Question about M&S Systems DMC1CD 6-Disc CD Changer
How do I connect an auxiliary source. I cannot locate where the auxiliary input is.
Its behind the DMC1 master unit, there you'll find 2RCA Jacks for CD and 2 RCA jacks for AUX Input
Posted on Jun 26, 2012
Connect tv to surround sound system
Connect a RCA cable from the TV Audio output (red/white)
to the surround sound Audio Input (red White)
If your TV has a "HDMI OUT" and your Surround System has a
"HDMI Input" Then use a HDMI cable instead.
You will need to set the source on your Surround System to
the audio source you use on the surround system(input)
On most it will be TV or Auxiliary.
Sep 30, 2014 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Can I connect a flash drive to logitech s715i?
The inputs are the Apple port (on the top) for iPod or iPhones, and the Auxiliary input for other digital music devices. You will need a 3.5mm headphone cable. The auxiliary input is located located just above the power connector on the back.
If you have a musical device that uses flash memory, then Yes you can. If however if you are reffering to a USB type of flash memory, there is no port for that.
May 18, 2014 | Logitech Audio Players & Recorders
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
Rear auxiliary audio plug port not working
Auxiliary is likely an input for external sound source. It won't produce sound.
Nov 06, 2013 | Logitech Bluetooth Speakers Z600
Rear auxiliary input source select
Unfortunately, the input on the rear of the stereo are Bus inputs. You must use a controller to use those inputs.
May 13, 2013 | Sony XR-CA600X Cassette Player
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
The battery on my car ent dead and now my AIWA CDC-MP32 keeps displaying "please unplug auxillary plugs"
An auxiliary input allows you to select an external source and play it through the cd player's amplifier. It's often used for iPods and MP-3 players. Typically you just need an inexpensive patch cable that connects the headphone output from your portable player to the input on the CD player. After that you can select "AUX" as another source like CD or Tuner, and whatever's playing on the portable unit will be heard through the speakers.
Auxiliary inputs can be on the front or the rear of the CD player. Front aux inputs are typically 3.5mm stereo plugs, similar to a small headphone jack. Rear aux inputs can be RCA jacks or a 3.5mm jack. If you have a CD player with a rear aux input, a cable needs to be connected at the time of installation. Then the other end can be routed to whatever location in the vehicle you want to keep your portable player while you're using it with the CD player.
Front aux jacks are more convenient for quick connecting/disconnecting the portable player, but they tend to wear out over time.
Let us know if you have somethin more to ask else accept the suggestion.
Thank You for contacting Fixya
Aug 19, 2010 | Aiwa CDC-MP32 CD Player
Not sure how to connect other devices
Unfortunately, the Westinghouse monitor has a bunch of inputs available, but completely lacks the audio output connection you need that would make life simple. Your Philips HTS only a single auxiliary audio input, but it does offer video and audio output connections to a monitor.
About the only solution I see available is to buy an A/V selector switch (available from Radio Shack and probably stores like Best Buy). Run the audio connections from the HD receiver and XBox through it, and send the output from the selector switch to the auxiliary audio input on the HTS6500. (You could use RCA Y-adapters to connect the audio to the monitor as well as to the selector switch if you really want to.) Send the video from these sources directly to the monitor.
You would need to select the source on the monitor, A/V switch and HTS to get the result you want, but it would be workable. (Now, why didn't Westinghouse simply include a set of audio output jacks with all those sources available?)
If this solution has gotten you going, please take a moment to rate it. And thanks for asking here!
Feb 25, 2009 | Philips HTS-6500/37 System
Switching on the auxiliary input
According to the manual, the AUX input is an optional accessory.
Check to see if the RCA jacks are labeled. I believe they are pre-outs only.
Best of Luck.
Nov 12, 2007 | Kenwood eXcelon KDC-X579 CD Player
Linking an i pod to a Sony CDX-MP40 using the bus input terminal
Some Sony head units let you use the Bus audio inputs as an auxiliary source input, but yours is not among them. To play your iPod through the head unit, you'll either need an iPod interface module: http://www.xplodsony.com/xplod/accessories/XA-110IP or an auxiliary input module: http://www.xplodsony.com/xplod/accessories/XA-300 The iPod interface will allow you to control and display the iPod directly through the head unit, while an auxiliary input adapter will allow the iPod to play through the head unit using the iPod's controls and display.
Jun 01, 2007 | Sony CDX-MP40 CD Player
241 people viewed this question
Top M&S Systems Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Tre Elkins
Are you a M&S Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
