Question about Sportcraft Exercise & Fitness
I have a sportcraft tx5.orc model#04050 i take a couple of steps and it stops what's wrong?
Shuts off after a couple os seconds
2 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: turned on, runs a few seconds, shuts off with a #3 on display
Contact the manufacturer. You need the optical disc. It is the speed sensor. Eric For Treadmill replacement parts, please contact our Consumer Affairs Dept. at (800) 526 - 0244
Posted on Aug 11, 2009
Tx 5.0 rc treadmill by sportscraft, manual
Did u find out the problem? Mine just started doing the same thing.
Apr 13, 2013 | Sportcraft Exercise & Fitness
TX400 STARTS BUT WILL NOT KEEP RUNNING FOR ONLY A FEW SECONDS
see the video and lube the deck + rollers bearing. This happen because the lack of maintenance.
If after you lube the problem remain, TIME to replace the old board deck
.God bless you
Feb 28, 2013 | Sportcraft Exercise & Fitness
The number seven appears on upper left side of tx5.orc treadmill
1) try to run the software calibration for diagnostic, troubleshooting and fix it.
2) adjust the REED switch see the diagram, clean it, and tight the plug+connector very well.
3) adjust the speed sensor , see the diagram, clean it, and tight the plug+connector.
God bless you
Sep 20, 2012 | Exercise & Fitness
The threadmill stops when i step on the decke. Why?
1) this hapeen has a protection to the electronic system, the machine keep safe the electronic soft and hardware.producing a shut down.
Lube the DECK BELT, inmediately.
2) LUBE the rollers bearing too very well
3) TEST the input voltage motor, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Sep 03, 2012 | Sportcraft Tx 4.9 Model 4041 B Walking...
I have a tx5 orc treadmill and it will not work when plugged in
1) you must use the VOM, for test the outlet wall, and measure if the voltage is o.k reset the c.breaker from your house.
2) reset the c.breaker from your treadmill
3) replace the fuse with the same capacity(ampers) +voltage and the same type ceramic or glass.
4) after you did the replace, test for main switch, and adjust the REED switch according see the instruc. manual.
5)if the problem persist a) LUBE the deck belt b) Lube the rollers bearing c) lubricate the bearing motor.Otherwise the main motor board is faulty.
Aug 05, 2012 | Exercise & Fitness
A backwards E appears on my treadmill model 3-1-04-050 FH what does this mean?
Read your instruction manual, section troubleshooting for indication.
However you must adjut THE reed switch, see the diagram attached, clean, and tigh the connector wires very well. God bless you.
Run the software calibration for diagnose, and troubleshooting too.
Jun 07, 2012 | Sportcraft Tx 455 Sportscraft Treadmill...
Turned on, runs a few seconds, shuts off with a #3 on display
Aug 06, 2009 | Exercise & Fitness
Exercise & Fitness Logo
136 people viewed this question
Top Sportcraft Exercise & Fitness Experts
John
Are you a Sportcraft Exercise and Fitnes Expert? Answer questions, earn points and help others
