Question about Toshiba Satellite Pro M15-S405 Notebook
Restore Problem Hi I have an M15 and I don't know how to restore it. It is running very slowly and I tried to use the resore disks but it won't accept them. It won't even let me restore it to about a month ago. Starting it up while holding the 0 key didn't bring me to the screen it should have. Any suggestions?
  • 3 Answers
In case you have not remedied this problem ...
Start off by running Checkdisk to make sure the Hard Drive is okay.
Get a good Antivirus and run it [ AVG free is okay ]. [obviously you must have a good AV installed!]
Download and install Spybot S&D v1.6, and run it
Also find Malwarebytes AntiMalware ... install and run that.
You could also try CCleaner.
And finally get a good Registry cleaner - and run that.[ there are a few good Free ones you may find on CNET, or one of the other Reputable download sites ]
After you have run all of the above you WILL have a much happier computer, and should not have need to load a restore ...
BUT you Will NEED to create a New Restore Point before you start the clean up, AND once the computer has been cleaned up - also create a New Restore Point.
And finally when you have completed all that , run the Defrag - which may take a long time if not run recently. [ defrag should be run on a fairly regular basis ]
Incase you need to get into the Windows boot options, holding the " o " key not the "0" zero, may get you in. Other wise the [F8] key must be pressed at startup - this will bring up the options menu also.
If you Requre to Boot from the CDRom at startup - as the Computer is first powered on start presssing the Right Arrow key until you see the Hilite move across the Icons - here you can select HDD , CDRom, Floppy and even WindowsBoot Menu.
Good luck.
Posted on Nov 18, 2008
Im trying resore my acer back to factory settings
Did you press 5 times
If you do NOT have a copy of this disc, skip to step 3 for further instructions. Once you restart your computer, a screen will appear with the words. Press Any Key to Boot From CD. Once you press a key, a screen will come up containing instructions to format your hard drive and restore the original factory settings. Follow the on-screen prompts to finish the installation. Once the restore is complete, remove your Recovery CD from the disk drive so that your computer does not try to boot from the CD again. Restart your computer to complete the restore. 3. If you do not have a System Restore disk, then your computer should have a recovery partition on your hard drive, separate from the main partition of the disk. Unplug all external devices and restart your computer. When the loading screen comes on with the Windows logo, press Alt+F10 together five times. This will bring up the system restore menu. Follow the on-screen prompts to restore your computer back to the factory settings Hope this helps.
Jan 20, 2013 | Computers & Internet
Im want to resore factory settings on my computer. I have tried pressing F11 when I turn it on nothing it wont start the system recovery and I have tried to find the recovery manager and that wont come up...
Hi
Another way to run the system recovery is RUNNING ON ADVANCE BOOTING OPTION by pressing F8 key when booting up and choose system recovery or restore factory setting.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 19, 2011 | HP Computers & Internet
Toshiba satellite p305 I tried to uninstall google desktop from my user and I coudn´t. I logged in like administrator and I did. I restart the lap top and did not come up anything, I turned off....
I think that is nothing wrong but you just selected the wrong way to restore it ..You should select to reinstall teh operation system complete ..and also to format the C drive during it ..in quick mode ..this would save time ..I suggest to get it from the start cause more than sure this way is in error ..and if it do not work ..just use a boot-able disk with the operation system and download the drivers for the used operation system from the manufacturer's site..
here is the link fr your model
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=380609&rpn=PS630U&modelFilter=M15-S405&selCategory=2756709&selFamily=1073768667
select the correct 305 one ..and the operation system and download the drivers in case you do not have them ..
If you suspect the recovery is damaged try to see if they can provide a new one or just reinstall it using a boot-able disk ..
you can download an image from torrent sites.
Good luck !
Sep 05, 2010 | Toshiba Satellite Pro M15-S405 Notebook
Need a restore disk for acer laptopex4420
Hello
Thank you for using
FixYa for your problem
Windows 7 and Vista has a feature called System Restore that automatically backs up registry and system files whenever you install new software or drivers. This feature is useful when you install evil software that makes your computer run really slow. But don’t worry, System Restore won’t remove Windows Vista.
Using System Restore in Windows
There are two places that you can use the system restore feature from. From within Windows, you can just type restore into the Start menu search box, and you’ll immediately see System Restore at the top of the start menu:
now just follow it all
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Acer Computers & Internet
System resore
No you don't want to create a restore point, you want to restore the system to an earlier time or recommended restore point
Dec 13, 2008 | Dell Dimension E510 PC Desktop
Can't Restore C:Drive
use ur supplied recovery disk. put the disk in cd/dvd rom and turn it on, the system boot sequence must be on "first boot cd". the rest restoring process will do the cd automatically.
Nov 20, 2008 | Sony Computers & Internet
Hi I NEED TO DO A FULL SYSTEM RECOVERY ON MY ACER WXTENSA 5620Z BUT HAVE NO RECOVERY DISK. HOW CAN I DO THIS??? THANKS
reset the computer when the splash screen comes on press alt F10 this will bring you to the Acer RECOVERY screen click on the top one restore to factory conditition,this will bring you back to day 1.good luck.
Aug 09, 2008 | Acer Computers & Internet
Toshiba satellite pro m15 hard drive failure
I have a set of recovery CDs. Email me at jmalachowski@comcast.net if still have a problem.
Jan 01, 2008 | Toshiba Satellite Pro M15-S405 Notebook
My restor disk douse not work
What kind of pc?
What os?
How old pc?
Does system come up without restore?
If pc is slower than normal, did U clean and defrag?
Dec 08, 2007 | Computers & Internet
Problem running the restore disk for Toshiba A85-S107
I have the same model and i just reformatted the hard drive with the original restore disk and it does loop around several times. That is the way it is suppose to do on this particular restore disk. So don't be afraid if it goes around several times because it is doing different tasks each time it loops.
Nov 19, 2007 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite Pro M15-S405 Notebook Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
