Question about Linksys E3000 Wireless Router
How do I find the WEP hex code so I can reconnect to my android phone
My phone lost its home link to the secured WEP code, It turned on while in my pocket and then this happened, I can connect via home-guest but not to the main home. Help
  • 362 Answers
Look on bottom of router the code should be there unless it has been changed
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Feb 16, 2012
How do i find wep key
Connect your router to computer with lan cable then you can access it with default link http://192.168.1.1 then type user as "admin" and password as "admin" or blank or "password" then you can see settings of router. Click on wireless then wireless security WEP key note down the code it is your password to connect wireless. Let me know if you need further assistance. Thanks for using FixYa.
Apr 06, 2011 | D-Link DIR-615 Wireless Router
Just bought a new acer aspire netbook and have a d-link 615 router at home. my dell laptop connects automatically anywhere in the house. my desktop is hardwired so also connects no problem. this netbook...
If the netbook is running Windows 7 and the router is encrypted with WEP, then you can try changing the encryption to WPA or converting the WEP Key to HEX and entering the key in hex to the netbook
http://d21c.com/sookietex/ASCII2HEX.html
Dec 25, 2010 | D-Link DIR-615 Wireless Router
How do I obtain the WEP Code for this Router? I'm trying to hook up my Internet capable LCD TV
Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1).
Click here if you cannot access the web-based configuration.
Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen.
Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key.
Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption.
  • 64-bit encryption 10 characters
  • 128-bit encryption 26 characters
  • 256-bit encryption 58 characters (available on DI-614+ only)
  • The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key).
    Step 5 Click on the Apply button then click on the Continue button to save your settings.
    Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
    How do I enable encryption on my D-Link adapters?
    If you need more help come back.Post /thumbs / testimonial are welcome!
    Nov 23, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
    Can't connect with i phone when wep security used
    WEP "Security" has been completely and thoroughly hacked. It is pretty useless. WPA requires that you pick a good passphrase which is not dictionary based.
    But my guess is that you have not entered the security key correctly. Stupid WEP should have included a checksum in the entered key. Make sure you use the hex key, and not the phrase that generates the hex key. I have had poor luck moving those and never encountered a problem with the hex key, unless I miscopied it.
    And switch to WPA security.
    Jan 12, 2010 | NetGear RangeMax WPN824 Wireless Router...
    I am trying to connect wireless so that I can you
    I"m not sure what you mean "EAP", but there is a WEP. It's the simplest code, but it will keep the casual or newbie out of your network.
    Somewhere in your documentation, there should be a section on wireless security. WEP 64 bit uses a 10 character HEX password. In the simplest sense, you could set it to FACE123456, or 1011121314 as I do in my own cul-de-sac residence. The neighbor uses a phrase that means something to her but not me.
    If you need something more elaborate, a Pre Shared Key (PSK) can be 8-63 characters and it's case sensitive. The problem is in most routers, if you forget it, you get to start all over as it's not displayed. In my Netgear, the WEP is visible and hex characters have no case.
    There is Linux and Mac software that can sniff out the packets and break the security, but if you happen to monitor your traffic from time-to-time or change passwords, you can usually figure out if it's been compromised.
    Carl
    Dec 14, 2009 | D-Link DIR-615 Wireless Router
    Printer will not accept the WEP encription code during setup wizard. We have double checked the code and it is correct
    you may have been putting the passphrase and not the hexadecimal equivalent network key. you should be inputing hex chars (0-9, A-F).
    For 64-bit WEP: 10 hex characters
    For 128-bit WEP: 26 hex characters
    Hope this helps!
    Sep 17, 2009 | Brother MFC 7840W Printer
    LG KC910 connecting wifi to my home internet
    I had this problem, My wirless router is using WEP Authentication with a "Shared Key". I had to change this to either Open or Automatic on the router.
    Feb 02, 2009 | LG KC910 Renoir Cell Phone
    Wireless is not secure
    Step 1 Log into the Router
    A device which forwards packets between networks. The forwarding decision is based on network layer information and routing tables, often constructed by routing protocols.'); return false">Router
    by entering it’s IP address into a browser. The default IP address is http://192.168.1.1. At the login, enter your username (admin) and password (admin).
    Step 2 Click on “Wireless” on the left hand side then click on “WEP” at the top of the page.
    tew-432brp_f_1.jpg Step 3 Enter in the desired encryption values then click “Apply”.
    Examples:
    Authentication type:WEP WEP
    Type: Open
    System Mode: Hex WEP
    Key: 64-bit Key 1: 0000000000
    Note: For WEP you can choose ASCII or HEX modes.
    64bit ASCII = 5 digit ASCII key.
    64bit HEX = 10 digit HEX key. (Can only use letters A~F and numbers)
    128bit ASCII = 13 digit ASCII key.
    128bit HEX = 26 digit HEX key. (Can only use letters A~F and numbers)
    You can also choose WPA
    Wi-Fi Protected Access (WPA) is becoming the wireless security standard. It is a higher level of security than WEP that combines encryption and authentication to create an unbreakable level of protection. For small office and home users the WPA preshared key (WPA-PSK) is the easiest set up and does not involve a Certificate Authority Server, which is recommended for small and large business customers. Once the preshared key is set-up on each network device, every packet sent over the wireless network will receive its own encryption key under the Temporal Key Integrity Protocol (TKIP). A key benefit to WPA is that it is backward compatible with WEP-only devices. For those users looking to ensure those who share keys are who they claim to be a Certificate Authority Server or RADIUS Server can be added. This requires a more complicated set-up and is not recommended for smaller networks. Also, one thing to note is that WPA adds to the packet size, typical transmissions will take longer.'); return false">WPA
    -PSK. The key must be between 8~64 digits.
    Authentication type: WPA
    -PSK
    Passphrase: omg laserbeams pew pew pew
    Confirm passphrase: omg laserbeams pew pew pew
    Jan 05, 2009 | Trendware TEW-432BRP 54Mbps Wireless...
    How to block my wireless so that next door house cannot use?
    how to make security code to my wireless router sitecom46E2CE this pls. i need your help to protect my network. thanks..
    Oct 05, 2007 | D-Link AirPlus DI-524 Wireless Router
    Linksys E3000 Wireless Router Logo
    57 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
