Windows cannot find any network - Computers & Internet
    Genius:
  • 1,011 Answers
have you installed the lan driver or wireless lan in you pc. Check it by the way. You can check the setting if you have windows xp by going on My computers....>right click and properties....>Hardware.....>Device Manager and see what is not installed here...like Network Adapters.
Best of luck!
Posted on Feb 16, 2012
Can't get old connection icon back on taskbar
From LifeHacker:
Windows 7: If you miss having a network activity icon that actually indicates if your network is active or not, this handy little hack will swap the static Windows.
The solution is a tiny application called, Network Activity Indicator for Windows 7. Download the application and park your standard Windows 7 network indicator in the hidden portion of your system tray, placing the icon for the Network Activity Indicator in the appropriate place in the system tray. If you'd like step-by-step instructions with pictures on how to do this, check out the via-link below to see the tutorial at The How-To Geek.
Once you've performed the swap, you'll have the old network activity indicator back and its familiar blinking screens. Network Activity Indicator for Windows 7 is freeware, Windows only. Have a little app that makes life easier? Let's hear about it in the comments.
Network Activity Indicator for Windows 7 [via HowToGeek]
source: http://lifehacker.com/5428229/get-the-classic-network-activity-indicator-back-in-windows-7
Sep 04, 2014 | Computers & Internet
Tip
How to connect to a wireless network with windows xp (must have a wireless...
  • In the start menu, click "Control Panel"
  • In the Control Panel window, click Switch to Classic View. If the text reads Switch to Category View, then you are already in Classic View and can skip to the next step.
  • In the Control Panel window, double-click Network Connections.
  • In the Network Connections window, right-click on the appropriate wireless network connection, and select View Available Wireless Networks.
  • In the Wireless Network Connection window, select your Wi-Fi (SSID)"Connect".
  • If you don't have a security code on it then In the Wireless Network Connection warning dialog, click "Connect Anyway" .
  • The Wireless Network Connection window will first indicate a status of Acquiring Network Address for your Wi-Fi, and a few seconds later will indicate a status of Connected. You are now connected to your router and can close the window.
on Jan 18, 2010 | Computers & Internet
Reset password on wireless router
That more than likely mean you have put the password in wrong or you are using the wrong authentication type.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the WirelessNetwork Connection and select Properties. When the Properties window openclick the Wireless Networks tab. Click on the SSID for your wirelessnetwork that you connect to and the Properties window will open. You canchange the Authentication Type to match the type set in your wireless routerand you can also change your password or Network Key to make sure you have itin correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left ofthe open window and click Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center thenlook to the left and select Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
Jun 08, 2012 | NetGear N300 Wireless Router
Thinkpad having limited to no connectivity
More than likely your password is wrong or the Authentication Type such as WEP, WPA, WPA-2 is wrong.
Click Start/Control Panel/Network Connections then Right Click on the Wireless Network Connection and select Properties. When the Properties window open click the Wireless Networks tab. Click on the SSID for your wireless network that you connect to and the Properties window will open. You can change the Authentication Type to match the type set in your wireless router and you can also change your password or Network Key to make sure you have it in correctly.
Click Start/Control Panel/Network and Sharing Center then look to the left of the open window and click Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
Click Start/Control Panel/Network and Internet/Network and Sharing Center then look to the left and select Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
May 11, 2012 | Lenovo ThinkPad T420 Notebook
Dell inspiron 8000 password authentication system
Are you talking about the authentication process on trying to connect using wireless?
That means you probably don't have the password or theAuthentication Type set correctly.
May 10, 2012 | Dell Computers & Internet
Cannot get the internet to work
That means you probably don't have the password or the Authentication Type set correctly.
May 08, 2012 | Computers & Internet
How do i set up my hp laptop to wifi
Please Understand wireless network settings and setup:
Wireless networks depend on special-purpose radio receivers and transmitters that substitute the exchange of messages over the air for the exchange of messages that occurs over wired connections on conventional networks. When you power on your PC, Windows Vista automatically searches for available wireless networks.
The network icon in the system tray, shown in Figure 1, enables you to view a list of local networks that Windows Vista detects. Notice that the network icon in this figure is marked with a red X, which indicates no network connection is currently established.
Figure 1: A red X indicates no network connection is active.
