Question about Ovens
Kelvinator Km635 loose oven light switch. How do I get to it?
  • 1 more comment
  • Randy Prevost
    Randy Prevost Feb 16, 2012
    Hi,If you don't know how to get to the switch, then how do you know it is loose?ThanksRandy
  • Jack Morley Feb 16, 2012
    Sorry; it's a rotary switch, and the locknut holding the shaft of the switch to the frame of the stove is behind the fascia panel. How do i get the fascia panel off?
  • Jack Morley Feb 17, 2012
    Thanks Randy, but the hex nut is behind the front fascia panel, so I will need to remove the panel to tighten the nut. The knob is off, and I see the nut through the hole where the shaft comes through. The nut is about 7/16" AF and the hole is only about 5/16" dia.
Good day I have a Kelvinator build in oven KE610SS
Fixya does not sell Kelvinator rack sliders.
Mar 23, 2018 | Ovens
Where is the fuse for a 9 year old Kelvinator undercounter oven situated?
There is none. Look in the circuit breaker box on the outside of the house for the one marked oven. It will be 2 breakers side by side with a metal part connecting both levers together. Move both handles back and forth a couple of times. That may restore power to the heating element. If one breaker trips it leaves 120 volts to work the light and the clock, but the element is 240 volts. It may have shorted with age. You may need to replace the elements if the breakers keep tripping after you reset it at the panel.
Jul 28, 2016 | Ovens
Where is the fuse location for Kelvinator wall oven model # R30-1
Kelvinator Oven Product Support ' ManualsOnline.com
kitchen.manualsonline.com/support/electrolux-kelvinator/oven/
How to light an oven of kelvinator KCL86GSC gas co. Kelvinator ... Replacing thefuses on my kelvinator stove model H
Nov 15, 2015 | Ovens
Wiring diagram for a Kelvinator DeVille eye level oven Model B305, Serial no 3674
Request the wiring diagram directly from Kelvinator.
Jun 25, 2014 | Ovens
Kelvinator stove MODEL KC600BS
can i get a wiring diagram for kelvinator oven switch kc600bs
Oct 11, 2013 | Stoves Ovens
My Kelvinator oven is not working. I've checked the fuses and it is getting power. The 4 burners of the stove still work and I'm getting an occassional flicker of the little orange light if a switch the...
Kelvinator oven not heating? How to replace a kelvinator fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for KELVINATOR element How to Repair Home Appliances
May 12, 2010 | Ovens
I have replaced a Kelvinator hob with a ceramic hob. It works but the owen is not working. What is the problem?
There are possibly a number of options. It could be that in wiring the hob in you have disturbed the wiring for the oven. Normally the oven works off the main oven control switch on the panel and the hob could be wired into something else.
Is the oven totally dead no power at all for everything, or is the clock running but the oven will not switch on?
Dec 29, 2009 | Stoves 720EF Electric Double Oven
Ovens Logo
53 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
