Question about BSA Optics
Owners manual for bsa sweet 223 scope
Need operating manual for this rifle scope
SOURCE: BSA rifle scope
its a metric 1.5 for the cam adjustments
Posted on Jan 15, 2008
  • 152 Answers
SOURCE: how do change the battery in a BSA HD42SB
It should be seated inside the windage knob, if not look for a slotted type indentation in one of the knobs, and turn that cap counter clockwise with a coin that fits snugly in the slot while holding the sides of the knob.
It will be a pancake style battery.
Aduz
Posted on Mar 30, 2009
fps353535
  • 99 Answers
SOURCE: lost manual for trophy scope 3-9x40 rifle
There is no manual for elevation and windage adjustments. (at least not one that comes with your scope; all your scopes manual will say is whether its FFP or SFP (First Focal Plane or Second Focal Plane, the scale used on your scope for mil dots)(you can get this info by finding a store that sells this scope and asking a sales rep)
To adjust for elevation and windage you have to take into account the daily factors (unless your shooting in the same indoor environmental controlled shooting range each day you SNOB! jk
The formula takes alot of variables into account and is known as Exterior Ballistics
!) Environmental Factors - First thing you account for.
A) Elevation from sea level plays a large part into your environmental adjustments. Your elevation from sea level determines largely the Barometirc Pressure but it also varies slightly with Temp and Humidity (Major Factor)
B) Temperature - The temperature can affect the density of the air. The hotter it is the thinner it is and therefore less resistance and a higher bullet trajectory (Minor Factor)
C) Humidity - This again will affect the densify of the air infront of your bullet (Minor Factor)
D) Barometric Pressure - The other large factor in air density this is the base stat that the others modify
These all combined create a ratio that you apply to standard MOA (windage and elevation adjustments) to obtain the shooting information for that particular environment)
2) Bullet Factors (Listed on the Box you buy) - There are a few bullet factors to take into account.
A) Speed - the bullets feet per second can vary as much or more than 500 feet per second with the
same caliber ammunition.
B) Grain - The Grain of an ammunition is a measure fo its "Sectional Density" or weight to volume
ratio
C) Ballistic Co Efficient - This number is the measure of the bullets ability to maintain its speed
during flight. This also varies from Grain to Grain
These factors are complex and a pain for the best of shooters to determine. adding to that confusion. there are many ways to determine a bullets ballistics coefficient and each one gets a different number. In this case bullet data is best retieved from the manufactuerers box and take their word for it.
3) Lastly you account for shot factors.
A) Range - by referencing your standard elevation MOA adjustments and mutliplying by the ratio for environment the Elevation MOA is achieved.
B) Windage - Windage is done in inches per mile per hour then is multiplied by the Mph of the wind.
In order to be precise the windage is done in inches instead of MOA. it needs to be converted heres and example.
You Ballistics Cheat Sheet for the day says the windage at 900 yards is 5.2 Inches per mph of wind.
you apply the ratio for your environment .90 (all example numbers. this number would represent a shooting environment with an air density lower than standard/ the cheat sheet's known MOA adjustments). the 5.2 inches is multiplied by .9to acheive 4.68?? idk the point is you mulitply that by the wind of 10 mph to achieve a total of 46.8" of wind drift to the target.
now for the conversion to MOA. 1 MOA is eqaul to 1.047" per 100 yards. meaning for every 1 moa you adjust the bullet will move 1.047" per 100 yards (our target is 900 yards; meaning that each MOA for this target is 9*1.047" = 9.423" per MOA adjustment. so take that number and divide our total wind drift by it. ie 46.8 / 9.423 = MOA Windage Change of 4.9665... now you need to know whethere your scope is 1/4 minute clicks or 1/8 minutes (how many spaces between large numbers?) you would adjust to 5 MOA for a 1/4 minutes scope equaling 20 clicks on an 1/8th minute scope it would be 40 clicks.
