Question about Sony FD Trinitron WEGA KV-34HS510 34" TV
Red tint red shadow
  • Sony Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Posted on Mar 09, 2012
Red tint right side mitsubishi hc7900dw
first try doing a factory reset through the menu. if it persists and the tint has a relatively hard edge to it, you may have a broken light tunnel and it's casting a bit of a shadow on the image. you might need to bring it in for repair, especially if it's under warranty
Feb 25, 2014 | Office Equipment & Supplies
Tone of red is showing too much. like a red shadow behing people
try this: go to the menu go to picture change the tint by adjusting the red.
May 26, 2011 | Televison & Video
Everything on my moniter has a shadow, even the smallest letter and number,the shadow is to the right with a slight red tint.
please check that any utility in os or software is activated.because many sofwares have this option called as drop shadow or check the moniter with other pc
it can also be the problem with the LCD panel
Mar 27, 2011 | LG Flatron W2243SPF Widescreen LCD Monitor
Shadow effect on picture. Picture is fine but there is a red shadow tint to everything (basically everything is written twice, but not in the same spot)
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Asus laptop and red shadows on letters and bad picture. is this a lcd inverter problem? External monitor works ok.I check lcd panel cable and replace lcd panel but all same
Yep, it's the inverter. Anytime there is a red or pinkish tint or hue you know it is the inverter. Usually the inverter is very easy to change. I would buy one on eBay for your best price...
Good luck!! EJ Kudelka
Oct 18, 2010 | Computers & Internet
The Picture looks Double, there is a red tint shadow next to everything projected onto the tv
You can get the repair kt called the Sony type 1 convergence repair kit from www.tvrepairworld.com which is the correct kit for your model. The kit contains parts and instructions for the repair.
Jun 22, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Shadow and red tint on projection tv
red bulb maybe bad, try the convergence from the menut first
Nov 06, 2009 | Ultra AcoustiFan DustProof Quiet Fan -...
AKAI PDP4273M Plasma tinted red
TRY THIS BY USING YOUR REMOTE 1-PRESS BRIGHTNESS 2-PRESS FREEZE 3-PRESS MENU 4-PRESS ENTER THIS WILL TAKE YOUR TV BACK TO FACTORY PRESETS. I WENT 3 MONTHS WITH NO TV BEFORE I FOUND THIS OUT.
Sep 06, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Sony FD Trinitron WEGA KV-34HS510 34" TV Logo
103 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
