Question about Toshiba Satellite X205-S9349 Notebook
I need help on how to open the battery door & find out exactly which new battery I need to buy
Seems I left my laptop plugged in too much? So, even with help from COSTCO concierge to discharge it completely and recharge it by powering it up, it won't hold a charge for long.
I moved the tab in the direction of the arrow on the battery compartment, labeled:
NICKEL-CADMIUM
NICKEL METAL HYDRIDE
AND/OR LITHIUM/ION BATTERY
and I can't get it to open.
Questions:
1. How do I open the compartment? When I slide the tab and try to pry open the compartment at the other small opening, nothing happens.
2. Do you know which battery I need?
3. Who has the best price on new X205-S9349 Toshiba batteries?
4. How do I not fry the next battery? How long am I supposed to leave it plugged in and when do I unplug it? Please explain this part so I can do it right with the new one.
I truly appreciate your help.
Roseann
    Genius:
  • 1,913 Answers
It is cmos cell batterty.
it is nearly RAM.
Posted on Oct 25, 2008
My samsung rv511 wont charge at all even though the charge is on, seems like something inside it might be wrong but I don't exactly know what?
You will need to replace the battery. Laptop batteries lasts approximately 3yrs. This can be significantly reduced if the laptop remains plugged in most of the time.
Feb 14, 2014 | Samsung RV511A01 Notebook
Laptop Won't Boot
You'll need to troubleshoot your laptop in order to know what the exact problem is. First try to plug it in with the battery on and try turning the laptop on. Next would be to remove the battery and plug the computer. If this doesn't work then it's definitely the AC Adapter and you'll probably need to call toshiba to purchase a new one from them or if you're still under warranty then have it replaced. They also have some qualifiers on whether an AC adapter or battery is qualified for replacement even if it's under warranty. Just call them on 1-800-457-7777 and ask their technical support reps about this.
Sep 17, 2008 | Toshiba Satellite A105 Notebook
Kenmore Ultra Wash Dishwasher door won't open
It seems most likely door latch stock and you going to need buy new door latch as for stock one most likely you hsve to forceit to open and replace it with new one
Dec 09, 2013 | Kenmore Dishwashers
Acer 5733 will not turn on
No solution, mine does the same exact thing but blinks orange five times. I got an error message that said click to fix it. I did it and the computer tried to reset itself but simply died. With brick cord out...nothing happens. Same with battery same with power cord in. The battery was fine. It may have died during a forced windows update. I hope someone comes along otherwise it's "buy a mobo" and buy a battery and so on....
Sep 06, 2012 | Acer Aspire 5733Z-4633
Dell studio 1535 not charging
Without testing the complete power circuit there is no way to know what needs replaced. the motherboard will most likely cost as much as a new laptop though. They are like the LCD screens. You can buy a new laptop for 4450 now days but to replace a motherboard or LCD screen you'll pay $500 to $700 not counting labor.
Jul 26, 2010 | Dell Studio 1535 Notebook
Left solstice in garage 6 months when i whent to open door battery was flat had to open door with key manualy alarm whent off since then car does not drive well any sugestions
Hi
Have you put new fuel in the car? fuel left for 6mths wont be very good. and most likely will need a service, new plugs etc etc, change the oil and check the battery connections.
Hope this helps
Regards
Dan
Feb 13, 2010 | 2007 Pontiac Solstice Convertible
Dell inspiron 1525 battery quit charging when warranty quit. Bought new charger, didn't help. Told motherboard needs replacement? This seems fishy to me. What kind of laptop works longer than the...
It is possible the battery itself has wore out. They have a limited amount of time they can be recharged. Does the unit run while the charger is plugged in??
Jan 26, 2010 | Dell Inspiron 1525 Notebook
Toshiba Laptop black screen
chek in bios setup your hard disk is detect or not.
when u power up the laptop press F2 or DEL or F5 or F12 then u see bios menu.then if your hard disk not detect disable sata.if u detect your hard disk set harddisk as first boot device then save settings.
but if u see first windows then blank scrrreen u need to do nothing.just do following.
when u power up the laptop press F8 key then u get safe mode and etc menu.
go to enable vga mode thwen u enter in windows xp set your display resolution to 800*600 or 1024*768
thats all.
Nov 10, 2008 | Toshiba Satellite A85-S107 Notebook
Powering off
Actually, if it is beeping as though the battery is low even while it is plugged in, it is because the battery is no longer any good and is sucking all the power from the wall. You need to purchase a new battery. Until you get a new battery, you can simply remove the battery and use the laptop plugged in. That will stop it from turning off. Been there - done that. Hope that helps! ; )
Nov 05, 2008 | Toshiba Satellite A35-S1592 Notebook
Open Questions:
Toshiba Satellite X205-S9349 Notebook Logo
91 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
