Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Key pad won't operate opener
I have two model 139.53754 openers. both reciever learn the remotes transmitters. but won't learn from the keyless key pad code. The keypad stoped working so i replaced the battary this still didn't help. so i found my new keypad from the second unit and installed the battery in it and it doesn't learn the code either from this keyless keypad
    Novelist:
  • 91 Answers
Check to make shure the battery from the second unit is good because it was stored for a period of time ,make shure it,s installed correctly . and after installing battery press any of the buttons you should see the keyboard light up , if you have a hard time seeing it because of the daylight just cup your hand,s around the display ! If that is all good then before installing the keypad on the outside jam ,go to the machine and locate the srt button or the smart button , after you located it just press it once and the yellow indicator light will turn solid , at this time you can program 4 digits into the keypad and hit the enter button on the keypad , At this point after pressing and holding the enter button ,you will see the machines lightbulb turn on and off once , that is telling you that the machine has just accepted the code ,for your other machine do not use the same code because the two doors will open togeter for example 1234 enter.................2nd machine 1235 enter you should have no problem programming the machines , theese are the easiest machines to programm and only take litteraly a few swconds each ....it takes me less then 5 seconds to do each ! also another way to check if your keypad is sending a signal back to the machine is find the srt button or the smart button (,they are the same button) look at the yellow indicator light next to it and then press the enter button and hold it down on the keypad you will see the light on the machine blinking rapidly , That is telling you that the machine is recieving a signal ! Good luck and hope this helps you , if your keypad still don,t work bring it back to sears for a replacement , sincerely Glenn
Posted on Jun 10, 2009
How can I program my remote?
Remote for ? door unlock / lock , remote start , garage door opener .
If the door lock / unlock , panic alarm ,remote start . You can't dealer only . Need a factory scan tool .
Transmitter Programming
Important: Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly.
The scan tool must stay connected until all of the transmitters are programmed.
Invalidate All
This procedure will erase all keyless entry transmitters from memory.
Install a scan tool.
Turn ON the ignition with the engine OFF.
With the scan tool, select Body.
Select Remote Control Door Lock Receiver (RCDLR).
Select Module Setup.
Select Program Key Fobs.
Select Invalidate All Fobs.
Follow the scan tool on screen instructions.
Transmitter Slot Programming
Transmitter slot programming allows a single transmitter to be programmed into a specific slot without affecting any of the other programmed transmitters. By using slot programming, the transmitter originally programmed to a specific slot is erased and the new transmitter learned in its placed.
Select the key fob desired to be programmed.
Remove the scan tool.
Exit the vehicle. Operate all functions on transmitters to verify correct system operation.
Jun 05, 2015 | 2007 Buick LaCrosse CXL Sedan
Why Can't I add another remote to a merlin mt60p
If you purchase additional transmitters, the garage door
opener must be programmed to accept the new remote
code.
Program the Receiver to Match Additional Transmitter
Codes:
Using the orange "LEARN" Button:
1. Press and hold down the transmitter button you wish to
program to the opener. The orange LED will flash to
indiciate it is receiving signal from the transmitter.
2. Press and release the "LRN" button.
3. The sourtesy LEDs will flash once.
Ensure the door is clear of obstruction, then test the
transmitter.
Using the Motion Detecting Control Panel
(optional accessory):
1. Press and hold the button on the hand-held remote that
you wish to operate your garage door (1).
2. While holding the remote button, press and hold the
LIGHT button on the Motion Detecting Control Panel (2).
3. Continue holding both buttons while you press the push
bar on the Motion Detecting Control Panel (all three
buttons are held) (3).
4. Release buttons when the opener light flashes. It has
learned the code. If the light bulb is not installed, two
clicks will be heard (4).
Now the opener will operate when the transmitter push
button is pressed. If you release the transmitter push button
before the opener light flashes, the opener has not learned
the code.
To Erase all Transmitter Codes:
To deactivate any unwanted remote, first erase all codes:
Press and hold the orange "learn" button on opener until
the learn indicator light goes out (approximately 6 seconds).
All previous codes are now erased. Reprogram each remote or keyless entry you wish to learn.
http://gomerlin.co.nz/getattachment/2949a1dd-74ab-4576-850d-4f40de28fbe3/mt60p-installation-guide part 27 from installation manual page 15
May 05, 2014 | Building Materials
Tried to reprogram security code for outdoor key pad on 1/2hp craftsman garage door opener according to instructions online, pressed learn button- put in new 4 digit code-held enter. Lights did not flash...
Seems you've done everything right. Press and immediately release the smart/learn button and then walk over and key in a 4 digit code and press enter. If you are sure the battery in the keypad is good then I think your keypad is on the fritz or the wrong one for that opener.
Apr 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
Moved to a place with a 139.53975SRT1 Garage Door and Keyless Entry. Keyless entry stopped working and I cant get code to operate door. All remotes stopped working. Reset codes with Learn button,...
Try this method for programming. Press and hold the button down on the remote while you press and immediately release the learn button. Do this for each remote.
Have you replaced the battery in the keypad? Try this:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Post back with your results.
Jan 14, 2011 | Sears Craftsman LiftMaster Chamberlain...
Opener will not recieve programing instructions from the keypad.
There should be a button on the back of the door opener that says "teach" or "learn". Push that button, a light comes on and you have about 30 seconds to program the control by holding it near the unit and holding the remote button down. The opener will then learn the code from the remote.
Sep 17, 2009 | liftmaster Chamberlain Garage Door Opener...
Wireless key pad and remote openers for the cars work intermittently have tried re-learning
Your remotes and your keypad are small transmitters that send a signal to the receiver. If all your units are intermittent then it is the receiver that is bad. The receiver is part of the logic board.
Jul 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftman garge door opener changing code on key pad
having all the remotes you want programed with you, find learn button on back of opener. hold button until little light goes out- no remote will work now, with each remote Press learn button once,Press big button on remote-light bulb on opener will blink on/off if bulb is working-do this each hand held-keyless is same way, put you 4 #'s in HOLD enter button-light bulb blinks on/off you have 15 sec. for each time you hit the learn button. also best to start off with new 9 volt battery before you start programing
Aug 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Trouble changing passwordon model 940CB wireless keyless entry
easyer then that , you die! Open your garage door, take out the step ladder, a chair or get up on *********** in law's back, (here's your chance to be on her back for a change) press the read button of your unit (motor) a led should light up and on the key pad, key in the new 4 digits code and press enter, the light of the unit should blink javascript:; Post Solution
May 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
154 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
