Question about Ibanez Ael20e AcousticElectric Guitar with Onboard Tuner
Where can I get the Manual for the Ibanez AEL 20eTRS 14-02 w/onboard tuner Guitar..
3 Suggested Answers
  • 5603 Answers
SOURCE: Hi, My Ibanez AEL 20
Remember that while in tuner mode, the audio output is disabled. Try additional presses of the tuner button to see if the audio comes back on. Also verify the volume and EQ gains are turned up. Verify the battery is new.
Posted on May 30, 2011
rzepka159875
Ibanez V72ECE hey i bought new ibanez and the tuner not working, i bought new batteries but still cant run. maybe its some way to activate it or its just bad one? rzepa181@yahoo.com plx helpme
Posted on Nov 27, 2012
Don't know how to turn on tuner
put a battery in your guitar. It goes in the space at the bottom, usually where you connect your cable to your amp.
Then hold the guitar as you usually would.
Look for a little board with buttons on the side of the guitar to turn on the tuner: )
Mar 27, 2014 | Ibanez Talman Acoustic/Electric Guitar
Broken knob on an Ibanez gio
if you are talking about the Headstock Tuning pegs, Yes that can be repaired by replacing the Tuners themselves, I have sen a complete set for $ 8:75. you may even be able to find them sold individually on ebay or your local music store.
Feb 02, 2014 | Ibanez GIO Z99 6 String Electric Guitar...
Just purchased a used Alvarez FF60WR. The Electrical part works, but the on board tuner does not. It lights up when you turn it on, but the pitch indicator lights do not flash, and neither do the arrows,...
my on board tuner used to do that. I just tried to tune the guitar normally and it usually worked after a couple of seconds. The tuner needs sound to work - it won't work without you playing any notes :)
Aug 30, 2013 | Ibanez Ael20e AcousticElectric Guitar with...
I have a Ibanez V Series V70CE. It play well. But sometimes when I connect it to the amplifier, there seems to be loose connection and no sound is heard. When I move the wire little bit sound come...
Many try to use poor quality guitar cables and have the problem. The sleeve of the guitar cable plug turns on the battery in the guitar. Always loop the guitar cable through your belt or the guitar strap to avoid the cable wisting the plug in the guitar causing noise and WEAR that wears the plug sleeve to the point it no longer will activate the guitar.
Sep 18, 2011 | Ibanez V Series V70CE Dreadnought Cutaway...
My acoustic electric guitar is giving intermittent sound any idea how to fix this problem
A common problem is a WORN jack that is caused by the user NOT looping the guitar cable through the strap or their belt loop. The rotation of the cable as it is played wears both the plug and the jack and causes noise and dropouts. Also verify that the battery connections are corrosion free. Also verify the problem is not with your amp.
Sep 09, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
My ibanez Ael20 works for 2 seconds when plugged in and than stops working. I have replaced the batteries.
Make sure you are using a TS type cable (standard guitar cable, not balanced). Make sure the tuner is off as there are modes for tuning that kill the outgoing audio during tuning.
Jun 23, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
Hi, My Ibanez AEL 20 has a preamp - tuner 5AEQ45F. Tuner works but there is no signal in output jack. Guitar is quite new, and the preamp hasn't been used before. Can I get a PCB schematic diagram...
May 30, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
Hello, I have found that Ibanez AEL20 guitars' 5AEQ45F (SRTn) preamp-tuner has a 6V voltage, my AEL20 guitar came with 1,5 V batteries (3V in total). There is no internet source to get the...
There is little data on the internet about this... However my AEL20E uses 2 AA cells. Some older ones may have used a 9 volt battery. Yours should use the 2 AA cells which go into the box right by the XLR output plug.
Feb 16, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
Ibanez intonation problem
Hi there. Use guitar tuner. Pluck string in open position. Tune. Now pluck same string at 12th fret. If tuner says flat, adjust bridge for that string towards neck. Towards bridge if sharp. Repeat procedure until in tune at open and 12th fret. Go to next string and repeat procedure.
Thanks
Paul
May 11, 2009 | Music
Ibanez Ael20e AcousticElectric Guitar with Onboard Tuner Logo
47 people viewed this question
Top Ibanez Music Experts
Wayne Tolonen
Ted Maxwell
Kyle Steven OHare
Kyle Steven OHare
Are you an Ibanez Music Expert? Answer questions, earn points and help others
