Question about Kicker S15L7 Car Subwoofer
HOW TO GLUE SPEAKER BACK TO BASKET - Kicker S15L7 Car Subwoofer
    New Friend:
Hello What type of glue did you use? I have to the foam and cardboard edge to the metal 15" basket
Posted on Feb 15, 2015
    Scholar:
  • 51 Answers
It sounds like your speaker surround blew away and separated from the speaker cone and/or housing. I'm in the process of fixing one my speakers by replacing the surround.
Generally, when this happens, you'll want to completely replace the speaker surround (the outer ring that allows the speaker coil and cone to travel in and out, usually made of rubber or foam rubber). This isn't necessarily super difficult, it just takes some time, skill and patience, if you want to avoid messing up the speaker and sound from it.
Inspect and repair your existing speaker:
1) Measure:
a) the diameter of your speaker cone (outer edge of the angled piece that goes inward toward the center coil) and the
b) diameter of the speaker housing (the metal "frame" part the speaker surround glues to, which is usually where the speaker mounting holes are located).
Note
whether the area on the speaker cone where the surround connects to is flat or angled.
2) Ordering: You'll want to purchase the new speaker surround to match the similar material you've already got, as close as possible to the exact dimensions you measured in either flat or angled for mounting to the speaker cone.
SpeakerWorks.com tends to be a bit more expensive than others than can be found online, and they will normally have what you need. Their speaker surround repair kits normally come with instructions, surround, glue and a little brush. I found hunting around can save 50% or more.
3) Gluing: Get yourself some Aleene's Tacky Glue (online or in craft stores), and make sure you don't use too much or too little, applying in a uniform coat on one surface, then applying gentle pressure to get the surfaces to stick, and allow it to dry completely for 24 hours.
IMPORTANT: This can be tricky, so be patient, or you're buying a new speaker. If you don't feel comfortable, take it to be repaired properly.
Typically, you'll want to start gluing the new speaker surround to the outer portion of the speaker cone, either on the underside or inside, as it was with the prior surround. Make sure it's centered, applying just enough glue with a brush to insure it holds and you can still slide everything around slightly into proper position. Gently move the speaker in and out to make sure nothing is rubbing. Allow this to dry for a full 24 hours, and do NOT attempt to glue the surround to the housing until after the cone glue is completely dry.
Now, it's at least 24 hours later, you can do the same thing by applying an even layer of glue to the surround (or onto the frame) to complete the new surround replacement. Apply light pressure to make sure it's centered, again gently moving the speaker in and out to make sure nothing is rubbing. Allow this to dry for 24 hours, just like before.
I know, impatience makes this difficult, but then you don't want to be doing this all over again by trying to move too quickly. Worse yet, you can end up completely destroying your speaker cone.
The nice thing about that tacky glue is is holds well and allows you to position things for a while before it sets. Just remember to allow the proper drying time, which is always way longer than the dry glue you can see.
Remember to defer to a professional repairman if you do not feel comfortable doing these repairs yourself.
I hope this helps!
Posted on Feb 16, 2012
The speaker cone and foam not held toghether halfway need to know what glue to use on aluminum square speaker
Great question? if you can see the speaker then you will want a clear adhesive for sure if you cannot see the speaker then I would use Bear Glue it is the strongest you will need something good to hold it together during vibrations. I use this glue for everything. Let it dry for 24 hours before any use. A good way to do this is also use Bear Glue and a cloth cut it to fit the crack or split big enough to cover the wound. Place glue on the piece you cut carefully slip it behind the speaker and seal it from the back of the original fabric on the back side of the crack or the area. This will hide the fabric as well as give it a good solid seal. I hope this helps you. John
Jan 21, 2011 | Philips MMS 321 Computer Speakers
Removal of speaker from cabinet Yamaha SW118
Please take my response with a grain of salt for I only serviced subs from B&W and Harman International and Linn.
If there is no bolt directly opposite of the sub (very rare known as a basket tensioner). Then all you do it remove the screws then tap the box lightly with a rubber mallet and the driver will pop out. The foam rubber seal they use can really glue itself in there.
If the mallet doesn't move it then tap the metal rim of the basket lightly to free it up.
If it is like a Linn speaker and they actually silicone them in place them you have to thread an over sized screw into the hole to grab the basket then protect the face of the sub box with a cloth. Now use a claw hammer to rip the screw out and hopefuly the driver pops out with it.....these were a real pain.
Chances are its just stuck and needs a little tap to free it up.
Hope this helps!
Kevin
Feb 03, 2010 | Yamaha SW118-IV 18" Subwoofer Speaker
Bravetti pro 4 litre deep fryer model f1400b. used 3 times and whenever i use batter with like fish, put it in the basket, everything sticks to the bottom of the basket like glue. no matter what i try it...
Hi, this one is a bit tricky: you have to drop the basket first, hold on to one end of the fish without burning your fingers, and give the batter a minute - the whole piece will start to float when the batter starts to cook. You need to flip it over with tongs to cook it completely.
Sep 04, 2009 | Bravetti Kitchen Appliances - Others
Busted cone (i think)
First try swapping the leads on your source, powering the left speaker with the right channel, and the right speaker with the left, if the problem follows, then the issue is with your source, and not the speaker.
If the cone is torn, then try to patch it, using some basic glue and several layers of tissue paper. White Glue, embed tissue paper in the glue, more glue,embed tissue paper in the glue, do this several times building up several layers. Guessing this is a standard paper cone...
Now if you are still having the issue, could be that the woofer is damaged. Look for a replacement.
john
Aug 19, 2008 | Alesis M1-Active MkII Main / Stereo...
The spider on my 12' infinity Cappa has detached from the cone. i managed to slide it back up about where it goes,but im not sure what glue or what i should use to get it to stay there
Hi tiffleiffle
I use and recommend the specialist glue for speaker repairs that you can purchase online from here. Great for refixing spider wires,dust caps, foam surrounds. Also get just about any other speaker bit or spre part you could think of. Get your speaker bits from speakerbits
robotek
Jun 28, 2008 | Audio Players & Recorders
Samson 65a monitor speaker
If its not to big find a neostick or similar sintetic glue,piece of medicine bandage and black (if speaker is black) mat spray.First put some glue around the rip wait for 10 min and then put the bandage on it.After that again 10 min of waiting and new layer of glue on the bandage.Let it 24 hours for glue to dry an then respray it.If you can do it from the back side its better and repair is almost invisible.
Feb 29, 2008 | Samson Resolv Sub88 Subwoofer
Surround problem
if you have woofer in tight enclosure you might want to use a vented enclosure .This will lower speaker suspension displacement .Or if you already have speaker in vented box ,it also possible you have wrong volume box..If surround is just ungluing from basket rim .You can try using GORILLA glue to reglue to rim .If its tearing at cone then lower the volume.LOL
Dec 06, 2007 | Eclipse SW9152 Car Subwoofer
Parts
I am not sure but i suggest check for the manufacturer via the internet
May 23, 2007 | Achiever CCS5000 Shredder
Kicker S15L7 Car Subwoofer Logo
592 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
