Question about JBL On Time 200iD iPod Dock/Clock Radio OT-200IDBLK Speaker System
How to dismantle jbl on time 200id
Because the IR receiver is not working, who knows the screw holes?
3 Suggested Answers
  • 4102 Answers
SOURCE: my i pod no longer charges when i plug it in the
Hi, this is a very common problem, its to do with all the little contacts on the dock that are causing it not to charge, over time and use these little thin metal contacs become warn and you then lose the connection with the device,
check the contacts on the ipod itself first make sure they are totally clean and no fluff or bits of rubbish are blocked in the port.
then check the docking station make sure its off with no power going to it then have a good look to see if you can see the contacts its not easy to fix or even see so you may need a good magnifying glass, so once you have one of these have a good look at each contact and make sure their is no fluff or anything else on one of the contacts, if their isnt then try the following.
make sure docking station is off and has not got any power going to it then using a magnifying glass have a real close look at the contacts then get a long pin and touch each of the contacts as if your tryin to scrape them clean with the pin, then give it a try, now if this still dont work the only other option to try and get it working is to only very slightly bend each pin so its connects with the ipod so if you have a close look at each one and bend it only very slightly outwards then give it a try again, doing this usually gets its working but if you bend them to much they can break and it will then be no good what so ever.
so have a go at fixing it but if it wont fix then the chance of getting it repaired is pretty slim.
let me know how you get on or if you need further assistance ok
Posted on Feb 07, 2011
SOURCE: My JBL On Time 200iD does not allow me to search
You need to change the radio type to Europe, by default it is US. Check the manual on how to do this.
Posted on Sep 11, 2009
How Dismantle jbl on tour
First you need to remove the sliding door. You can do this by opening it and lifitng one side with a screwdriver like on one of the pictures.
After that you can remove the battery cap and batteries.
Than you will need to remove the JBL logo. This is quite tricky. because it is glued.
After that you can remove all the torx screws and open the device.
http://imgur.com/a/Czyat
I damaged mine because I didn't have proper tools. Fixed the speaker though.
Aug 12, 2012 | JBL On Tour Computer Speakers
I have bought jbl on time 200P dock station for ipod with radio but all the freq in radio is odd numbers and i need to change it to even numbers
Hi. Try this: change your language settings to a European language. After that you can choose your radio type: choose Europe. Exit the menu. Now you will be able to choose radio stations with two decimals, for example fm 88.15. I hope this solves your problem.
Sep 05, 2011 | JBL On Time 200iD iPod Dock/Clock Radio...
I bought the JBL 200ID and I love the sound but I have had two of them now and it will pause itself and go to another song in the middle of one. This is the second one that has done this. Has anybody else...
I have the same unit and have the EXACT same problem - random pausing and resuming from an intended pause, and skipping songs at random. I only experience this after I have used the remote to PAUSE the music. And when I have the problem, only way to reset it back to reliable behavior is to pull the plug and leave power off it. It's a firmware problem, nothing to do with the connection. I've tried it with 4 different Apple devices ranging from 2nd GEN NANO up to various models of iPhone including the 5. They all do it, BUT only after I use the remote. The remote is IR based and I do not have it even close to pointing at the base as I thought maybe it was a stuck key on the remote. It's the base and it has a glitch in the firmware. Unfortunately it's not patch-able, we just have to live with it.
Jan 08, 2010 | JBL On Time 200ID High-Performance Speaker...
After I set my my time minutes, the AM PM
You are probably in 24 hour mode. You only have the option of settting AM/PM if you are in 12 hour mode. In 24 hour mode, you set a time in the afternoon by scrolling to 13, 14, etc.
Jun 29, 2009 | JBL On Time 200ID High-Performance Speaker...
I have a JBL MR-17.2 Sirius Ready stereo
To get your Sirius ID number from you MR-17 JBL stereo, select the Mode button until it displays "Sirius". Then push and hold the Mode button for a couple seconds and it will chirp and display 3 blank spaces. Enter three zeros, "000" in these 3 spaces. The Zero is the loud button labeled "LD". When you do that, it will display your Sirius ID number. :)
May 13, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
Can you repair a broken ipod connector on the JBL On Time?
Yes it can
Fullers Electronics on 01728 746400
The board part number is: ZDTIMEWT0100G
Apr 05, 2009 | JBL On Time 200iD iPod Dock/Clock Radio...
JVC HD-61G787 IR receiver location
I took the front of the tv off. the IR receiver is beside the lens. I stuck the IR emitter directly on the receiver and reinforced it with hot glue and then fed the cable out through the back off the tv. Not a hard job just lots of screws.
Dec 13, 2008 | JVC HD-61G787 61" Television
JBL On Time 200iD iPod Dock/Clock Radio OT-200IDBLK  Speaker System Logo
1,091 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
