SOURCE: Arris cable modem
try shutting of your computer then shutting off the modem, the modems have batteries you might have to remove them theres usally a panel on the bottom, in the back you should have a wire for comcast cable and an ethernet chord telephone too if you have everything. also your modem could be broken, i had the same problem
SOURCE: how is Arris Telephony Modem installed?
Hi taldrich6 - You have this listed under Arris CM450. Is that what you have?
The Arris Telephone modem is used to connect you to the Internet, as well as provide the VoIP connection for your phone service.
if the power light is flashing then the modem is on battery backup and internet is disabled. plug the power cord into the modem or find a working power outlet, you should be set after that.
Power light flashing=bad
