Question about Sewing Machines
Kenmore sewing machine 385 17624 only sews backward
Machine only sews backwards, with or without reverse lever depressed
RickE1
  • 202 Answers
SOURCE: backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Posted on Jan 11, 2009
radiohead68
SOURCE: serger
As long as this is a sewing machine and not a serger, I don't know about them. I only tinker on my own. Remove the bottom. There is a rod running along the length of the machine. it needs to be turned 180 degrees. You may need to retime the machine.
Posted on May 29, 2009
  • 52 Answers
SOURCE: Viking sewing machine model 6430 will only sew backwards
Th cam stack gears have gummed up on you you can try getting the back cover off along with the side and soaking the machine down with wd-40 and running it while forcing the reverse button in and out if it breaks free try and soak up as much of the wd-40 as you can and then oil anything that moves. I know this may be discouraging but viking no longer supports this machine and you might be better off taking it to an older viking dealer for help.
Posted on Jul 14, 2009
  • 4 Answers
SOURCE: I own a Sears Kenmore machine that began sewing backwards
Make sure that the reverse button isn't stuck inside. if all else fails, go back to sears and have them look at it.
Posted on Oct 16, 2009
  • 109 Answers
SOURCE: my machine is only sewing
Try hitting the reverse button twice in quick succession. SOME machines have a permanent reverse feature. Also check your manual for this feature.
Posted on Aug 23, 2010
How do I fix a serger that sews backwards?
move the sewing direction knob /lever to forward
Sep 27, 2016 | Sewing Machines
My machine will not sew in the forward position...It keeps sewing backwards like it is in reverse.....Need help ASAP
All sewing machines have a gear lever. This is so you can sew a seam forwards and backwards. Consult your manual.
May 03, 2016 | Sewing Machines
Machine will only sew in reverse
You wrote,
"Machine will only sew in reverse - Sewing Machines" A: I'm just a tinkerer, hobbyist, who did run across this same problem before. I can give a general non-model specific remedy based on my limited experience with mechanical sewing machines that get locked into sewing backwards, that is "they only want to sew in Reverse":
1. Verify what is the normal direction of the fly wheel in forward sewing for your machine. Most sewing machines, including Singers, always sew with the top of the flywheel moving toward the operator, regardless if sewing forward or backwards; but older friction-wheel White Rotary (RF) sewing machines, have the flywheel running in the opposite direction (top of Hand-Wheel turning away from the operator when sewing.
2. If it has Reverse Lever/Switch; check that it is in the correct position; if still only sews in reverse, change positions of the Direction Control lever (or Button, etc.), and see if it changes direction to correct the problem.
3. If this does not help, then jiggle the Reverse Lever and follow the linkage inside the machine and see if there is anything broken, loose or out of adjustment. Some machines have reverse control linkage elbows in the top part of machine, and by poor design are prone to accidentally pop backwards, causing sewing in the opposite direction of the position of the Reverse Lever/Button (Backwards when you want to sew Forward). On occasion, a Kenmore 158.1787180 got locked into the backwards sewing mode (the dog-gone' est thing), but by following and analyzing the linkage, I found where it was going wrong, and popped the indecisive linkage elbow back the way it was supposed to be and fixed it. [ I had more detailed notes, on this fix, but when I read them, without the machine in front of me, made no sense to me today so I can't share that till I revisit the conundrum again.]
4. If all else fails, you may be able to hold or clamp the Reverse Lever/Button in the Reverse position, so it sews Forward (I've done this before too (as a short-term fix) until I figured out how to adjust it back the way it was supposed to be.
5. If this post helped you, don't be afraid to indicate so, so Fixya will know. If it was useless, "ouch", but I'd like to know that too, so I'll be more selective on what I really know more about. I try to help, though this is probably a trade secret that anyone who knows is discrete about who they share the information with.
Sincerely
-- Amender. (2016 FEB 24)
Feb 06, 2016 | Sewing Machines
Can't remember how to stop sewing backwards
a small button or lever makes it reverse
Dec 04, 2015 | Sewing Machines
My sewing machine will only sew in reverse
The stitch length lever on some machines will back stitch when the lever is in the uppermost position. Bring the lever down to an appropriate stitch length and your machine should stitch forward.
Oct 11, 2014 | Singer 3116 Simple
Jul 02, 2009 | Brother XR-65t Mechanical Sewing Machine
Only sews backwards
You probably have it in the buttonhole stitch.
Mar 23, 2009 | Euro-Pro 9000 Mechanical Sewing Machine
Reverse Switch Control on my Kenmore Sewing Machine
My back swith button is not working on my Kenmore sewng Mchine. Can you tell me what the problem is?
Aug 25, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
