Question about Directed Car Audio & Video
My directed 1500d is locked in protection mode and keeps blowin fuses and dose nothing is there something i can do to get it back running again?
1500 watta car amp
The Marv
  • 72 Answers
SOURCE: Amp goes into protect mode.
I would definately suspect wiring. If you can use a volt meter. Put it on the b+ to ground and see what the reading is should be 12+ then try the ground to remote wire should be 12+. If it drops below 12 volts when car starts. Recheck wires for loose connection. Also double check the wire you have the remote wire connected to. You might even want to disconnect from the amplifier and use a jumper wire from the positive terminal on the amp to remote on the amplifier and see if it stays on then. If it stays on you will have to find the loose connection or find a different wire to get remote power.
Posted on Feb 05, 2007
  • 83 Answers
SOURCE: Fuse problems
output leads shorted by chance?
Posted on Jul 12, 2007
  • 631 Answers
SOURCE: amp blowing fuses
The amplifier probably has shorted output transistors.
Disconnect the speakers and RCA cables. Replace the fuses with two 10 amp fuses or a single 20 amp fuse. If the amp blows the fuse when it powers up, the outputs are almost certainly the problem. Don't try it with the two 30 amp fuses. The smaller fuses will provide more protection for the power supply. If the amp powers up with the smaller fuses and they don't blow, check the speakers and the wiring (for shorts to ground or shorts between wires).
Posted on Nov 22, 2007
XRAYRON
  • 156 Answers
SOURCE: kicker zx750.1 protection mode
Ok a few things to check here. So get a checklist lol.
Is the amp well ventilated?
When it goes into protetion mode is the amp HOT? like too hot to touch?
Do you have the GAIN maxed out? Turn it down
What are the gauges of your ground/power cables?
A bad speaker or speaker wire can cause this also.
Incorrect wiring of speakers like 4ohm speakers wired in parallel connected to bridge.
Inadequate alternator or battery in car
Does your system have a Capacitor? If not get a nice digital CAP they aren't too expensive.
Posted on May 06, 2008
  • 631 Answers
SOURCE: my amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Posted on Nov 30, 2008
Directed d2400 turning onnot going on protected mode but sound on the output.needs resetting?
Just turn it on normally then after you verified that the green power light is on. And the protect light is on as well just one by one remove the fuses and then wait one minute not doing anything and just re install the fuses one by one and when the blue directed light reactivates (THE BLUE LIGHT ON TOP OF THE AMP COVER) you are good to go. Sometimes just removeing the amp trigger wire and reinstalling it will do the same thing. hope this helps. i do this on mine every now and again. Just wish i new what caused it to do it in the first place, this is just my solution to get it working again.
Apr 02, 2015 | Directed 2400d Car Audio Amplifier
Memphis 1500d amp
The flashing indicates that the amplifier is in 'protect' mode, which is often a sign of a ground fault, but may also indicate that one or more of your power and/or signal wires is crossed, connected incorrectly, or shorting out for some other reason.
In short: Go through all your wiring and check it thoroughly. Be patient, take your time, and I can almost guarantee you'll find the problem in a loose wire or perhaps your ground wire isn't connected to a part of the chassis that is fully grounded.
Unfortunately the Memphis 1500D is a discontinued model, so installation instructions for it are not readily available... however, the SPL 1500D is a very similar product and the wiring should be identical, so for your reference here is the installation manual for that unit:
http://www.spldynamics.fi/products/amplifiers/ICE-series/splclassDmanual1220.pdf
Hope that helps, good luck!
Dec 03, 2013 | Car Audio & Video
My 1500d directed blow fuses as soon as you turn it on the red protection light keep flickering same as the green
It is for sure that you have a short in the amplifier and so will need to open the set to identify before the power is switched on. So first of all use a good multimeter to check for short in the output drivers. Disconnect the power line to the drivers and see if the set triggers on. If not trace it to the circuit near the power supply which makes the fuse blow. It can be easily found out by checking for the short or the voltage drop when powered. I hope you could try. Good day
Aug 11, 2010 | Directed 1100d Car Audio Amplifier
Amp keeps blowin the two 30amp fuses on the amp.
Make sure that the speaker wires are wired correct at both the amp and the speakers......otherwise it sounds like the typical death of a power acoustik amp (great amps, but prone to a premature death)
Mar 29, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
No power to tv
The power management and protection circuits have taken over. There is something taking too much current and the protection system has shut the system OFF to prevent further damage ...............if you are familiar with tv service you can check the main fuse that should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as soon as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply.......Check horizontal output transistor.............
Feb 04, 2009 | RCA HD52W59 HDTV Projection Television
Protect mode on vivitar vivicam 5386
hi there
this is the disc that you use in your camera correct, put the disc back into camera if so go to your camera setting like if you were going to review your pics.and go to the place where you went to lock the pictures press menu find protect again hit function settings hit select it will bring that picture back up again click function again and this will unlock it. this works for my cannon but it goes something like that hope this works for you its hard to explain but i had the camera in hand its easier do it. i just did it with my sons hope i didnt confuse u
Jan 19, 2009 | Vivitar ViviCam 5386 Digital Camera
Left directional and break lights on my 2001 jeep grand cherokee won't work. I've already replaced bulbs several times and the entire assembly
check the fuse for it, it maybe because its to big an keeps blowin them. an when you replace one side go ahead an replace the other side as well this should keep from blowin them.
Jan 02, 2009 | 2001 Jeep Grand Cherokee
Lanzar vibe 1500 protect mode
sorry bath your problem is a proablem the soft
Aug 02, 2007 | Lanzar Vibe 1500D Car Audio Amplifier
Rockford a2 not powering up
yiur amplifaer is in protection mode you moust reset the amp
Jun 15, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Car Audio & Video Logo
62 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
