Question about Casio HR-100TMPlus Calculator
How to change ink roller in casio HR-150TE Calculator
SOURCE: CHANGE TAX %+ & TAX- ON MY CASIO JF-100TE CALCULATOR
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Posted on Jan 26, 2008
  • 374 Answers
SOURCE: casio calculator HR 100 Tm
Printing models (except HR-8TE):
1. Have calculator in “print” mode
2. Press [CA]
3. Hold [SET/%] key for about 5 seconds
5. Press [TAX+]
6. Press [SET/%]
Posted on Apr 06, 2008
SOURCE: can not load paper
Solved by itense perseverance!
Posted on Feb 13, 2009
SOURCE: how do I change the ribbon on my casio hr-8tm calculator?
Place the roll on the wire thing at the back (I don't think it matters which way round); push the paper through the slot at the bottom of the back and then (having taken the clear plastic cover off) push it along the bottom inside at the back as far as you can then start to press the feed button; keep feeding it with your finger and pushing the feed button asnd it should pick up eventually.
Posted on Feb 23, 2009
SOURCE: CHANGING THE VAT SETTING ON HR-8TEC CALCULATOR
1-press and hold "SET/%" key 2- "set" will appear on screen 3-press "tax+" key 4-type tax amount ie 17.5 5-press "set" key to complete done.
Posted on Sep 04, 2009
Testimonial: "Many thanks. A simple task but without the instructions, difficult. I have saved the instructions so when vat goes back to 17.5% I can change it back."
Casio HR-100TM. is there a demo step by step on replacing ink.
The ink supply is a small roller. Remove the clear plastic cover over the (printed) paper and the roller will lift out. It only takes a couple minutes to do the job. I suggest not wearing anything white as you will probably get a little ink on your fingers.
Nov 23, 2016 | Casio HR 100TM Portable Printing...
How do I change the print head on HR 100TM casio calculator
You grasp it and then pull as hard as needed to remove it. next, shove the replacement into the space the removal revealed. Easy. huh?
Mar 18, 2016 | Casio HR100TM 2-Color Printing Calculator
Replace ink roll for Casio 100TM
Should just be a matter of lifting up the lid, removing the old roller and replacing it with a new one. That's how mine works.
Oct 10, 2014 | Casio HR-100TM Two-Color Portable Printing...
How do I replace the ink cartridge on my Casio H R 100TE calculator?
Remove the plastic window where the paper comes up. See the printer ink roller on the right side. Lift it up and replace.
Sep 16, 2013 | Casio HR-100TEPlus Calculator
Casio hr-100tm ink roller
Check to see whether a fragile plastic roller pin or retainer has broken off. Also, a piece may have fallen out when the old roller was removed.
Aug 30, 2012 | Casio "HR-100TM Two-Color Portable...
What ribbon cartridge do I use for HR-8TM Casio Calculator
  • Nu-Kote NR42 Compatible Ink Roller
  • Single-Ply Adding Machine/Calculator Roll, 16lb, 2-1/4"x150
Mar 04, 2011 | Casio HR8TM Calculator
How do you change the ink ribbon?
One the right hand side of the ink roller there is a little tab on the plastic, if you put your finger under that tab you can easily lift out the ink roller & replace it with the new one.....it snaps into place.
Jan 14, 2011 | Casio HR-100TMPlus Calculator
Need help w/ink
Hi...This calculator takes a IR-40T ink roll.
Turn off the power.
Open the top cover,
There is a flat tab on the ink roller, lift up, remove.
Hold the new roller by the tab, line it up in the slot and snap in.
Turn on the power and test.
If it doesn't work you might not have it snapped in properly or all the way.
Good Luck........
Squipps
Jan 08, 2008 | Casio HR-100TEPlus Calculator
Casio HR-100TMPlus Calculator Logo
244 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
