Question about ViewSonic P775 Monitor
Fix the monetor view to horizontal view
I want to know how can I return the monetor's view to regular. It become horizontally instead of vertically, therefore, it is possible to read or work on the comp unless I turned it up side down.
Orientation can be changed to landscape mode by accessing the video card properties in the windows "Control Panel".
Posted on Dec 16, 2008
2333 sw modeline
Samsung SyncMaster
Part Number: LS23CMZKFV/ZA
Product Line
Samsung SyncMaster
  • Native Resolution Full HD (1080p) 1920 x 1080
  • Contrast Ratio
    1000:1 / 20000:1 (dynamic)
  • Color Support
    16.7 million colors
  • Horizontal Viewing Angle
  • Vertical Viewing Angle
  • Brightness
    300 cd/m²
  • Horizontal Refresh Rate
    75 kHz
  • Vertical Refresh Rate
    61 Hz
  • Max H-Sync Rate
    75 Hz
  • Max V-Sync Rate
    61 Hz
Dec 18, 2017 | Samsung SyncMaster 2333SW 23" LCD Monitor
Monitor viewing position
what model of monitor do you have..?
May 18, 2008 | Philips Brilliance 107B 17" CRT Monitor
Im seeing duble words,how can i fix it?
There should be a convergence adjustment on this set. It will have a "cross hair" type pattern
You adjust the beams so that the cross hairs turn white. I believe Green is not adjustable intentionally. The procedure is to adjust the vertical Red line until it alligns with the Green line. Then adjust the vertical Blue line until it lines up with the Red and Green. The line should turn White.
Repeat the procedure for the horizontal lines. When you return to regular viewing mode the double
images should be greatly reduced or eliminated..
Hope I've helped you,
Best Regards,
Dec 30, 2010 | Panasonic Televison & Video
Picture appears only as a thin, horizontal line...
chk vertical amp /vertical drive i/p from oscillator/power to it/power to vertical amp/chk dry joints-hot area/look at vertcal amp capacitors-swelling etc
Jul 04, 2009 | Akai Televison & Video
Info on lenovo 0768 laptop screen is vertical instead of horizont
try ALT>+<CTRL>+<ARROW>­ three button at a time. the arrow you press, screen should go on that way. It works on most of the pc s. Should work on you too.
Please Rate me if it works.
Apr 19, 2009 | Lenovo 3000 N100 Notebook PC
ALL the next is with the tv unplugged (NO NO power)
  • resold the jungle (video processor) all around
  • following the horizontal drive pulse path and arriving to the horizontal area just after the horizontal transformer and in the base of the horizontal DRIVER there is a electrolytic capacitor (if this chassis uses this one,) Change it (maybe is dry)
  • solder all components i just told you in the last step. horizontal driver, transformer, etc
  • remember:
  • if a transistor is blowing with no reason (there is a reason: the collector receives 130 volts but cannot hold it forever, It has to be in some place. if the switching pulse doesn't arrive to it the transistor throws this 130 volts and burning itself. i hope it is help full.
Apr 15, 2009 | Televison & Video
Monitor is vertical display instead of horizontal display
the keys ctrl+alt+right arrow should do the trick for you. if not then right click on the keyboard and select properties for options and you will find your graphics software has its own rotational software. good luck with two year old, sounds like you'll need it.
Feb 25, 2009 | Dell Computers & Internet
My desktop background is horizontal instead of vertical
u have the intel video driver try to ctrl + the arrow where u wanna rotate it
Dec 26, 2008 | IBM NetVista A30p PC Desktop
Hi...there! Kazz,
Go to your toolbars bottom R/H corner and look for the VGA settings icon ( nVidia or ATI). Right click on that...and look for rotation settings, from there just followed the settings... Have nice day!
Oct 10, 2008 | ViewSonic VA902 19" LCD Monitor
Weird TV
the audio is perfect, but the screen vertically squeezes to about a quarter of an inch and stays horizontally regular. it is due to vertical section of your tv has failed. it is a common problem if you are not a tech person call tech to fix it. solution 1 check vertical section supply. 2 check components in vrtical output stage. 3 check vertical output ic. 4 loose contact in vertical section it is not a major ptoblem. good luck.
Oct 06, 2007 | Panasonic CT25G7 25" TV
ViewSonic P775 Monitor Logo
85 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