When you click this icon, a window opens indicating you're not connected to a wireless network, as shown in Figure 2.
hpsmb_laptoppcwireless-fg02.jpg Figure 2: The detail window for the network icon provides a link to create a network connection. The window also includes two hyperlinks: Connect to a network and Network and Sharing Center. Click the Connect to a network link to open the Connect to a network window, shown in Figure 3.
hpsmb_laptoppcwireless-fg03.jpg Figure 3: Connect to a network window.
Nov 10, 2010 | Computers & Internet
Drivers for ethernet card for gateway 6433 laptop
That unit has multiple drivers depending on os and original configuration as shipped. All are available at the mpcdrivers.com website at the following links.
http://www.mpcdrivers.com/sylvia/Support/gateway/VIWLAN2.exe - Windows Vista Intel Wireless Network Driver version: 11.1.0.86
Supports: Windows Vista (32-bit)
Note: This file contains the Windows Vista network driver for the computer models and components listed below.
3/13/2007
190,957 KB
http://www.mpcdrivers.com/sylvia/Support/gateway/VIWLAN.exe - Wireless Network Driver version: Intel 10.6.0.46
Note: This file contains the Windows Vista network driver for the Gateway notebook computer models and components listed below. English, Japanese, and Spanish installation instructions are included in the file.
2/7/2007
3,633 KB
http://www.mpcdrivers.com/sylvia/Support/gateway/LANFAQ.exe - LAN Windows Vista Driver Information
Note: This document explains the networking functionality within Windows Vista for the computer models and components listed below. English, Japanese, and Spanish instructions are included in the file.
2/1/2007
27 KB
http://www.mpcdrivers.com/sylvia/Support/gateway/BCM40100.exe - Broadcom Wireless Driver Version 4.100.15.5
Supports: Windows XP
Note: This is the Windows XP Broadcom Wireless driver for the Gateway notebook computer models listed below.
11/28/2006
77,858 KB
http://www.mpcdrivers.com/sylvia/Support/gateway/D00453-001-002.exe - Network Driver version: 8.26.2.3
Note: This is a Windows XP network driver for the Gateway notebook computer models listed below.
Apr 16, 2010 | SMC Realtec Network Card NERENC01
My Laptops Internet switch has stopped working
Then install your USB device with your CD
Then do this
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Nov 17, 2008 | Compaq Presario 700 470024-192 Notebook
I have a Compaq PC with Windows XP and the flat I've moved into has wireless broadband - how do I connect to it?
You can use a wireless network to share Internet access, files, printers, and more. Or you can use it to surf the Web while you're sitting on your couch or in your yard. Plus, it's easier to install than you think.
There are 4 steps to creating a wireless network:
1.
Choose your wireless equipment
2.
Connect your wireless router
3.
Configure your wireless router
4.
Connect your computers
For Windows XP users, Windows XP Service Pack 2 is not required for wireless networking, but it does make things much easier. Service Pack 2 also helps protect you against hackers, worms, and other Internet intruders.
If your computer does not have wireless network support built in, plug your network adapter into your USB port, and place the antenna on top of your computer (in the case of a desktop computer), or insert the network adapter into an empty PC card slot (in the case of a laptop). Windows XP will automatically detect the new adapter, and may prompt you to insert the CD that came with your adapter. The on-screen instructions will guide you through the configuration process.
Note: The steps below only apply if you're using Windows XP Service Pack 2. If you're running Windows XP and you don't have Service Pack 2 yet, plug your computer into your wireless router and download and install Windows XP Service Pack 2.
Windows XP should show an icon with a notification that says it has found a wireless network.
wireless_connected.gifFollow these steps to connect your computer to your wireless network:
1.
Right-click the wireless network icon in the lower-right corner of your screen, and then click View Available Wireless Networks. If you run into any problems, consult the documentation that came with your network adapter. Don't be afraid to call their tech support.
2.
The Wireless Network Connection window should appear and you should see your wireless network listed with the network name you chose. If you don't see your network, click Refresh network list in the upper-left corner. Click your network, and then click Connect in the lower-right corner.
wireless_chooseconnection.gif 3.
Windows XP prompts you to enter a key. Type the encryption key that you wrote down earlier in both the Network key and Confirm network key boxes, and then click Connect.
4.
Windows XP will show its progress as it connects to your network. After you're connected, you can now close the Wireless Network Connection window. You're done.
Note: If the Wireless Network Connection window continues to show Acquiring Network Address, you may have mistyped the encryption key.
Nov 05, 2008 | Compaq Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
