Question about Garden
Where can I find a walbro hdc 17-A carb for a stihl 015L saw
  • robert brothers Feb 27, 2012
    problem has been solved
  • 12 Answers
SOURCE: Walbro wt hose routing on poulan saw
Carb has 2 nipples. top nipple gets line with filter on it from tank, bottom nipple receives line from bulb other side of bulb returns to tank
Posted on Mar 15, 2009
  • 211 Answers
SOURCE: Stihl MS 260 Pro wont run wide open or idle.
Hi brandon First change the sparkplug with the same heat range,Check and clean the gas filter with compressed air.Remove the carb and very carefully disassembly entirely.Check the gaskets and the diafragms.At the fuel pump side there is a fine screen(clean it).Check the needle,the spring and lever.Unlock the screws L and H(note how many turns are they).Put the corp of the carb in a special clean solution for 12 hours and then clean it with compressed air(something is clogged there).Put all back together and try to start the engine. regards savumihai71
Posted on Feb 12, 2009
  • 205 Answers
SOURCE: Stihl chain saw won't achieve max rpm
Crank seals are leaking, causes lean or low vacuum for the carb to work properly
Posted on Mar 26, 2009
emissionwiz
  • 75822 Answers
SOURCE: I have an old Homelite ez with a Walbro HDC 44
THIS IS CAUSED BY A PIECE OF DIRT STUCK IN AN AIR BLEED JET OF THE CARB OR THE CHOKE BLADE NOT BEING FULLY OPEN, CHECK THE CHOKE BUTTERFLY 1ST, IF IT IS OPEN ALL THE WAY THEN REMOVE AND CLEAN/REBUILD THE CARBURETOR
Posted on Jun 25, 2009
  • 124 Answers
SOURCE: what is the walbro chain saw carburetor adjustment for a
There is no set adjustment on any chain saw. If it were that simple there would be no need for adjustments. The problem is that most equipment manufactured in the past 10 years can not be adjusted by the user. Carburetors are now equipped with either adjustment limiters which limit the adjustment to less than half a turn or with adjustment screws that require a special tool to make the adjustment. More than likely you will have to take it to an authorized dealer for those adjustments.
If you do have an adjustable carburetor, then gently close both needles and open each on 1 full turn. This should allow the engine to start and the final adjustments can be made at that point. If it still will not start then open each needle 1/8 to 1/4 turn and try again. If this still does not work then most likely your carburetor needs a good cleaning and a rebuild kit.
Posted on Sep 13, 2009
Looking for carb repair kit for stihl 026 chainsaw
Check out ebay under name of the chainsaw. The carb is either a Zama or Walbro and there are plenty kits available for less than 10 dollars.
Oct 16, 2016 | Stihl Garden
Need a service manual for stihl 015l chainsaw
http://stihlusa.com/information/info_product2.html
Mar 16, 2016 | Stihl Garden
Where can i buy a carb kit for 011avt stihl?
First you need to determine if you have a Zama C1S-S1C or the Walbro WT-29A carburetor. The Zama will need a RB-11 kit and Walbro will need a K10-WAT kit. These kits should through most online small engine parts sites or your local small engine repair parts store.
Here is one place I order parts from that has these kits.
Lawn Mower Parts
Oct 29, 2014 | Stihl Garden
Need A parts diagram for a Sthil G65 Blower carb.
Unfortunately, Stihl won't release any of their illustrated parts diagrams to anyone except Stihl dealers. The dealers won't release them either. It is possible that the manufacturer of the carb will have a breakdown listed on their site. Stihl primarily uses either zama carbs (www.zamacarb.com) or Walbro carbs (www.walbro.com). Look on the carb for engraved numbers and letters to let you know what series and model to search on. The manufacturer is usually listed either on the bottom diaphragm plate or up on top. Walbro series usually start with a WT, or WA. Zama will usually have a C series (ex. C1U)
Nov 02, 2010 | Garden
I need to rebuild the carburetor on a Stihl Model 025 chainsaw. An exploded view diagram would help.
I don't have a diagram or the part numbers to the minor and major repair kits, but a Stihl dealer should be able to help. Tell him you need a kit for a ZAMA C1Q type carb. The exploded view should be with the kit.
May 19, 2010 | Garden
Instruction on how to rebuild Stihl FS85 carburetor
The FS 85 was produced in HUGE quantities over a number of years. Several different carbs were used during production and Stihl has several proprietary carbs in use. You will need a Rebuild Kit (NOT just a Diaphragm Kit) for this particular carb. On the carb body you should see a Series and a Model identification.
Example: If this is a ZAMA carburetor, the C1U-S66 might have been used on your trimmer.
Get that info off the carb body and ...
For ZAMA carb lookups click HERE.
For WALBRO carbs click HERE.
Hope this helps.
Oct 04, 2009 | Oregon Scientific Complete Carburetor for...
Garden Logo
655 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
