Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Poulan pro 260
I have a poulan pro 260 While using it lost it's spark, changed plug not that. Upon investigation found coil pack messed up because screw came loose..Replaced coil pack with new one but still no spark. Not sure of adjustment of coil ack from flywheel or if something else is wrong. Please help
  • jfjt Feb 15, 2009
    Have not used saw in 6 years, Cannot get it to start. Only used it twice
    Thanks
    Joel
    Problem Solver:
  • 9 Answers
Clearance from coil to flywheel should be around .010
Posted on Oct 26, 2008
Poulan pro bvm200fe blower not getting fire
Make sure you have the correct plug. Use a spark tester and make sure you have spark. The air gap on the coil should be around .020". Also make sure the coil is grounded well on its mounting points. Usually corrosion prevents a ground and the coil will not produce spark. It is very rarely a coil failure.
Apr 05, 2017 | Poulan Garden
How to check coil moduel
Take a spark plug and put on the wire hold the plug on a metal part of the motor ,pull the starter cord and a spark should jump through the plug gap.
Oct 02, 2016 | Poulan Pro 220 Chain Saw Misc. Parts Lot,...
22 hp 2plugs 1 side not firing
Sounds like you may have a bad spark plug or coil..first remove the plug wire from the one not firing..using a rubber handled pliers hold the plug wire close to the plug tip or any metal part of the motor..and crank engine if you see a spark it most likely is the plug..pull the plug out and place the wire back on and do the same thing holding the plug close to the metal, if no spark change the plug..if none coil is bad..just follow the plug wire back to its beginning..the coil. It is attached by two bolts or screws,,check and see if they are tight and there is space between the coil and the flywheel..if it is loose or no space reset the clearance by using a business card as a gauge between the coil and flywheel and retighten and check for spark..If everything iis tight and clearance is ok..remove the coil and replace with a new..use the business card as a gauge...good luck.
Jun 27, 2014 | Poulan Pro 46Inch 22 HP Yard Tractor with...
My Poulan 260 pro starts and runs for 15 - 30 seconds and then dies. I have changed spark plug, replaced fuel filter, checked fuel lines. Any idea of what could be the cause?
If you have changed the fuel filter, and the hoses are not leaking, then you may well have a blockage in the internall filter in the carb, the filter is under the alloy pump cover, usually secured with a single screw.
May 14, 2011 | Poulan Garden
I have a 18 in poulan pro that want run. has new plug, air filter,gas filter
Check if is any "spark" at the spark plug.If not change the "coil" =spark plug cable and coil all are together.
Nov 09, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
There is a misfire in my engine, changed plugs & wires. now it reads that the fuel leveling sensor is bad, will this help?
If there is a misfire, the cylinder that it is misfiring in will be recorded as a code in the computer.
Have the car scanned to determine which cylinder is bad. Then, replace the coil pack going to that cylinder.
Ignition Coil Pack Removal & Installation 2V Engine To Remove:
  1. Twist the spark plug wires off of the ignition coil towers. Mark the spark plug wire positions so they can be installed in their original positions.
  2. Disconnect the electrical connector from the ignition coil. CAUTION
    When removing the spark plug wires, a slight twisting motion will break the seal and ease removal.
  3. Remove the mounting screws and remove the ignition coil.
To Install:
  1. Position the ignition coil pack on engine.
  3. Connect ignition coil pack electrical connector.
  4. Match previously marked spark plug wires to ignition coil and install.
4V Engine To Remove:
  2. Remove the screws and the water shield
  3. Mark spark plug wire positions
  4. Disconnect the spark plug wires from the ignition coil CAUTION
    When removing the spark plug wires a slight twisting motion will break the seal and ease removal.
  6. Remove the mounting screws and remove the ignition coil
To Install:
  1. Position ignition coil pack. Install mounting screws and torque to 56 in-lbs. (6Nm)
  2. Connect ignition coil pack electrical connector
  3. Match previously marked spark plug wires to ignition coil and install
  4. Position water shield and install screws
  5. Install RH cowl panel
Aug 11, 2010 | 2002 Ford Taurus
No spark on poulan 2055
1st try another good plug, if no spark, remove the pull start and you will see 2 small wires and 1 thick one going to the plug, disconect the one that has a spade conector on it (the other small one should be screwed down on to the coil) refit the starter and check for spark. if none replace the ignition coil/ module as one part.
Jul 01, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan Pro 18 inch saw. Once the unit is warm it
start saw when cold and work it hard. if it stalls or quits remove spark plug and hook the plug wire to the plug and ground to the cyl head have switch on and pull the start rop briskly a few times or use a test plug. if there is no spark disconnect ign switch from from the ign wires and pull rope a few more times.spark?= replace ign switch,no spark until engine is cool,replace coil.
Sep 23, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro 260 42cc. Need a manual.
For parts manual
http://www.ordertree.com/cms/Illustrated-Parts-List/64.html
Hi and low speed jets are both 1 1/2 turns open, fine tune from there.
Apr 01, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Where is the coil pack located under the hood
Follow the spark plug wires away from the spark plugs. The coil packs are on top of the ignition module. The coil packs have two terminals each and will have two spark plug wires attached to each coil pack. There are 3 coil packs and I would recommend replacing all three at once. They are bolted down to the ignition module bracket with a total of 6 small screws. Two per coil pack. Remove the small screws and the electrical connectors and the plug wires. Dont forget to mark the wires so you can replace them as you found them. Installation is just the opposite of removal.
Jan 20, 2009 | 1995 Oldsmobile Cutlass Supreme
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
514 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
