Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Gas lines installation - McCulloch 16 Inch Gas Chain Saw MCC1635AK
Gas fumes from maytag range
"The professional gas installer has been here several times to check the. Gas lines." Ask the professional gas installer to do a leakage test and inspect for a cracked gas line.
Jul 29, 2017 | Maytag 30" Self-Cleaning Slide-In Gas...
Gas line installation i installed the gas pump but my car still shuts off can it be that i put the gas line wrong ???
Very possible . Check for an arrow ( indication flow direction) or words on the pump (in or out)
Nov 29, 2013 | Cars & Trucks
What size gas line should I install
Yes i have good solution Gas line Installed .....................
Toronto Gas Furnace
Oct 29, 2013 | Dayton Gas Furnace Heater
Whirlpool 6th sense natural gas water heater 50 gal. Bought brand new today. Upon installation, discover low gas pressure running to unit. Turned out that gas line had under ground leak so had to turn...
1) Be careful before you Call Whirlpool 1-877-817-6750.
Be careful what you report so not to void warranty because installation protocol was not followed. Whirlpool will cover gas control valve, and possibly the installation of valve which takes about 15 minutes and does not require emptying water heater.
************So make sure you report installation that is consistent with installation shown in manual.
2) Whirlpool will also answer this same question later today with invitation to contact them.
3) Copy following link to identify gas control valve, and download service manual:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
4) If dirt or debris gets into gas control valve, it will cause it not to work. Such as broken gas line. Debris can enter gas line.
Or if too much pipe dope was used on gas connection, or stray teflon tape got into line and then into valve, or end of pipe got dirty during installation, and then dirt got into gas control.
Take off gas line and use vacuum cleaner to see if something can be removed by suction. Clean up the joints.
5) It appears you have ordinary Honeywell gas control valve on atmospheric vented water heater with 9 year parts-labor warranty..
Unknown error code, so it is hard to look up solution in service manual.
Add a comment if you want expert to look up error code in service manual.
Feb 13, 2013 | Water Heaters
Brand new model rtg-64dvln smell gas when water is turned on..when water is off no gas smell getting code 11 gas valve not fully open but gas valve is fully open
1) if you smell gas, this is absolutely dangerous.
Call installer immediately.
If you installed yourself, get a professional technician immediately.
2) Copy following link for For error code 11: problem with gas.
Do not use flex line, bleed air from gas line, check gas pressure, incomplete combustion, etc.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Jan 29, 2013 | Water Heaters
How do I replace gas tank lines?
The inlet line will be an .080 x .140. Using side cuts, cut line at a slight angle and feed into tank. Pull through gas cap opening, cut line straight, and install filter. Pull line back into tank so filter lays on bottom. Connect to small carb fitting on side of carb.
The return line is 3/32 x 3/16. Connect one end to pump return next to primer, cut other end at angle and install about 1/2" into tank.
May 01, 2010 | Craftsman 25cc Gas Line Trimmer
Disconnected intake hose from gas tank to primer bulb
is gas line broke or disconnected? Either way it has to be reinstalled.First, get new gas line, and be sure to get it longer then you need, because, you will need to cut a sharp angle on one end then install this end into gas tank, then reach thru gas cap opening with needle nose pliers, get ahold of fuel line and pull thru. if you do not cut angle on new fuel line, you will never get the line into gas tank.
Apr 29, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
How do you hook up the gas line
Is there a gas line at the installation location? If you mean where on the heater, Then please tell me why you ask? Isn't it sticking out the side or back? If not, you may have to take a panel off that should have a hole in it and install a fitting to hook the flewable gas line. Its ther and the main gas valve is or should have a open threaded hole the fitting goes into. The flex line come with the fittings.. Good Luck, Ned
Oct 06, 2009 | Desa International GWP10 Wall Mounted...
Have installed new fuel pump and gas lines in 1995
pull line off of front of filter and cycle key 2 on position if there is no fuel present your feul pump may b the problem, before replacing old one make sure the fuse is good
Oct 06, 2009 | 1995 GMC Jimmy
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
41 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
