Question about Westinghouse Refrigerators
Trouble shooting westinghouse silhouette series 2 model 445 fridge
docjohn174
  • 943 Answers
SOURCE: where to find fridge drawers
Hi. thanks for the question . I would try, Repair clinic. you will need the model # thanks the appliance doc
Posted on Oct 03, 2008
SOURCE: I need to replace light globe in westinghouse
I rang Westinghouse and they gave me the type of globe I needed.
Many Thanks
Posted on Aug 05, 2009
BMT60
  • 126 Answers
SOURCE: Westinghouse Silhouette Frige 522 frost free is
UNPLUGGED FOR 24 HOURS AND LET IT TOTALLY DEFROST.
Posted on Apr 24, 2010
tunde007
  • 2382 Answers
SOURCE: Westinghouse Silhouette Frost Free 442
Hi, this is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try:
If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, i usually recommend you contact a qualified appliance repair technician.
Posted on Mar 03, 2011
heatman101
  • 43501 Answers
SOURCE: My Westinghouse Silhouette 652, will
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Aug 02, 2011
I have a Westinghouse Top Level Silhouette 411 Model RB411G-R-9. I need the Manual for this Refrigerator please.
Go to manualslib.com... Westinghouse... or SEARS
has a pretty good library... ALL FOR FREE
searspartsdirect.com
http://searspartsdirect.com/
Jul 09, 2016 | Westinghouse Refrigerators
Westinghouse silhouette frost free fridge 522
I've been on fridges where this happened. I've found the thermostat to be the issue, or the temp sensor to be the issue. It's hard to check without being there with the proper equipment. It may be worth the money to contact a service tech. lmk if you need more help!
Aug 04, 2013 | Refrigerators
My Westinghouse Silhouette 652, will not freeze food or chill food in the fridge are, both areas are cold but only just although they are set to maximum
heatman101
Aug 01, 2011 | Westinghouse Refrigerators
Have a westinghouse silhouette frost free 442 fridge freezer. It is full of ice behind the back panel. How can I remove the panel? Is there a simple way to defrost the ice? It is approximately 5 cm...
its easy to remove the ice ( just add heat ) / but you do need to correct the problem . this sounds like a defrost cycle failure .. ck the defrost heater and the defrost terminator . and the heater itself .. the model # is not complete try to find the one on the unit itself . in order to get better info .. hope this helps mmm. feed back pls.. 7/10 //11
Jul 10, 2011 | Westinghouse Refrigerators
Apr 24, 2010 | Refrigerators
Where to find fridge drawers & glass top for westinghouse silhouette 521 auto-defrost
Oct 03, 2008 | Refrigerators
Refrigerators Logo
71 people viewed this question
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