This is the math of shooting. to learn how go to
WWW.shooterready.com they are an excellent sight to get the math down WITHOUT wasting ammo. Once you have the math you an transfer it to your gun. waste a few rounds checking it out and youll be hitting targets @ 1800 yards in no time
I like to take the simple way after i learned how to do the hard way
There is software tha will do the exterior calcualtions for you.
if your interested i use Sierra Infinity V6 Ballistics Software
GL
Posted on Apr 08, 2009
  • 81 Answers
SOURCE: I'm looking for a manual or instructions for a
your best bet is to locate your local shooting club and ask someone experienced with specialist scopes. As for now, all I can suggest is to sight the scope in at 3x power. I'm not sure about a boresight on this scope, since is is at the extreme budget end of zoom scopes. If you mean it has a rangefinding (or ballistic) reticle, then you might try here: http://www.perry-systems.com/reticle_analysis.htm for basic usage guide. The reference distances will vary according to several factors, including but not exclusively: bullet weight, muzzle velocity, firing angle, windage adjust, wind direction.
Posted on Jul 21, 2009
SOURCE: need a manual for a simmons rifle scope model #
When you click on "customer service" on the simmonsoptics.com website, it takes you to the Bushnell customer service web page.
The number for customer service that is given is:
1-888-276-5945
The customer service rep. told me to "go to the Simmons web page".
Which, of course, takes me back to the Bushnell web page. It's a circular race track.......
In my opinion, Simmons/Bushnell has lousy customer service.
I bought a 2nd hand Simmons 3-9X50 scope (model #800479) that needed the screw on caps for the reticle adjustment screws. A small request, I thought.....one that should be easily remedied by calling Simmons/Bushnell customer support.
No dice. Customer support told me to spend $15 to send them the scope, and then they "will have to look around and find something that will fit."
Oh really??? Doesn't Simmons/Bushnell already KNOW the sizes of the parts they have?
Just send me the damn caps. They will cost Simmon/Bushnell no more than a buck apiece.
Then I asked for a user manual for said scope. No dice. The customer support lady told me to find the manual on the Simmons web page.
The Simmons web page doesn't provide user manuals online.
Their customer support needs a lot of improvement.
Posted on Oct 27, 2009
I have a BSA point 22 carbine air weapon circa 1990. Could you tell me what the name of the carbine is?
Hello Jean
It is likely to be a BSA Meteor or a BSA Airsporter. I am from Birmingham UK and owned one.
Here are a number of links for you which will help identification. I will put the Google link at the very bottom of the post which lists a lot more info. Write back as a COMMENT below my post if you need any further help. I am one of the air weapon experts.
  • 1990's Air Shot Corp./BSA Catalog, Vintage Gun Catalogs www.vintageguncatalogs.com/product_info.php?products_id=57 Circa 1990 Air Shot Corp./BSA Catalog,8-1/2" x 11" with 6 pages Content: ... Air Gun Catalogs. Air Arms; Beeman; Benjamin; Brno; BSA; Crosman; Daisy; Feinwerkbau ...
  • History & Ethos ' BSA Guns - BSA Air Rifles bsaguns.co.uk/about/history.aspx BSA Guns; History & Ethos; Production ... 1962 Introduction of Merlin air rifle; 1962 Introduction of Armatic .22 self ... and Airsporter Carbine air rifles; 1990 ...
  • BSA - John Knibbs International Ltd - Airgun Spares www.airgunspares.com/store/content/87/BSA Superstar .22 : 1990 - 2004: R22: R - 10 MK1 .22 : R77: R - 10 MK1 .177 : ... BSA Standard No2 Air Rifle .22: 1936 - 1939 : T: Ralock Self Loading Sporting Rifle .22 ...
  • BSA .22 Air Rifles and Pellets ' Wonderland Models https://www.wonderlandmodels.com/bb-air-guns/air-guns/rifles/bsa BSA .22 Air Rifles and Pellets. Wonderland Models are an Online Model Shop specialising in BSA .22 Air Rifles and Pellets and ... BSA Rifles Meteor Evo Air Rifle.
