Question about Danby DWC508BLS Wine Cooler
Danby wine cooler fan is continuosly cycling
Fan will shut off for about 15 seconds then starts right back up and continues this cycle constantly.
Demy
  • 20 Answers
SOURCE: danby wine cooler
Is it because your keypad not functioning, meaning does the number change when you press the arrow up or down? Or when you set it, (let's say 12 Cel.) it does not reach down to that temperature. Then it could be either it's a sealed system problem( leaking refrigerant or under charge if it's a new unit). Or it could be a control problem( electronic control or sensor)
Posted on Aug 01, 2007
  • 1073 Answers
SOURCE: Danby Wine cooler runs and runs
not hard to replace but you are correct if it is not cycling off at the temp you want it to then the temp control is the problem
Posted on Apr 12, 2008
SOURCE: Danby Wine Cooler
If you are getting the E4 error code, try replacing the defrost sensor. The part might take forever to get to you, but we replaced the sensor on the wine cooler and it's working.
Posted on Jul 22, 2008
  • 44 Answers
SOURCE: danby wine cooler compresser not running and is hot
The compressor needs to be tested to see if it's operational. This normally needs to be done by a service tec.
Posted on Aug 21, 2009
  • 1214 Answers
SOURCE: Danby wine cooler is not getting cold. Fan is
Last one of these brought to me had lost it's charge. They are not very well built.
If your within 5 years, take it back to where you bought it. Unit's have a 5 year warranty on the compressor. If the compressor is bad, negotiate trade-in for a newer unit as you can buy a new, better unit for about the same amount of money.
Posted on Dec 11, 2009
Danby wine fridge making noise
If I checked out the right video it sounds like a fan motor. After a fan motor heats up and with age the fan will leak a little oil, the oil will become to thin and not cote the bearings well enough. It sounds like the fan trying to start back up after stoping. I would track down the fan motor and replace it.
Apr 09, 2014 | Danby DWC283BLS Wine Cooler
Recently, the wine fridge has started to make a whirrring sound that lasts around 4 or 5 seconds, then stops for around 20 or 30 seconds, then starts whirrrring again. Sounds a bit like a man moaning....
it was the internal fan in the upper rear section of the fridge. Apparently, since it is mounted so close to the rear panel, the sound seems to amplify from the back. Anyway, a replacement fan was only $3.71 direct from Danby, but I did have to pay 7.99 for shipping. Also, there is a fair amount of disassembly and re-assembly needed, which might be challenging for those who don't typically make their own repairs. Once removed, the only thing I could find wrong with our old fan was that the shaft was very loose in the unit, which may have indicated a bad bearing.
Canby may be reached at the following link:
http://danby.com/customer_service
May 21, 2011 | Danby DWC283BLS Wine Cooler
We have a danby dwc283bls wine cooler that no longer cools, and the compressor gets warm (above normal) does it need to be recharged
that's always a possibility but not always the case. The thermostat may not be cycling correctly or set wrong. The condenser could be dirty or if there is a fan, it may not be running. Freeze ups can also cause an "Out of temp." condition. Check it out.
Apr 15, 2010 | Danby DWC283BLS Wine Cooler
Danby Silhouette DWC513BLS lower back fan noise.
Called Danby customer service. Requested repleacement part of lower fan unit. Located at bottom right on back of unit. Part was $6.68 plus shipping. Less than $10 total. At my door in 3 days. Plug and play piece that was easy to change. A very cheap fix and I hate to think what a service call would have been. Danby ph # is 800-263-2629.,
Dec 08, 2008 | Danby Silhouette DWC512BL Wine Cooler
Danby wine cooler repair
call Danby at 800 263 2629, you can order parts from them
May 10, 2008 | Danby DWC283BLS Wine Cooler
Wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Mar 25, 2008 | Danby DWC513BLS Wine Cooler
Wine cooler noise
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Dec 30, 2007 | Danby Silhouette DWC512BL Wine Cooler
Danby DWC508BLS Wine Cooler Logo
81 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
