Question about Uniden Radio Communications
How to remove the letters RX near the battery so u can talk to another person It's a Uniden hand held receiver model-uh043sx-2
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Hi Phillip,
The Rx symbol indicates that someone else is using the channel, which, (if your radio is working correctly) means you should be hearing them, if this is the case then there is nothing you can do to change that, because only one person at a time can use the channel at a time, however, as we\'re talking about CB radios, that is not always the case, dependant on the make and model of the radio in use.
In the case of your radio, not much can be done, as that is a factory default setting, so you can\'t override this without getting into the unit and risk stuffing it up period.
If you know someone in the 2-way radio game i.e,. a radio technician, or radio amateur, they could help, otherwise you can\'t do much about this.
If this is a real problem for you, then getting a bigger 5 watt radio could be an answer, as these are normally set by default to allow you to override the Rx when you Tx.
Note: Don\'t buy a Chinese made unit, as these are not reliable, nor stable units for Aussie use, I found this out when I purchased an Oricom CB... Absolute crap, cheap and nasty. Be aware of where radios are made, regardless of brand name.
I hope I have been of assistance.
Regards,
Peter
Posted on Mar 04, 2013
2 Suggested Answers
vrc_tech
  • 109 Answers
SOURCE: Uniden VHF Hand held Radio HH940
There are several avenues for you. 1. do a serch on ebay for the battery. 2. try your local two-way dealer or 3. go to Unidens web site.
Pat
Posted on Aug 20, 2008
Uniden uho43sx 2
rx means its in receive mode, what happens when you push the PTT (push to talk ) ?
May 24, 2014 | Radio Communications
Where is the tab to open the battery compartment?
I see you have a Uniden, but what model number, Uniden make numerous Hand Helds as well as CB Radios and Commercial 2-ways.
Without the model number I am only guessing, and that's not helping you.
Please reply with the model number and I'll find the answer for you quickly.
Cheers,
Peter
Dec 30, 2012 | Uniden Radio Communications
How to remove RX icon on Uniden UH038SX-2
The RX indicates that it's receiving, as opposed to the TX when it's transmitting. It's normal for one of them to appear on the screen whenever the unit's turned on.
If you need a manual, you may download a copy here.
Sep 14, 2012 | Lands Phones
I have an older Uniden PowerMax 5.8 and the handsets are old and one is held together with tape. The second hand set was rained on yesterday. It was sorta working but I worried i would short it out if I...
Hello, Terrie.
Sorry for the delay in responding - time zone difference.
First, let's see if we can fix your handset (from Uniden):
1. Remove the battery cover and leave it off for ventilation.
2. Remove the battery pack by disconnecting.
3. Leave the battery cover off and the battery pack disconnected for at least 3 days.
4. Once completely dry, reconnect the battery pack and the battery cover.
5. Recharge the handsset's battery pack for 20 hours in the base unit before using the phone. IMPORTANT: You must unplug the telephone line while recharging the battery pack
to avoid charge interruption.
I believe there is a way to export your phone book to another handset, but not without reviving your original phone. Unlike a cell phone, there is no memory card to remove and transfer.
Let me know what happens.
Hope this helps.
Oct 06, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
My uniden ltd 715 receives from my handheld but when I transmit to handheld it just buzzes.
Just to clarify something, you say that your hand-held VHF can receive a clear transmission from the Uniden, now which of the radios are buzzing, the Uniden or the HH?. If it's the hand-held buzzing try transmitting on the low watt on the Uniden, get some distance from the radio, because if the hand-held are to close to the on the Uniden on high watt you will get a buzzing, the signal are overpowering the receiver of the hand-held, try getting the minimum of 30 feet away. Good luck.
Mar 24, 2011 | Uniden Solara DSC VHF Marine Radio
My UH043SX-2 seems to be stuck on RX, I can talk on it but not hear an answer.
We have 6 of them all with the same problem. Uniden says to turn off holding down the mon and scn buttons. Then hold down the mon and scn buttons together for 20 secs. Then turn on holding down the mon and scn buttons at the same time. Then turn off and turn on again. This should clear the problem. It didn't for me so I threw them away and bought some more. I think that would have been easier than all the other stuff!
Dec 01, 2010 | Uniden Hand-Held VHF 2-Way Marine Radio
I have a uniden bearcat hand held scanner sportcat, which for some reason has lost its memory, is there any way to program it
You didn't specify the model number of your scanner, so here's a link to a list of available Uniden scanner manuals. If your model number is listed, just click on the "Product Details" column to download/print the manual. It will provide detailed programming instructions.
http://www.uniden.com/index/manuals_results.cfm?cat=3
For a comprehensive database of active frequencies in your area, visit
www.RadioReference.com
Dec 31, 2009 | Uniden Hand Held Scanner - BC-246T 2-Way...
Uniden uh064sx-2 2-Way RX Stuck On
Didyou have any luck resolving this issue? We currently have exactly the same problem
Aug 05, 2009 | Uniden GMR1038-2 (7 Channels) 2-Way Radio
Radio Communications Logo
242 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