  • JC Militaria ' Air Weapons www.jcmilitaria.com/air_weapons.asp?Start=10 At JC Militaria we stock a number of Air Weapons. ... 22 Calibre Bolt Action Single Shot Air Rifle ... BSA launched a centenary air rifle to ...
  • BSA Air Rifle Combinations - The Airgun Centre https://www.theairguncentre.com/rifle-combinations/bsa BSA Guns are at the cutting edge of Air Rifle design and manufacturing and have a history going back over 150 years.
  • Blue Book of Airgun Values - BSA GUNS (U.K.), LTD. RIFLES ... bluebookofgunvalues.com/Airgun_Values/Airgun_Manufacturer_Models... ... LTD. RIFLES: MODIFIED REAR/UNDER LEVER COCKING airgun ... RIFLES: MODIFIED REAR/UNDER LEVER COCKING . ... faucet tap loading, Marked: "THE BSA AIR RIFLE ...
  • http://www.bing.com/search?q=BSA+22+air+rifle+circa+1990&FORM=HDRSC1
    Jul 05, 2016 | BSA Optics
    Mounting
    Any scope will mount on any rifle using the appropriate mount and ring combination. It shouldn't be a problem to mount it on your savage.
    Mar 27, 2014 | BSA Sweet .17 Rifle Scope
    The head of set screw and the threads it follows on the elevation adjustment are banged up how can I get it out
    You might need to buy a kit that lets you drill out the top head and use the kit to back out the screw. These are available at most hardware store.
    Oct 15, 2013 | BSA ® 2 - 7x32 A/O Sweet 17?? Rifle Scope
    Sticky coating bsa sweet 17 scope
    Has been contaminated with a petroleum based solvent
    Jan 16, 2012 | BSA ® 3 - 12x40 IR Sweet 17?? Rifle Scope
    Not really a problem. Just looking for a manual so I understand how all of the adjustment functions work.
    Have you tried contacting BSA directly? I searched for an on-line manual which you may have also.
    I didn't have any luck, but I do know they provide on-line manuals for many of thier products.
    E-mail them from the link provided below and you should get what you need.
    Here is the direct link to thier customer service contact info.
    https://www.bsaoptics.com/Contactus.aspxe.
    hope this helps you!
    Apr 08, 2011 | BSA ® 2 - 7x32 A/O Sweet 17?? Rifle Scope
    I have age 3by9by40ir scope. it has a illuminator red dot in crosshairs .problem is need to use much strength to turn on.any way to fix? scope is brand new. somewhere to send?was achristmas present. use...
    I've never had that problem with my scopes, but BSA's customer service department welcomes questions and comments. I bet they'll have some good advice. Here's their contact information:
    954-581-2144 (Monday - Friday 8.30am - 5.30pm EST)
    BSA Optics, Inc.
    3911 SW 47th Ave. Suite 914
    Ft. Lauderdale, FL 3331
    Jan 22, 2011 | BSA ® Huntsman Series?? 3 - 12x50 Rifle...
    I inadvertantly changed my elevation adsjustment.
    this is an excellent article on zeroing a scope.
    http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
    Apr 06, 2010 | BSA ® 2 - 7x32 A/O Sweet 17?? Rifle Scope
    BSA 3-12 x 50 Rifle Scope
    But a new scope. Having the crosshair reseated will cost you more than getting a new BSA scope.
    Feb 16, 2018 | Science & Laboratory
    BSA rifle scope
    Nov 11, 2007 | BSA Big Cat 3.5-10X 42mm (3.5-10x42 mm)
    Optics Logo
    184 people viewed this question
    Top BSA Optics Experts
    Joe Lalumia aka...
    Joe Lalumia aka...
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a BSA Optic Expert? Answer questions, earn points and help others
