working
Brother 8200 8500 8500d screen ..just found this on youtube not sure if this will help you out
Dec 03, 2016 | Brother Sewing Machines
The touch screen on my singer quantum xl-1000 lights up but no icons are showing. What should I do?
I have instructions for recalibrating the screen on an XL-6000, which is similar enough that it should work; however, give it a try at your own risk. I would point out, though, that at this point you probably have nothing to lose.
While the machine is turned off, you hold down the scissors button, reverse button, and the green/red light button all at the same time. While pressing these buttons, you turn your machine on and can let go of the buttons. You take the pointy end of your lint brush and use it as a stylus to touch a little red dot on the screen (that also has that pen looking thing that I had messed with and that caused my trouble), the dot will move to another position and you will touch it again. It moves again two more times, and each time you will touch it with the pointy end of the brush. Then you will touch the treasure chest box on the screen to save what you did. You will then turn off the machine and turn it back on, and then things work again!
Oct 19, 2014 | Singer Quantum XL-1000 Computerized Sewing...
My Kenmore 19001 touch screen works when I am sewing regular stuff, but when I put in the embroidery card - I can see the designs on the touch screen but nothing happens when I try to go to a design. I...
to recalibrate the machine press the stop/start; the reverse; and the knot button at the same time and while holding it down turn the machine on.
Sep 28, 2012 | Kenmore 19001
Hi Can u please tell me how to calibrate my Designer 1? Have not done it for a few years and now I've forgotten. Also my touch screen is only partially responding....I'm not getting any response...
Hi Vina, Since you can't get any response to your Menu-Norm-Prog-Rep-Set-or Help on your touch screen but you can get into your stitches, It does sound like you need to re-calibrate your touch screen. Normally you would get into your Set Menu to access your touch screen calibration. But as suggested on another solution. You turn off your Des 1, Holding in the reverse button (bottom left of the eight buttons) and the pivot button (the second one from the bottom of the four buttons) at the same time and turn on your machine. This is the Service menu that pops up (try not to touch anything on this screen, it could really mess things up if you don't know what you are doing) After this screen pops up go over to the eight buttons on the far left of your machine and touch the needle up, needle down button (top right button of the eight) the Calibration Screen will pop up on your touch screen (two plus marks labeled 1 & 2) In your sewing sitting position touch the center of the #1 mark and then the #2 mark. Once you've done that the Service Screen will pop back up. Shut off your Des 1 and restart it normally. Try getting into your different menus- Menu-Norm-Prog Etc. Hopefully that fixed your Calibration issue! ** Note: If the service menu doesn't pop up when trying to hold in these 2 buttons together and turning on your Des 1 the buttons weren't held in properly and you need to turn it off and try it again. Hopefully that helped you out!! Happy Sewing!! Kathy
Nov 24, 2010 | Husqvarna Designer I
Janome MC 9000 off touch screen calibration
Thanks guys
I remembered the fix!!
On the Janome MC 9000
To calibrate the touch screen
1. Turn off
2. on Sewing arm above needle there are a series of buttons
3. Hold down bottom 3 buttons
4. While holding turn on machine
5. Using scribe
6. Touch the centre of each + as it appears
7. It will go Centre bottom rh centre top lh as you select each + position it moves of it's own accord.
8. Turn off machine
9 Turn on and test.
Important sometimes this does not entirely fix prob!!
Simply do it again "Yahoo""
Some mechanics will try to tell U the screen is on it's way out
Bollocks just calibrate.
Thanks
CYA
Nov 16, 2009 | Janome Memory Craft 9000 Computerized...
Designer 1 Problem
Try touching around the button on the screen.  Touch above, below,left & right moving farther away from center. At some point it may clear. If so, use the same method to calibrate your touch screen in the "set" menu.  If not, go back to your repair facility and have them recalibrate in the service mode.
Sep 03, 2009 | Husqvarna Designer I
Won't work at all-esante ese baby lock
Check that the button used to snip your thread at the end of your seam is not stuck. Mine will sometimes stick and if I just touch it again it will again activate and the red start/stop button will work again.
Apr 08, 2009 | Baby Lock Esante
My touch screen doesn't always work. Sometimes I have to touch all around the square and even then, it won't come on. At times, it stops working when I want to change patterns. It seems to work most of the...
Yes, I have a solution for this problem. Your screen needs to be recalibrated and you can do it yourself. Don't you wish they would just tell you this stuff instead of charging you an arm and a leg? Here's what to do: Before turning on the machine, press the start/stop button, the reverse button, and the needle position button all at once with one hand (one finger on each button). Hold them down and turn on the machine. What will come up is a recalibration screen. You will see the numbers 1-5 with a little plus sign beside them. Find a small blunt object (I used the tip of a mechanical pencil with the lead in instead of out) and while holding the start/stop button, touch the plus sign beside 1-5 in numerical order. Then, turn the machine off and on again in the normal way. This should recalibrate the screen. Pass it along, people! This is something no one should have to pay for!
Nov 03, 2007 | Baby Lock Esante
Sewing Machines Logo
48 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
