Question about InFocus IN72 Multimedia Projector
What does scart mean? - InFocus IN72 Multimedia Projector
    Sergeant:
  • 176 Answers
what does scart mean? - images?q=tbn:and9gcsq3imtjhqb0abmt8dptscde8waay3n_hlomxu7sbdjgyrsqmaoxypwoa
A SCART connector is a physical and electrical interconnection between two pieces of audio-visual equipment, such as a television set and a video cassette recorder (VCR). Each device has a female 21-pin connector interface. A cable with a male plug at each end is used to connect the devices. (The 21st pin is actually not a pin but a ground shield contact.) Stereo audio, composite video, and control signals are provided in both directions. RGB video signals are input only. The interface is an industry standard
originated by the French company, Peritel. Today, most new television sets and VCRs in the European market and other countries that use the PAL video standard come equipped with a SCART connector. SCART stands for Syndicat francais des Constructeurs d'Appareils Radio et Television. The connector is also known as a Euro-connector.
Although it is possible to build your own connecting cable, knowledgable people recommend buying a commercial cable because of the detailed pin-crossovers and close pin connections. Differerent cables serve different purposes. A cable for connecting a VCR or a TV set to a high-fidelity audio system needs to use only three of the 21 pins.
It is more difficult to use the SCART connector to interconnect a VCR to a computer monitor because of the difficulty of synchronizing the composite video signal (which is companded into red, green, and blue) from the VCR with the RGB signals needed by the monitor.
Posted on Feb 17, 2012
I have an Element LCD flatscreen model Eleft326. Can I hook up my Polkaudio Surround Bar 6000 to it?
surely there is a scart fitment that will allow this? I imagine that the connection is possible by some means or other, if you have insufficient scart sockets obtain a scart expansion device, I haveone , can put 4 scarts on my single slt tv. Ebay or Radioshack should have these
Apr 24, 2016 | Element Televison & Video
Flickering blackness while viewing films
sounds to me to be the scart lead or the scart is not fully connecting.what i mean is watch for the scart connector on your tv or dvd moving in when you plug the scart lead in.
Mar 08, 2014 | Pioneer DVL-909 DVD Player
Trying to connect scart to video input but unit wont pick up signal. Computer input (vga)is fine
Ok SCART is meant to be a "Standard" meaning all SCART should be the same, unfortunately they are NOT. Please have a look at the Wiki link below it will explain all. Some SCART plugs do not have all connection wired through, you must ensure your SCART cable has EVERY wire intact, we usually meter out our plugs to check, as we have been caught out too many times, usually the High end, ones are OK
http://en.wikipedia.org/wiki/SCART
Mar 19, 2010 | Sony VPL-ES1 Multimedia Projector
Wharfedale DVD recorder, no sound. Scart lead connected to Sky Box & scart connection to TV. Picture OK & can play DVD's or record to HD but no sound.
HI if you mean scart connectors on rear of DVD recorder, try swapping scart inputs on DVD recorder and if no joys then on set top box. (some units have 1 input designated for TV and the other for Set top box input)
Mar 16, 2010 | Televison & Video
I have a Toshiba DVR19DTKB DVD & VHS Recorder with Freeview , A SKY + Box, A Panasonic NV-SD240BL Video cassette recorder, A Samsung PS42B450B1W 42'' Plasma TV, and would like see a diagram of how all...
connect the aerial to the dvd/vcr/freeview combo, connect a scart from that to the tv, from the scart out socket.
you can then connect the sky from the scart marked tv to either the tv direct or to the combo if it has a second scart.
Note. a scart socket with an arrow going into a box is an input, coming out of the boe is an output and a double arrow is a two way scart.
if you use scart 2 on the tv to connect the combo, the combo will recieve a signal from the tv for recording.
Jan 21, 2010 | Televison & Video
Panasonic TV: TX-28DTX10,VCR nv-HV60 EB, DVD:SC-HT 520
EC means euro connector, I.E. Scart socket. For some reason there is no video signal coming out of the scart cable/out of the VCR or being displayed on the TV. Try plugging the scart plug into a different scart socket and see if that helps.
Sep 14, 2008 | Panasonic TX-32PL10 32" TV
How to connect two vcr via scart cable over old tv
what you mean old tv ? with not scart conection?if yes,conect first vrc to second vcr via scart and second vcr via rf cable to tv if no scart socet on tv or via scart if tv have scart conection.
Aug 14, 2008 | Televison & Video
Vcr dvd recorders
I assume you mean a Digital Reciever. If so, and the Digital box has two scarts, connect as follows:- Connect the VCR scart to the "Input" scart of the DVD, the output scart of this to the "VCR" scart on the Digi-box, and the "TV" scart of this to the T.V. You need BOTH switched on. On the T.V. select to view the scart that the box is on and on the DVD select to view "Scart Input". You will now be viewing the VHS. When you want to view the DVD just change the selection.
Jun 02, 2008 | Insignia Digital-to-Analog Converter for...
WIRELESS LINK FOR SKY+ BOX
your sky box should have 2 scarts ;input and tv.I have one so as can watch sky upstairs and on projector screen.
reciever sender is in av on tv upstairs sender downstairs is in scart next to tv scart on skybox scart lead in tv scart connected to av on tv.some senders need to be turned on.when you plug in adapter and led is on doesnt necessarily mean sender is on .is this a new sender with instructions youve bought
Jan 01, 2008 | Acer TravelMate 2300 Notebook
InFocus IN72 Multimedia Projector Logo
192 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
