Question about Protron PLTV3250 32 in. LCD Television
Protron PLTV32M Can not connect hdmi to Laptop
I connected my hdmi male to male cable from my Protron PLTV32M and can not get my Laptop to recognize the LCD TV. I checked the cable by connecting the LCD TV to my XBOX360. The XBOX360 works fine with it gives video and audio. I have a Radeon 5400 graphics card in my laptop. It is an onboard video adapter. When I connect a vga cable and put the Protron PLTV32M into vga mode it is recognized by the laptop with no problem. Just can not get it to detect the LCD when I put it in dvi mode. The connection in the back is definitely hdmi even though the OSD screen says DVI as the mode. Checked everywhere but can not find an answer. Please help, I miss my HDMI.
  • 4 more comments
  • Jason Morris Feb 16, 2012
    What type of laptop do you have?(model)
  • Mitchell Juergens Feb 17, 2012
    I have a Hewlett Packard Pavilion Dv7 Notebook.
    I forgot to mention that last year I dropped the laptop and damaged the DVD Drive. So the problem might be related to that. I am very proficient at working on the inside of laptops I have taken them apart before and have fixed problems. I just want to resolve anything that might be software related or anything I might have missed before opening the laptop and working inside it.
  • Jason Morris Feb 17, 2012
    Hold down the FN key(function) and tap F4 until it switches to hdmi.
    Tried that it does not show an option for hdmi. This only seems to work when I have the external vga cable connected between the latptop and my LCD TV.
    Any other suggestions.
  • Mitchell Juergens Mar 03, 2012
    Ok So I decided today I would take my laptop to Staples since I bought it there. I brought my brand new HDMI male to male cable with me. Told the salesperson I wanted to see whether my laptops HDMI was working and wanted to test my laptop with there LCD Monitor. Connected my laptop using HDMI cable to the HDMI port on there LCD Monitor and it instantly connected. After this I brought my laptop back to my home and connected it to my Protron PLTV-32M and switched the input source to DVI and nothing but a blue screen. Remember earlier in my post I said I successfully connected an XBOX360 using the same HDMI cable to the Protron PLTV-32. So any suggestions would be helpful.
3 Suggested Answers
SOURCE: Problem with DVI Port
You might be running into a problem if you haven't changed the video settings on the PS3 to send digital video. Try that first.
Posted on Jan 24, 2008
  • 125 Answers
SOURCE: I'm connect my PS3 TO
Temporarily hook the Playstation up to another television and change the resolution in the display settings to 1080i and try again. If that does not work, try lowering the resolution again to 720p. If this set has component video input (Red, Green, Blue video cables) try that as well if possible. In fact, this may be the only way to hook this up and have it work in high definition because this set may not be HDCP compliant. You will have to check the owner's manual for its specifications. If all else fails you will have to use the composite (yellow) video cable to hook it up. It won't look pretty, but it should work. Good luck.
Posted on May 06, 2011
Have wireless internet need to connect tv to hp laptop
If its portability and convenience you're wanting to achieve you can connect your tv to your laptop via a hdmi or vga pc to tv device such as the one below.
wireless-internet-need-connect-tv-hp-h3kz2pmtsa0m5tqtbi05zsqk-5-0_1.jpg Or you could set your close lid settings to "do nothing" when lid is closed" and set it to "never sleep" when connected to AC power and use either an hdmi cable or male vga to male vga cable to connect to your tv. You will need a wireless keyboard and wireless mouse because u will no longer need to physically access your laptop. Make sure your tv input selection is correct. For example, hdmi 1, computer, vga, and etc.
Oct 18, 2015 | HP Pavilion Computers & Internet
Using with a laptop
Connection the monitor depends on the connections you have out of your Toshiba laptop.
The monitor has both VGA and DVI.
If the Toshiba has a VGA out, all you need is a VGA cable available online, computer or electronics store.
If the Toshiba has an HDMI out, you can connect it to the DVI on the monitor with an HDMI cable and an HDMI to DVI Adapter.
