Question about WYSE Computers & Internet
I have Wyse V50L termimals that cannot connect to Terminal Server 2008. Connections from XP Remote Desktop Client work fine. The server is configured to not use Network Level Authentication. The V50L terminals can connect if the RDP connection is set to NT4 compatible however, this is not an acceptable workaround since we need support for device redirection (which does not work with NT 4 compatibility settings). Need to know what to do...
  • 25 Answers
Have you tried the latest V50L firmware version? There was a major revision lately?
http://www.wyse.com/serviceandsupport/support/downloads.asp
Posted on Dec 18, 2008
How do i network my home pc with a wyse terminal.
OK,
That makes sense.
1. Physical network - Depending upon the distance between the terminal and the PC you have the choice of either wired or wireless. It is probably easiest as you have wired cards in both the PC and the terminal and the PC to buy a LAN switch, or use ports on your DSL router (I am assuming that they are also connecting out to the Internet?).
so, plug the PC and the terminal into the switch/DSL router using CAT5 Ethernet cables (straight through ones).
Assuming that you have a DSL router that is handing our DHCP addresses, ensure that both the PC and the terminal are both getting addresses via DHCP. You can easily check this by opening up a command (DOS) window and typing ipconfig. Check that you have an IP address on both boxes (typically 192.x.x.x or 10.x.x.x ranges unless default DSL router config has been changed). In the DOS window on the PC type "ping <remote address you got from terminal>" - you should get a response back if all is well.
2. Now you have connectivity between the PC and the Terminal, you need to get a remote desktop capability if I understood you correctly?
You could use either Windows remote desktop (in XP it is called something like remote assistance). I prefer VNC as it is quick, lightweight and free. You can google this and download both server and client apps.
This should get you into a situation where you can remotely control / view your PC desktop on your terminal. You can of course map drives from one to another.
Let me know if the above needs additional clarification, if it helps please leave feedback accordingly
Cheers
Jan 24, 2010 | WYSE Winterm 3235LE Network Terminal
Port Forwarding On Linksys RV016
it's a rather lenghty explanation so please go to this site and follow the instructions...
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/
Robert
Please rate this solution ... thanks
Sep 08, 2008 | Linksys RV016 Router
Setting up Terminal Services on Server 2003 at the head office of a client in a workgroup environment, no Domain Controller. The branch office wants to log in through a VPN Router ( Linksys RV042 that has...
Assuming you can connect via Remote Desktop without any issues...
Printing through Terminal services requires that printing be enabled in the Terminal Services Configuration (Client Settings Tab). It also requires that the printer driver be installed on the Terminal server, not the actual printer (as it shows under the control panel) but just the driver. You can install just the driver by going to File/Server Properties under Printers and Faxes ON THE TERMINAL. Install the printer normally on the client machines.
Note: For a printer to work via Terminal services it needs to have a compatible driver (which I believe is called PCL??) So some consumer printers (the ones that only come with Setup programs, not just driver packages) will not work. The majority of HP Officejets and laserjets are fine, as are Brother lasers.
Oct 27, 2009 | Microsoft Windows Server 2008 Terminal...
Cannot detect other printer in remote desktop connection
Hello my friend, regarding on your problem kindly check your system particularly your windows 2008 server OS. Kind reinstall the printer drivers then then shared it. Then after you share the printers kindly check the ip address of your windows server 2008 OS then go to the workstation Computer then click start button found in your task bar manager then click run. Then kindly type the "\\IP of your windows server 2008" where your printer drivers installed then enter. As soon as you can log in the Windows server 2008 menu environment then if you can find or see the printer icon then click the printers icon then right click then click connect. Let the system automatically installed the printer driver to your workstation computer. then as soon as your system finished installed the printer drivers then try to run and print if you can now print using network LAN.
Hope this solution able to solve your problem. If you need more assistance kindly rely to this post.
Thank you.
geo_jonas
Jul 17, 2009 | Office Equipment & Supplies
Wyse S10 RPD to Server 2008
you have to buy 1 terminal license for you S10 also.
Apr 23, 2009 | WYSE S10 (90210501) Network Terminal
Wyse S10 and Windows 2008 Terminal Services
The Wyse S10s require a firmware update to connect to Windows Server 2008. This is due to lack of support for RDP 6.1.
The update I've found to work best is 6.4.0.18.
The only way to get this update is to contact Wyse. However, I have deployed it on numerous clients (our entire base is S10s) and had great success.
Nov 12, 2008 | WYSE S10 (90210501) Network Terminal
Conection to Microsoft Windows 2003 server terminal server
G key reset the unit, or failing that, re-image the device, and then setup your RDP connection from the default desktop.
Jul 09, 2008 | WYSE WT3235LE (902032-68) Network Terminal
Wyse v30 error on connection
could you give me more info plz
Jun 18, 2008 | Computers & Internet
Computers & Internet Logo
262 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
