Question about Apple iPod classic MP3 Player
Ipod wont connect with itunes
Ive plugged in my 40gig ipod shows weak battery as well but no showing connect to computer an ipod cant download or charge someone told me hard drive fried?? can b fixed or just buy a new one??
  • 81 Answers
Heres a video that will help you reset it. Hope it helps.
http://cnettv.cnet.com/2001-1_53-25928.html
Posted on Jan 04, 2009
When i plug my ipod on to itunes it wont show up
Sometimes your iPod fails to display in iTunes, which will keep you from being able to transfer songs from your computer to your iPod. If this happens, there are a number of steps you can take to resolve the issue.
Is it the iPod? Your iPod could fail to show in iTunes for a variety of reasons and this issue can be resolved by something as simple as rebooting your iPod. To reboot your iPod, first lay it on a flat surface. Using your thumb and index finger, press the play and menu button at the same time. If done correctly, your iPod screen will go blank and then you'll see the Apple logo. Is it the USB cable? Your iPod could fail to show in iTunes if you are using a defective USB cable. Try connecting your iPod to another computer that has iTunes installed using the same USB cable. If iPod again fails to show in iTunes, replace the USB cable. Is it my computer? One of the most common reasons your iPod doesn't show in iTunes is because your computer doesn't recognize your iPod is connected. Troubleshooting your computer/iPod connection Disconnect your iPod from the computer and reconnect. If your iPod still doesn't appear in iTunes, disconnect your iPod and reboot your machine. Once your computer has restarted, reconnect the iPod. Is it iTunes? Your iPod could be fail to display in iTunes if there is a issue with your iTunes program. If there is a problem with iTunes you can try updating the software to the most recent version. If that doesn't resolve your problem, re-install iTunes. b> http://www.itunes.com/ b> http://www.apple.com/support b> iPod Won't Connect to iTunes b> Apple's iTunes software contains mechanisms specially designed to sync with your iPod, allowing you to transfer music, videos and other media from your computer. If you find that iTunes does not recognize or allow you to access your iPod, then you cannot perform some of the device's most fundamental functions. Fortunately you can often resolve this problem without expensive maintenance, simply by doing a bit of troubleshooting and determining the cause of your connectivity problem.
Try resetting your iPod. Apple recommends this as a first step in troubleshooting an iPod not appearing in iTunes, since a quick reset will often restore functionality. If you use a click wheel iPod, hold down the "Menu" and center buttons until the Apple logo appears on your screen. For the iPod Touch, hold your "Home" button and "Sleep" button simultaneously until the Apple logo appears. Charge your iPod battery. If your battery has absolutely no power left, your iPod will often remain unresponsive even when plugged into iTunes. Try charging for three to four hours and then try connecting again. Plug your iPod into your computer using a different USB port. Sometimes a failed connection can mean you have a faulty USB port, so try plugging your USB cable into a different port and see if the iPod appears in iTunes. Verify that you have the latest version of iTunes. Visit the iTunes page Apple.com and check to see the latest version available. If you do not know which version currently runs on your computer, click "About iTunes." For Mac users, this option will appear under 'iTunes" on your menu bar. For Windows users, the option will appear under "Help" on your menu bar. Download the latest version of iTunes if necessary. Reconfigure your iPod service. If running iTunes on a Windows computer, click "Start > My Computer > Manage," and select "Services and Applications." Under "Services," select "iPod Service" and click "Stop." Leave the window open and connect your iPod to your computer. When your iPod shows up on your computer, click "Start." Reinstall iTunes. If simply updating iTunes does not work, you may have defective software. Try removing the program from your computer and completely and reinstalling it.
Jan 29, 2013 | Apple iPod touch Second Gen (8 GB,...
My ipod wont show up on the bar when i plug it in the itunes
Ive got an ipod touch which i got today, on the screen shows a picture of the charging cable and says itunes above it, it wont do anything else apart from saying slide bar to switch off, can you help...
Just plug it into your computer and open up iTunes(if you have not downloaded iTunes, download it here). iTunes will have you go through a quick set up for your iPod. Then you should be able to get past the iTunes and charging plug screen.
Hope this helps!
Dec 25, 2009 | Apple iPod touch
Shows to connect to itunes on the screen
The ipod should let you do a restore in itunes with the computer that last synced the ipod. This is the only way to remove the passcode.
If it wont simply show up on the computer, plug the ipod in, hold the power button and then slide to power off. Press the power button, as soon as the apple logo appears press and hold both the top power button and the home button together until the orange triangle appears. This should put the iPhone into restore mode, open itunes and restore.
Nathan.
Apr 09, 2009 | Apple iPod touch
Ipod wont show up on itunes
You can try connecting it to another computer and see if it works there. If it does then it is Windows or your computer or the USB port or driver. You could also uninstall iTunes and reinstall it and then check if it connects. If it shows up then, you can select to restore it on the info screen, it will reset it back to factory and wipe it clean.
Hope this helps
Nov 27, 2008 | Apple iPod nano 2nd Generation MP3 Player
first try reainstalling itunes if that dosnt work try restoring your ipod.
Jul 09, 2008 | Apple iPod touch
In order to get an Ipod to work on your computer never plug it into a USB hub. The hub does something to the power of the device that causes it to not perform, be recognized, or charge. Find a spare USB port to plug it in and see if it will find it.
USB hubs do not work on external hard drive devices. Jump drives will work on a hub
Jun 05, 2008 | Apple iPod MA446LL/A MP3 Player
go to applications then utilities then open disk utility
on the on the left side all the hard drives will be listed. click on your ipod then click erase, look here click "erase" and then "ok". when it is done disconnect the ipod, open itunes and reconnect the ipod. itunes will tell you the ipod is corrupted and i needs to restore it. click ok and then wait for it to complete the restore.
PC:
go to start, my computer. in the new window your ipod's name will apear right click then click format. make sure that quic format is checked and then click "ok". when it is done disconnect the ipod, open itunes and reconnect the ipod. itunes will tell you the ipod is corrupted and i needs to restore it. click ok and then wait for it to complete the restore.
Feb 19, 2008 | Apple iPod nano
Your ipod has to be plugging into a high speed usb port, that's your problem. Don't use the usb ports on front of your computer, use the one's in the back. Those are typically high speed. If you have an older computer, you might not have high speed usb ports and you'll need to purchase an pci usb 2.0 adapter.
Once you get it connected to the computer and you sync with your library it will remove any songs that were previously on the ipod.
Dec 26, 2007 | Apple iPod nano
Apple iPod classic MP3 Player Logo
88 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