You can also use USB out with either a VGA converter or a DVI converter (go with DVI for the better picture). Converters can be found online at Amazon, you may also need a standard male to male DVI cable to use with the converter.
Amazon com uxcell Black Blue VGA 15 Pin Male to Male Plug Computer Monitor...
Amazon com 5m High Speed HDMI Cable Ultra HD 4k 2k HDMI Cable HDMI to HDMI...
Amazon com Rankie Gold Plated DVI to HDMI HDTV Male to Female Adapter...
Amazon com StarTech com USB to DVI External Video Card Multi Monitor...
Apr 05, 2014 | HP Pavilion F1903 19" Flat Panel LCD...
Connecting VGA Screen to HDMI laptop
Press and Hold "Fn" and then press number key with "square / square w/ legs (like monitor)" icons
Jun 18, 2013 | Computers & Internet
Laptop to T.V. connectivity
Hello!
This is my first time using this site, but I will try my best to assist you.
From what I understand, you want to connect your laptop display to your T.V. In turn using your T.V. as a "monitor".
So you were wondering if you could use a S400 to HDMI cable to accomplish this. Unfortunately I don't believe this is possible with that cable. To my best knowledge, S400 ports are only capable of transferring DATA between devices, not VIDEO. A VGA or HDMI cable will accomplish what you want. I don't think your laptop has a HDMI port, so I recommend buying a male-to-male VGA cable.
I looked up your T.V. and it looks it should have a VGA input port. This is what I did for my laptop and 32 inch LCD T.V. when i accidently cracked my laptop's screen.
It may not be High Definition, but you should be able to get fairly decent resolution. Make sure your T.V. is on the "Computer" input channel. (Or equivalent)
I don't recommend buying a VGA to HDMI cable converter as it usually doesn't result in improved quality.
I hope this helps! Good luck!
Jan 21, 2013 | Computers & Internet
What type of cable do I get to connect presario 900 laptop to TV?the
You can use either an HDMI cable or a VGA cable to connect your computer to your TV. Your computer has both HDMI and VGA ports. You can use either ports but you cannot use both or else your video card will crash.
Thank you for visiting FixYa! have a nice day!
Apr 27, 2011 | HP Compaq Presario CQ60615DX Notebook
I NEED A Toshiba Satellite L305-S5946 Laptop HDMI CABLE AND DONT KNOW WHICH ONE TO GET.
as far as I knew, that laptop didn't have hdmi out. if it does, you should be able to use ANY hdmi although you made need a specific cable with either a full size male hdmi on both ends or an hdmi with a full size male on one end and a mini male on the other. if it doesn't have an hdmi out port though, you will need something like a VGA to hdmi or DVI converter box (depending on what you are connecting the laptop to). a simple cable with VGA on one end and a hdmi on the other wont work either as it wont convert the signal properly. you need an electronic box(could cost more than $50) to convert the signal similar to this for an example...
hope this helps
Apr 17, 2011 | Computers & Internet
What kind of connector do I use to connect a dell laptop to a Hitachi 42'' plasma display? HDMI to DVI or HDMI to VGA?
If the TV has a VGA connector then use a VGA to VGA cable from your laptop as most laptops have a VGA output. Otherwise use one of the other combinations that work HDMI to DVI or HDMI to HDMI..
Nov 11, 2009 | Televison & Video
Ps3 hdmi cable with adapterto tv's rca's
Just use the regular AV cords. They are 480i using an HDMI to this and that isn't going to improve picture quality.
Mar 01, 2009 | Sony Playstation 3 (PS3) Console
HOW TO CONNECT MY PROJECTOR TO MY LAPTOP?
I have hp laptop with hdmi & vga, sharper image projector with rca connector what do I need to connect these two
Dec 22, 2007 | Philips cBright XG2 Multimedia Projector
Protron PLTV3250 32 in. LCD Television Logo
142 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
