Question about Epson PowerLite 5350 Multimedia Projector
5350 ghosting problems
What can be done to correct ghosting or blurring on the screen?
Screen has a problem when flipping through apps previous image stays on screen kind of blurred out
It is called ghosting and has been a major issue for the Mini thus far (even though it hasn't been reported in the MSM).
Play with your settings to find a way where it effects you less-- screen brightness, motion detection, reset the device and restore to original settings (but back your Mini up first!).
Dec 12, 2013 | Apple iPad Mini with Retina Display
Viewing Screen White Out
this seems to be a fault with the CCD of the camera
you will have to make a major repair
Sep 17, 2008 | Fuji FinePix A345 Digital Camera
Ghosting on DELL 2007WFP
what connection do you use?
if this only happens when you browse web pages with java or dynamic content or when yo play games check in your graphics card drivers that you have not forced anti-aliasing, try also updating direct x
Jul 24, 2008 | Dell UltraSharp 2007WFP Monitor
The picture is blurred and ghostly. Sometimes it's fine but then it reverts to blurred again. The picture is very red as well.
Good day!!! That problem is usually cauase of bad t-con board please try replace it to end this problem.. Thanks for using fixya..
Sep 13, 2011 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
My Toshiba 42" has 3 black lines on right half of screen about 3 inches apart starting from the top, right side blurs and ghosts when playing. Is this a main screen problem or a board?
panel its dying :( sorry better get new one :((( you still can try with the old one some time the cables that control the the rows get unglued you can try heating them and reg glue them
Good luck
Sep 26, 2010 | Toshiba Televison & Video
Pictures get ghost image & colour veriation
You get a picture with sharp and correct colored parts as well as parts blurred with wrong colors?
I assume this only happens indoors, when you use the flash?
It sounds like you are using Slow Synchro flash mode.
Try switching the flash mode to Auto instead.
May 04, 2010 | Fuji FinePix S7000 Digital Camera
I just got this hitachi 50v500 from a friend. We had to have a lamp fixed, but now the screen is blurry, like the ghost shadow problem I've been reading about. The repairman who replaced the bulb said...
There is a specific method for ghost adjustment on the 50v500.
Ghosting is most noticeable on lettering or with the set in the 4X3 format the edges will look somewhat double or have a ghost.
If this is what you have: I have the process which is done with the Hitachi remote to correct this. I got this from Hitachi who published a service bulletin on this problem for this model.
SD TECH
Mar 19, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
My Epson Powerlite 5350 has a ghost image. Any recommendation on how to adjust the projector to remove this symptom?
I've got the same problem on two Epson EMP7300.
I believe (from reading about other projectors) that the ghost image can be adjusted with RS232 codes.
Does anyone know how to do this?
Jan 24, 2010 | Epson PowerLite 5350 Multimedia Projector
Showing to of the same thing and colors
ghosting or convergance issue is what u have. if the image is in diff colors then deff a convergence issue. however, if the image isthe same color or shaded from the original then this is ghosting. this may be corrected through the menu settings(sinc settings).
Jan 15, 2009 | Toshiba TLP-380, TLP-780, TLP-781UF...
Epson PowerLite 5350 Multimedia Projector Logo
70 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
